Question about Danby DPAC9008 Portable Air Conditioner
Leaking out the bottom. Soaks the carpet - Danby DPAC9008 Portable Air Conditioner
Rain water leaking in drivers side vauxhall meriva
if this is a new shape meriva the problem is the wiper scuttle seal leaking water .it drips into the engine bay,onto the heater pipes and tracs into the cabin.Pour water onto the screen and look into the engine bay,just behind the engine and you will see it drip onto the heater pipes where they enter the bulkhead.It then tracs into the cabin and soaks the carpet.The problem is a foam seal on the scuttle panel when it should be a rubber one.One fix is to ensure that the seal where the heater pipes enter via the engine bay is dry and spray it and the pipes with underseal.Vauxhall are aware but dont have a solution?
Jan 02, 2013 | Cars & Trucks
Rear Door seal water leak
If silicon is working,I would go with it,silicone last a long time and it's working.
Dec 25, 2012 | 2001 Toyota Sienna
2001 toyota sienna water leak inside rear door seal
For water leaking inside the rear door panel, I'll suggest you check and replace the black rubber/foamy seal that is part of the high-mounted-rear light assembly.
It gets weak over time and soaks water, thereby allowing water seep into the booth lining and also into the underlay of the carpet.
If you have a cracked rear-light (the one attached to the boot hatch), you may also get a leak.
Change this rubber seal/ gasket. I used an old rubber carpet to make a gasket to fit the light assembly, and it stopped the leakage.
Hope this helps.
Feb 07, 2012 | 2001 Toyota Sienna
My floor boards in my Cavalier are Soaked ..
If you've been using your air conditioner during this time, and it hasn't rained at all, then the small drain at the bottom of the a/c evaporator core may be plugged. When you use the a/c to cool the car the evaporator coil [located next to the heater core in the ductwork under the dash] is very cold and moisture from the hot humid air condenses on it as a result. This condensation dribbles down the core and accumulates in the plastic housing under it where it should then drain out a small hole and drip onto the ground. If the small drain gets plugged, which happens quite often, then the water fills up the housing until it overflows and then runs out and soaks the carpet on the front passenger side. The drain is located on the engine side of the firewall, passenger side, down low where the firewall begins to curve under. Usually a puff of air will clear the clog and the drain will work fine again. If the carpet is really wet it would be a good idea to remove it and get everything dry again as it tends to get pretty smelly if left wet. One last note: usually a leaky a/c unit will only make the passenger side carpet wet unless it's been leaking for a long time while a leaky windshield seal can make both sides wet depending on where it is leaking. Good luck, hope this helps you out!
Jul 29, 2010 | 1993 Chevrolet Cavalier
My yukon rear ac i think! got my rear rear carpet all wet im thinking ac drain plug but dont really know how it works any ideas thanks ronn
The A Pillar is filling up with water and running out the hole where the front kick panel attaches. I took me 6 months to find this and a snake camera from Harbor Freight. The water runs down under the sill and soaks the front and back carpets. Seal the door hinges and the door grommet where the wires go from the pillar to the door with silicone black. Pull out the grommet and seal around it well. I also drilled a drain hole into that cavity just under that pillar but behind the front of the door bottom corner so it cant be seen with the door closed. No more problems!!!
Jan 17, 2010 | 1999 GMC Yukon
Water leaking into 2005 Camry 6 cyl under carpet drivers side.
I think that I can help you. It sounds like your drain-tube is plugged up. Get in the passenger side, and pull the carpet back from under the glove box. Look for a black rubber pipe that goes from a black box, and pokes thru the firewall, on the passenger side. Remove the hose from the box, and have a container ready to catch water. If water comes out of the black box, your drain hose is plugged up. Clean out the clog, and you will be golden.
Jul 27, 2009 | 2005 Toyota Corolla
Pinguino ct 90 trips the circuit breaker and soaks the carpet....
My Delonghi Penguino ct90 no longer blows cold air out for longer than a couple of minuets need a fix for this and it is no longer under waranty. Please help.
Jul 05, 2009 | DeLonghi Pinguino PAC-700T Air Conditioner
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Heater matrix leaking
You'll probably have to remove the old leaking heater core from under the dash.A chiltons or haynes shop manual would be very helpful in telling you the actual step by step proceedure for removing the old core and installing the new one.I've replaced several heater "cores' and it involves a good bit of body contortion to get you head under the dash to see what your dealing with,but I,m confident that you can get the job done.Don't skip any steps here cause that way leads to frustration.Be sure to have a small bucket or tuperware container handy to catch any excess antifreeze before it soaks you carpet.
Dec 19, 2008 | 2004 Land Rover FreeLander
Danby DPAC9008 Portable Air Conditioner Logo
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
