Question about Ovens
Eurolec stove looking for new knobs - Ovens
  • 1,711 Answers
Where can I obtain an Instruction manual for a Eurolec built under oven with grille?
Looks like the support is overseas. However they do have email support. If I knew the make and model I might be able to obtain more information. Otherwise here is the email link for support:
Reception@Eurolec-Services.co.uk
Jul 02, 2015 | Ovens
Where can I order new knobs for my stove
It depends a lot on what brand it is. But sears has a universal knob kit .
http://www.sears.com/search=universal%20oven%20knob%20kit
May 03, 2015 | Ovens
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
Eurolec stove auto ignition not working
press for few sec for hold and ignate the knob
Dec 09, 2010 | Haier Ovens
My eurolec oven is letting the heat out and burning the cupboards
check that the fibre glass is still in place and has not been soacked with water, you can get some fibre glass from your local stores and wrape it just after openning the couvers and puting them back to place
Aug 02, 2010 | Ovens
Looking for a Oven knob for the Caloric Presige
http://www.appliancepartspros.com/partsearch/
or
http://www.expertappliance.com/caloric-stove-parts.html
Oct 18, 2009 | Ovens
I need six knobs for a 1950 Frigidaire model RM-45
I have the same model stove for sale. here is my number 678-644-2161 samantha
Jul 23, 2009 | Ovens
Eurolec oven fire - gases released made us sick
Good morning Folk!!
A toxicity doctor rang me to say that I have been exposed to vitreous enamel and galvanised metal.
The composition has zinc, chromium, silica so when the gas came off the oven interior, I had "gas fever, short term toxic, that would be eliminated from my body with no expected problems. Apparently welders have this all the time. It causes irritability, nausia and sleepiness. Australia has very poor metal detection in blood testing. It usually has to be sent to America.
I don't trust Eurolec, nor the company who made their baked enamel ovens - Technogas Italy, who now produce for Euro appliances.
I'm getting a new stove - ILEVE - which is a better quality gas stove all round.
Bye for now
Sandra Petersen
Sep 17, 2008 | Ovens
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Ovens Logo
57 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
