posted by Volkhard on Apr 27, 2008
Whre can I get one and how to replace it? open the case? is the batterie plugged or soldered?
1 Other User Has The Same Problem
Comment by hmpcole, posted on May 13, 2008
My CMOS battery is dead and the time and Date keeps reseting.
I will tear into it soon so I can try to replace it.
Best Solution
posted on May 31, 2008
The CMOS Battery is behinf the main battery behind a platic shield. The shield is relitivly fragile and glued around the edges. Care should be used removing it to prevent ripping. The battery itself is 3" flat pack glued to the case. Mine was wrapped in a black heat shrink with two wires exiting.
The connector is under the keyboard. You will need to remove the 6 scres from the bottom of the case to release and remove the keyboard. The keyboard ribbon cable is attached through a ZIF socket. Be sure and release the cable before removimng the keyboard. Youll have to trace the CMOS battery leads to determine the correct connector.
I found a Maxell ML2032 rechargable battery. Unfotunatly all the 3" flat pack batteries I have found are LITHIUM ION and not rechargeable. If I find a replacement I will post the information.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Acer TravelMate C110 Tablet PC
Email this problem
Email this problem
Can you Help with these Tablet PCs problems?
CD RW & DVD driver working...
I don't use the external drive... Answer This...
Repair Service
Find Tablet PC Repairman Near You:
