Question about HP Computers & Internet
What to update window installer Have error saying cant find window installer Want free updates all fail
    Scholar:
  • 131 Answers
Did you register your copy of windows when you installed it you need a product key which is usaully on the side or back of pc i dont think you can get updates after 30 days after reinstalling... its a 25 digit code containing letters and numbers reinstall and register it...to find where to register on vista click on start then right click on mycomputer then select properties then a screen should come up with your pc's specs go to bottom of that box and see if your copy is registered if not click on link to do so it might work hope this helps
Posted on Aug 11, 2010
How to get Windows update to work after doing re install of Vista?
Try updating your hard disk drive driver see:
Vista Windows Update Error 8024A000
Here's the solution. I had to replace a failed hard drive in a Vista laptop. The original drive was a 200GB and I replaced it with a 500GB. I used my original Toshiba restoration CDs. I've spent HOURS troubleshooting this problem and I never would have guessed the solution -- it's the Intel Rapid Storage Technology Driver. It has to be updated because of the larger drive.
Here's a link to an HP support site for the updated driver. You can also find the update on Intel's site.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02219204&cc=nl&lc=en&dlc=en&product
Sep 22, 2014 | Toshiba Satellite A305-S6872 Notebook PC
Hi my mum has just purchased windows 8..can get onto facebook...but when she wants to play mindjolt games..(golf solitaire) it will come on... but then has a white screen where the game should be.altho it...
Hi there. Firstly... make your mom a cup of tea . You know how to calm her down . Then take on this task . It looks like a impossible task , but just follow the instructions . You can do this: Install the Windows 8.1 Update (KB 2919355)
  • ?Email
  • Microsoft support. Code 0x800F0922 This error might mean that a file needed by Windows Update is damaged or missing. Here are a few steps you can try to fix the problem:
    1. Run the Windows 8.1 Update troubleshooter to fix the problem.
    2. Install the Windows 8.1 Update or Windows RT 8.1 Update.
    Code 0x800F0923 This error might mean that a driver or other software on your PC isn't compatible with the update. For info about how to fix this problem, contact Microsoft support. Code 0x800F0922 This error might mean that your PC couldn't connect to the Windows Update servers. If you're using a VPN connection to connect to a work network, disconnect from the network and turn off the VPN software (if applicable) and then try to install the update again.
    The error could also mean there isn't enough free space in the System Reserved partition. You might be able to fix this problem by using third-party software to increase the size of the System Reserved partition. Error: We couldn't complete the updates. Undoing changes. Don't turn off your computer.
    Error: Failure configuring Windows Updates. Reverting changes. These are generic errors that might appear any time a Windows update fails. You'll need to determine the specific error code to investigate how to best resolve this problem
    You can find the error code for the failed update by viewing your update history. Look for KB 2919355 in the list, note the error code, and then contact Microsoft support.
    To view your update history:
    1. Open Windows Update by swiping in from the right edge of the screen (or, if you're using a mouse, pointing to the lower-right corner of the screen and moving the mouse pointer up), tapping or clicking Settings, tapping or clicking Change PC settings, and then tapping or clicking Update and recovery.
    2. Tap or click View your update history.
    Error: The update is not applicable to your computer. This error might mean that your PC doesn't have the required update KB 2919442 installed. Check to make sure that all important updates, including KB 2919442, are installed on your PC. If all updates are installed, you might need to refresh your PC.
    To refresh you PC:
    1. Swipe in from the right edge of the screen, tap Settings, and then tap Change PC settings. (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, click Settings, and then click Change PC settings.)
    2. Tap or click Update and recovery, and then tap or click Recovery.
    3. Under Refresh your PC without affecting your files, tap or click Get started.
    4. Follow the instructions on the screen.
May 07, 2017 | Computers & Internet
Short dst failed fix
Drive short test failure usually indicates what it says, which is a fault with the drive, but you state that this happened after an update (don't trust windows update!)
do you have have any error codes this could indicate further the exact problem. but usually this type of error would indicate a drive fault which would require replacing the drive
Cheers D
Mar 03, 2014 | HP Pavilion g6-2210us Notebook Laptop PC
Windows update failed
You version is no longer supported, time to upgrade
Apr 04, 2017 | Office Equipment & Supplies
I cant install windows update error code 80040154 thanks for yours halp.
Hi arturkollaku
Go to the windows website and they will give you free professional help to install your windows update...
Apr 16, 2011 | Home
PS3 Update successful,install failed,systemrebooted,error8002F14E
On the playstation 3 site error code tool says this code is an issue updating the PS3 sytem software. Try to start with the hard drive uninstalled then try again installed. If that dont help i would format the hard drive in a laptop and see if it helps. worst casr scenario you could dissasemble the PS3 and unplug tha battery on the main board and see if that helps. Good Luck
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
Trying to download avg 8.5 free edition
You cant put 2k service packs on XP, try xp's sp3, it may solve the problem
May 20, 2009 | Microsoft Windows XP Home Edition for PC
Installing Nero 8
Just down load windows installer 3.1
WindowsInstaller-KB893803-v2-x86.exe and install it on your PC. After installing the above you try installing nero 8.
This will solve the error "Cannot update MSI engine, please update manually".
Oct 15, 2007 | Computers & Internet
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
