Question about Hunter 52" Ceiling Fan With Light And Remote Control
Hunter Fan with Remote
My new fan and light comes on at will. How do I fix?
  • cindy_kra Apr 30, 2008
    I have the same problem. The light and/or fan will just come on at will. What can I do to correct this problem?
  • kagleed May 01, 2008
    It turned out that that the dip switches needed to be changed to other settings. Dip switches are in remote (battery compartment) and in lamp (in part closed to ceiling). We switched them and no problems for almost a week.
    Sergeant:
    Scholar:
  • Hunter Expert
  • 96 Answers
I think you re-check your fan installation once again. before looking out for other options.
Take help of the video at the below link. http://www.ceilingfandirection.com/knowledgebase/
Installation Help
Posted on Apr 10, 2015
Contact Hunter Fan and they will send you another ceiling remote. Just received mine but have not installed yet. Good luck. Len
Posted on May 01, 2008
wbwill
  • 68 Answers
SOURCE: Hunter Fan problem
Joel, you could have anything from a loosened connection in the connection box above the fan, in the fan, or in the wall switch if installed.
because the remote or pull chain will not start the fan, it tells me the fan windings or bearings are probably bad.
I don't know what age this fan is, or the cost, but if it is a typical hardware type fan, I would look into a new one.
If for some reason, it is one of the more expensive fans Hunter makes, [over $200.00] it might be worth looking into repair, anything under $100.00 you will spend more finding the issue than a new fan would cost.
Let me know, we are experts in ceiling fans, especially older fans, some of those are very expensive, built with brass cages, have custom blades, I hand wound one hanging in an Art Gallery to this day, cost twenty years ago to rebuild it completely was over $2000.00 [four zeros]
It is a very common repair cost versus new price evaluation, you have a problem in that two devices will not start the fan, one mechanical method and one electrical which is 90% chance it is something fairly severe in the fan.
You can send me the some photos or estimates of the cost, if it is one of the high dollar fans, I can help you find a shop locally to look at it, again if it is a typical off the shelf unit, get a new one.
Will
Posted on Dec 02, 2008
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
  • 5 Answers
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
if the battery's are good then you broke it and you have to order a new one which you can do by calling the place that you got the fan from tell them what kind of fan you have and let them know that you nead a new remote and they will be able to help you do that.
Posted on Aug 13, 2009
hondakilla
  • 129 Answers
SOURCE: Hunter Fan - fan turns on and light goes off
you need to check the wiring and make sure factory dip switch settings are set
Posted on Aug 23, 2009
  • 3 Answers
SOURCE: I have a Hunter fan with remote. The fan or the
See my post below: (Sorry, we're in the same boat)
Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!! P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Posted on Apr 03, 2010
Hunter fan 27227 remote stopped working
How i fixed my Hunter #28096 remote controlled ceiling fan, started not controlling the light, then later the fan quit also. Start by testing the remote buttons, see this post... Cp9430r Fixya
Jun 22, 2014 | Hunter Ceiling Fan Light Remote Control
Remote will not turn on fan. A ll I get is a click.Light works fine
How i fixed my Hunter #28096 remote controlled ceiling fan, started not controlling the light, then later the fan quit also. Start by testing the remote buttons, see this post... http://www.fixya.com/support/t11813083-cp9430r Cp9430r Fixya
May 30, 2014 | Hunter Ceiling Fan Light Remote Control
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Dec 30, 2012 | Hunter 52" Ceiling Fan With Light And...
I have a Hunter fan with remote. The fan or the light comes on by itself with no one around
Apr 02, 2010 | Hunter 52" Ceiling Fan With Light And...
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Aug 13, 2009 | Hunter Ceiling Fan Remote Transmitter...
Hunter Sonic Ceiling fan comes on by itself
is it your grage door opener that could be doing it
Jul 22, 2009 | Hunter 52" Ceiling Fan With Light And...
Remote Chewed Up
i had similar problem with remote , went to home depot to buy a new fan and saw they had new remotes and receivers for the hunter fans , i bought the kit ( which had a remote and a receiver for a non remote ceiling fans) and was working again . salesman was very helpful .thanks.
Dec 30, 2008 | Hunter 52" Ceiling Fan With Light And...
Ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Dec 28, 2008 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
657 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
