Question about Compaq Presario sr1111nx 2.53GHz Celeron Computer (SR1111NXRB) PC Desktop
I have only 10% hard drive space when I should have more. I can't find what the problem is, I am trying everything I can think of. Would updating my drivers solve anything? I know I need to upgrade my RAM but no money.
  • joaquim Aug 08, 2010
    is a spyware installed on os, your computer is webserver from hackers. try buy a good antivirus.
  • 62 Answers
Run All programs >Accessories> System tools > Disk cleanup once and see if you got enough space. If not, go to Control Panel > Power options and disable hibernation. After that again run the Disk Cleanup.
Posted on Aug 08, 2010
How to get the latest Win 10 update from 10586 to 14393 with error "too low memory needs 8G"
To update to Win-10, the system requirements are:
  • The present O/S should be either Win-7 or Win-9 [Licenced version]
  • Minimum 2GHs processor.
  • Minimum 2 GB of Ram
  • Minimum 20GB of free hard disc space partition. (C - partition)
Otherwise, won't go. No need to try.
Dec 13, 2016 | Computers & Internet
How clear the contents of the temporary folder?
Are you talking about on your GPS or on your computer?
I think that error message has nothing to do with the Cache... first make sure your hard drive has 5-10 GB of free space, then try updating to the latest version of Garmin Express and try the update again
Aug 02, 2014 | Garmin nuvi GPS
Status code 4174-0000-3080-0504-8007-000D
This is very simple: you seem to not have enough hard drive space for a system update that your console is trying to install.
Error 8007 0070 occurs when you install an update or buy content on...
(I've pasted some bullet points for you)
" Error 8007-0070 occurs when you install an update or buy content on Xbox 360
Problem
You may see the following error code and message when you try to update your Xbox 360 console or purchase content:
xxxx-xxxx-xxxx-xxxx-8007-0070
Note
The "x" characters in the error code vary.
This may mean that there's not enough space on your storage device (mostly likely the Xbox 360 hard disk) to install the update or the content.
Solution
A console update or content download may require significant hard disk space. If you don't have enough free space, you need to move or delete some items."
You can probably get around this by using a 32gb USB thumb drive and moving some of your content that's hogging up your console's space onto that thumb drive temporarily.
Heres the Xbox.com info to get you started about moving and deleting hdd space--which also has info about using a USB thumb drive, too. Copy move or delete Xbox saved games profiles and avatar items
Jul 21, 2014 | Microsoft Xbox 360 Console
I want to back up my hard drive onto my Elements external drive. The computer says that the Elements 3607 does not have enough space. What do I do?
Well first of all check how many free space you have on your ext. drive. If you DO have enough to back-up your files,then i would suggest you right clicking on your ext. drive,choose properties and format it,but beware,formating will delete ALL your data on external drive.
If you think i was usefull,click on Thumbs up button,cheers!
Mar 07, 2011 | Western Digital Elements powered by WD 320...
External Hard Drive not Accessible after Windows Vista Update
Assuming that the external hdd is physically working fine, everything is pointing to a damaged boot sector.
You can get back most (if not all) your data stored in your external drive with the help of an application called: Pc Inspector File recovery.
Its a freeware.
Here is the link: http://pcinspector.de/Sites/file_recovery/download.htm?language=1#
Simply install it on your C:\ drive, and follow the prompts.
Please let us know the outcome.
Don't forget to rate this answer if it helps
Dec 12, 2009 | Maxtor Hard Drive
I can't download a world of warcraft game cause it says not
Go to control panel, add/remove programs and remove all programs that you do not use, such as free trials, etc. Once you have removed them, reboot computer and you should be good to go. You need to free up space on your hard drive to install additional software and this is the easiest way to do it. You can see how much space is on your hard drive by going to my computer and right clicking on C: and then choosing properties. The picture will tell you how much space is being used. If you have allot of music on your computer, you can burn them to CD and then delete from computer as these hog allot of space on computer.
Sep 13, 2009 | Video Game Consoles & Games
I have a Sony Vaio PCG-FRV26 series laptop that has just started shutting itself down and restarting after windows has been up for only a minute or two. I have taken the unit apart & cleaned everything...
The main drive (C) being too full is an indicator that's your problem. Windows reserves space on your drive called a 'swap' file. It effectively takes hard drive space and uses it in lieu of RAM if you don't have enough available RAM to run programs.
If the computer doesn't have enough hard drive space to create the swap file then it won't boot up, as it will interpret the lack of available space as a failure to install the file and then try to reboot.
Luckily it doesn't install one when you're in safe mode. Try going into safe mode and restoring some of your hard driver space, as well as performing a cleanup and defragmentation of your hard drive, and chances are it will boot up.
As an alternative you might think about getting an external hard drive and using that for any new programs/music/videos/etc.
Sep 04, 2009 | Sony Computers & Internet
No sound,please help!!
try to download the sound driver from here  http://74.125.153.132/search?q=cache:http://www.sis.com/products/sis661fx_benefits.htm  . if it fails again then try to install windows xp with sp2 not sp3 ok.
Jun 14, 2009 | Abit SG-80DC Motherboard
Compaq Presario R3000 compatible bios?
I Think the latest bios update for R3000 is F.35. Sounds like you need to reinstall OS or buy a new HD
Nov 27, 2008 | Compaq Presario R3000 Notebook
How do i free up space on my start up disk?
your problem is the space is it?i think on top of moving your itune library u should move all other less important files to any external storage and see whether this will solve the problem.
Sep 05, 2006 | Smartdisk - Peripherals - HARD DRIVE,...
Compaq Presario sr1111nx 2.53GHz Celeron Computer (SR1111NXRB) PC Desktop Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
