Question about Tecnik Washing Machines
Hi we have purchased an integrated washing machine Tecnik 3TT102GB but we donot have the user manual. The washing machine seems to stop soon after it starts with all lights flashing, I press start/pause and then it resumes, BUT - the water doesn't fill, it seems to trickle in but must be draining out at the same time, it doesn't heat the water, it won't go through any complete cycles. We are just back off holiday with mountains of washing - please help
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Posted on Feb 27, 2008
  • 17 Answers
SOURCE: our washing machine (Zanussi ZWF 1632 W) flashes 5 times
This is a motor problem the end light flashing 5 times indicates error E50. The motor has either got wet or has just failed i would suggest trying to dry it 1st but i would suspect the motor has gone down to earth usually having to replace it. The part no. DST1246179079 Motor aprox £195 but shop around you may find it cheeper.
Posted on Dec 17, 2008
  • 61 Answers
SOURCE: water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Posted on Jan 20, 2009
  • 236 Answers
SOURCE: Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
Posted on Mar 16, 2009
Need a user manual for used LG washing machine/dryer WD-1480RD..
Hi Johanna
Try Here
Product Support ManualsOnline com
Use your Search Engine for different terms
PDF
User Guide
etc
Mar 16, 2016 | LG Washing Machines
Dimensions for tecnik 795/2
This dishwasher was made for tecnik (moben/kitchens direct) by bosch. Any Bosch, Siemens or Neff fully integrated 600mm dishwasher will replace this machine.
Apr 08, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Please may I have a Washing Machine manual for TKL9260
Free tech support for Tecnik TKL9260 Front Load Washer and help with Tecnik TKL9260 ... Where can I find a manual to download for this machine please. www.fixya.com/support/p31758-tecnik_tkl9260_front_load_washer www.fixya.com/support/p31758-tecnik_tkl9260_front_load_washer
Jan 26, 2012 | Tecnik TKL9260 Front Load Washer
Where can I get replacement integrated door hinges for Teknik 9060
we have a shop in stirchley birmingham that sells new and used parts for allwashing machines and tuble dryers if you go online you may be able to find a place near you or go on tecnik web and search for the part.
Jan 02, 2012 | Tecnik SLR 650 Washing Machines
Does anyone know where can I buy a new belt for my Tecnik tkl 9260 washing maching? Tecnik customer service won't pick up the phone and Spares2go seem to think this appliance has too different belts...
Your washing machine only has one belt. The reason for the two different part numbers is that the original part (1192J5) is no longer manufactured/available. 1185J5E is the replacement part number which is fully compatible with your machine. An appliance spares supplier should have been able to tell you this.
You can order using either part number - some suppliers will have the part listed under both numbers, others may still have stock of the original 1192J5 part.
I generally use UK Whitegoods for appliance spare parts as their prices are good, they deliver quickly and if you need any advice on ordering the correct part, you will get the right information:
Your belt: http://shop.ukwhitegoods.co.uk/Washing+Machine+Parts/White+Westinghouse/White+Westinghouse+Drive+Belts/36060200+Washing+Machine+Drive+Belt.html
Home page: http://www.ukwhitegoods.co.uk
Parts enquiry: http://shop.ukwhitegoods.co.uk/contact_us.php
Hope this helps!
Regards,
BElectric
Nov 25, 2010 | Tecnik TKL9260 Front Load Washer
Washing Machine won't spin
Could be worn carbon brushes, or possibly defective shock absorbers
Mar 26, 2017 | Tecnik TKL9290 Front Load Washer / Dryer
Tecnik tlk 925 washing machine not spinning
sounds to me like your carbon brushes have worn down if they wear down too far they will hit the metal casing that explains the grinding noise
Aug 08, 2008 | Tecnik TKL9260 Front Load Washer
Washing machine keeps stopping at the beginning of a cycle
If you leave it on its own, how long/will it ever, advance on its own?
Nov 05, 2007 | Tecnik TKL9290 Front Load Washer / Dryer
I need the Manual for the Tecnik TKC 1285 Dual Fuel Kitchen
Here is the site for Technik: http://www.tecnik.net/aftersales.htm Did you ever find the manual? Can I have a copy?!?
Jun 14, 2007 | Tecnik TKC1285 Dual Fuel (Electric and...
Washing Machines Logo
85 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
