Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
My pc is not detecting my flash,i think its corrupt.
    Genius:
  • 1,121 Answers
Format-it
Posted on Aug 08, 2010
Every tym i insert my pendrive it says insert disk into the drive...???removable disk appears..but it doesnt opns...is there any solution...plz do help me
Assumption 1
Flash drive is damaged, the normal operating system.
Solution
If the flash drive is detected (eg; detected the flash drive in drive G), but it says "insert the disk into the drive ..."
1. Download software JetFlash Online Recovery (open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download).
2. Insert the flash drive
3. Open file OnLineRecovery.exe - Select the volume of the device - Repair the drive & keep data existed - START. If it fails, select Repair the drive & erase all data - START.
If the flash drive is not detected (not detected as drive G),
the above solution can not be used.
Assumption 2
Normal flash drive, the operating sytem is corrupt
Solution
Flash drives do not require drivers (plug and play). Because flash drives plug and play, it should be, when the flash drive inserted detects the operating system without installing drivers. But, if the operating system does not detect, the possibility of operating systems corupt. The cause is a virus corrupt your operating system.
1. Download and install anti-virus Avira or AVG (free).
2. Update anti-virus
3. Scan your computer.
4. Repair the operating system.
5. If no virus is detected, the possibility of operating system is corrupt.
I hope this information helps.
Oct 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Tip
Broken Flash Drive ? , Flash Drive not working ? Dont trash it just yet.
Many people believe that when a flash drive stops working , you can throw it in the trash...this is however a expensive mistake to make as about 30% of drives can be repaired.
There are basically 3 causes for a flash drive to stop working.
  1. Partition is corrupted
  2. Broken electrical contact inside the drive
  3. Memory module is blown (no repairs possible)
#1 Partition is corrupted
If your flash drive's partition is corrupted you will not be able to access it. To fix this , do the following.
Go to My Computer
Right click on the flash drive
Select Format
Check the Quick Format option
Select Start
After the format is completed , test the drive. If it disappears or was never present to begin with , but windows detected when it was plugged in , try re-assigning the drive letter for the flash drive.
If you do not know how to do this , please follow the steps in the following tip i wrote : How to change a drive letter.
If the drive is not present in the disk management window , proceed to step 2.
#2 Broken electrical contact inside the drive
If the drive does not detect on your pc , this might be the cause.
What you need :
  1. Soldering Iron and Solder
  2. Magnifying Glass (Optional)
  3. Desk Lamp
  4. Superglue
Open the cover of your flash drive. This is normally done by pulling the two parts apart. Then have a look at where the USB is soldered onto the PC board. There will be four metal contacts soldered onto the board.
This is normally where a electrical fault will occur.
If you find one of the contacts are broken , simply solder it back into place and glue the cover of your drive back on.
If these steps fail to fix your flash , you can dump it in the trash with confidence that its dead.
Please rate this solution if you found it helpful.
Kind Regards
Stephan
on Feb 24, 2010 | Computers & Internet
Flashdrive not detected by any computers
your USB flash drive is corrupted and faulty and wont work on any computer, only solution is to replace it. as flash drives cant be repaired
Jul 13, 2011 | Computers & Internet
Five beep in Hp compaq 530
1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
Apr 21, 2011 | HP Compaq Business d530 Ultra-Slim PC...
It will be not detected,when attached 2 system it shows hard not working properly problem in ip driver
I Think you may have a virus on it or some form of corruption, if possibile right click on it and run a scan for errors and a virus scan. If not Go to sanDisk site and update/reload driver launcher.
Jan 06, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My system didn't regonize the flash drive
If it in't detecting the flash drive.....Then the driver must have been corrupted....so just uninstall unknown device....and try to connect te flash drive
Mar 15, 2009 | Acer Aspire T120 PC Desktop
Please Help
Most likely, i think you might have a bad flash drive, or the drivers has been corrupted. Try cleaning your system drivers and use a program like DriverMax. It is free, just register and download the program, then, clear all your drivers and put in the flash drive again.
See if it works.
Jul 21, 2008 | Clone (CWH-600S) PC Desktop
Flash
i think the firmware is corrupted ..... you must install new firmware ....
just visit the nearby showroom or technician he will install the new firmware ..........
for installing firmware it may costs some 300 to 400 bugs ....
how ever there may be other problems too may be the battery is dead just change battery and check....
check whether it is detecting in pc or not..........
Feb 11, 2008 | Cameras
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
63 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Alun Cox
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
