Question about Nokia N79 Cellular Phone
Mobile keypad hang - Nokia N79 Cellular Phone
Hanged and off
Try pulling the battery out and put it in carefully, make sure everything is lined up right. If that doesn't work, try plugging in the charger and leave it for an hour.
Apr 19, 2014 | Nokia 3110 Cellular Phone
KEYPAD IS HANGING
May be your keypad ic or your OS (Operating System) of your cell phone has been corrupted. Which means your phone memory has low space. And could not be loaded. So please refer to the nearest mobile service centre for repairing.
Thanks for Using FixYa!
All the Best
Aug 30, 2012 | LG Cell Phones
On my n79 the camera automatically turns on and off randomly and even the keylock get unlocked automatically and randomly every second,the phone get hanged up as the mobile screen turns even when the...
There may be some oxide coating below the keypads, try to open the keypad and dome-sheet beneath and clean the contacts.
Hope this will find a solution for your keypad issues.
Jul 20, 2017 | Nokia N79 Cellular Phone
My Mobile God Hang.Keypad Not Working
My Dear Your Phone Keypad IC Fault SO Please change Keypad IC
And Key pad Problem will Solved
Oct 08, 2010 | Nokia 5310 Cellular Phone
ON SWITCHING ON THE MOBILE IT IS DISPLAYING RANDOMLY DIGIT 6 WHICH IS NOT PRESSED BY ME. THIS HANGS MY MOBILE 2626 NOKIA
Please take it apart using six sided (small for nokia mobiles) screwdriver, remove the cabinet and Switch it on whether the same problem persists or not. If the problems still persists, the you can check the keypad with the number 6. It must be stuck, you can remove the tape which is covers the keypads, and check it. To find the key no. 6, refer to the keypad and take action with the corresponding key. Do whatever is needed like cleaning, removing etc.. and again switch on before you close (fit) the cabinet. If it's ok, you can fix the screws and the cabinet (housing/case). If there's is nothing wrong with the key, then there're must be internal problem. You better go to a mobile repairing shop and get it repaired. In case the problem goes away, then replace your cabinet. It's the problem with your case, perhaps it might have been broken somewhere. Good luck. Thanks for using FixYa.
Jun 01, 2010 | Nokia 2600
Buttons(keypad) are not working?
I thinh its keypad ic is damaged or may be you have flash it by some mobile expert in case of hang fault
May 22, 2010 | O2 Xda Atom Exec Smartphone
My nokia 3110c mobile hanging when i satrt the mobile
Check the keypad for stuck, Or reinstall software with Nokia software Updater
Jun 09, 2009 | Nokia 3110 Cellular Phone
Moto w30 keypad not working
buy a new phone. your phone is buggered
Jul 03, 2008 | Cell Phones
Nokia N79 Cellular Phone Logo
140 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
