Question about HP PSC 2210 All-In-One InkJet Printer
Printer won't turn on
My printer just all of a sudden stopped working. I didn't drop it or anything. Today I realized that it was turned off (and I usually just leave it on) and when I went to turn it on, nothing happened. I pressed the on button and used different outlets and it still wouldn't turn on. I know that there is power going through the cord because the printer is warm on the right side but I just won't turn on. Any ideas
  • paker989 Apr 27, 2008
    how do you get access to the PC board because i think that might be it
  • 975 Answers
Lets start with the AC power supply ,with a multimeter check for correct voltage , next step is to check inside the PC BOARD for a blown fuse , if so , replace , and try again unit . hope this helps
Posted on Apr 27, 2008
Unfortunately the process android process acore has stopped
I know it might sound reasonable but a lot of times if you remove the battery for 5+ seconds or so.Replace the battery and turn the phone back on. It might reboot up right you have nothing to loose
Aug 12, 2017 | HTC Sensation Cellular Phone with Sense...
My iPhone 4 is a few months old and last night it suddenly stopped charging. Of course i didn't realize it until my phone died during the day today and i tried plugging it in and wouldn't ch
The charge adapter maybe faulty.
If your cell phone is a few months old, then it would be still under warranty. Take it back to the place where you purchased it and have it repaired or replaced under warranty.
Jul 26, 2012 | Apple iPhone Smartphone
I've been using OKIDATE MICROLINE 320 PRINTER at work. I was printing something and I realized that I was printing the wrong page so to stop printing, I simply turned off the power and waited....
You would have to cancel the current print job from your computer for it to stop. Assuming you have access to a computer that is connected to that printer, you will have to find that printer by going to Control Panel > Printers and Faxes > Oki ML 320 then right click, select "See What's Printing" and cancel Current print job (I am also assuming you are using windows). I really hope this helps, if not add a comment clarifying your question, thanks.
May 23, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
1993 Toyota Paseo - Engine dies when clutch depressed
Absolutly, Your idle control valve at the end of your fuel rail has a vacuum line and its sensitive to pressure changes. One way to double check that would be to hook everything up normally and pull that vacuum line off your idle control valve. Are the symptoms the same?
Jun 04, 2009 | 1993 Toyota Paseo
I have one PIXMA MP150 with proble paper jam message, and I could not find any jammed paper inside,how shouls I do to make this printer available?
GGONG644, Try this fix. TURN OFF PRINTER wait ( 10 or 15 seconds) turn it back ON and listen for
paper ROLLERS to be turning and FORCE FEED A single sheet of paper through print rollers until it PULLS it through the printer and SEE if a scrap of paper comes out with sheet ? Let me know if this works ? Phil at palcando@yahoo.com
GOOD LUCK !!
Apr 29, 2009 | Canon PIXMA MP150 All-In-One InkJet...
"Incorrect Color Cartridge Installed"
You can just click the print button and the printing will begin, I was having the same problem.
Apr 05, 2009 | HP PSC 750xi All-In-One InkJet Printer
Hpdeskjet 940c printer
If the Power light is not illuminated, first check the power cable to ensure all connections are correct. Next, turn off the printer, then turn it on again. If the Power light does not become illuminated, the printer needs to be serviced. I believe if this doesn't work you have a bad power supply.
Jan 08, 2008 | HP DeskJet 940c InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
88 people viewed this question
Seeker5211
Seeker5211
