Question about Dishwashers
My westinghouse dishwasher goes through all the cycles but the dishes do not dry enough.
I found the answer to my questions on another website at no charge
Posted on Apr 28, 2008
Hi, my westinghouse wsf6605xr dishwasher is not drying dishes. Any ideas?
The heating element may be burned out, pull it out and test it for continuity of the coil.
Feb 23, 2017 | Westinghouse Dishwashers
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon
Sep 07, 2011 | Westinghouse Dishwashers
Drying problems
Check the front control panel for a AIR DRY / HEAT DRY switch. Perhaps the switch is in the AIR DRY position. If so and you really want to HEAT DRY your dishes, set the switch for HEAT DRY.
Second, it is not a bad thing to let your dishes AIR DRY. It saves money! Just open the Dish Washer door after the last rinse cycle has finished and let the dishes AIR DRY manually. In a hour or so they can usually be put away.
You can also check for the heating element.Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thank you!
May 14, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
The water does not heat up and the dishes do not dry
A dishwashermag-glass_10x10.gif that suddenly stops going through the cycles or never completely dry dishes probably has a faulty thermostat. The thermostat controls the heating elements for water and drying. If the thermostat is stuck, the dishwasher won't go to the next cycle because the minimum water temperature requirement is never met. Drying dishes also requires the temperature to get high enough to do the job.
  1. Step 1 Remove the front plate of the dishwasher and locate the thermostat. If the thermostat is not located in the front of the unit pull the dishwasher out and remove the back access panel.
  2. Step 2 Disconnect any wires or other parts that are in the way. Separate the wires with a flat blade screwdriver carefully to keep the wires from breaking.
  3. Step 3 Take out the screws attaching the thermostat to the firewall and remove it from the dishwasher. Verify the replacement part matches the original, including the wire connector.
  4. Step 4 Place the new thermostat into place and secure it with the screws. Connect the wires and replace any parts or cables. Attach the front or back plate and replace any molding.
  5. Step 5 Run a hot water cycle and verify the water is heating and the cycle is able to complete. Check the drying cycle and prepare the first load of dishes.
Nov 15, 2009 | Dishwashers
Model # dwu7702aae has heat delay light coming on during cycle. Why?
Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
Feb 22, 2009 | Maytag Dishwashers
The dishes don't get dry enough
I was able to fix this by using rinse during the cycle.
Nov 11, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Doesnt dry dishes
The heater on this unit only comes on twice, once in the wash cycle, and again in the Sanitary rinse. During the drying cycle all that happens is a vent opens and a fan comes on. The fan removes the hot moist air from the unit and the dishes dry off. If your water is not hot enough, this is why your dishes are still wet. Rinse aid also helps to sheen off the excess water as well.
Sgt 48
May 06, 2008 | LG 24 in. LDF7810 Built-in Dishwasher
HElp Dishes not coming clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Dishwashers Logo
60 people viewed this question
Top Dishwashers Experts
