Question about Memorex (32025541) 25 Pack 4x DVD+RW Storage Media
Sony Precision Drive 3 DVD+RW
When I burn TV shows from iTunes onto my blank DVD, it will not play in my supposedly compatible DVD player...help!!
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
If you are using RW media, that could very likely be the source of the problem. Here are detailed instructions on how to determine or confirm the source of the problem.
http://docs.info.apple.com/article.html?path=iDVD/7.0/en/6669.html
After completing these steps, if it is caused by the DVD+RW media, re-record them on regular DVDs, and assuming your player will accept that media, they should play appropriately. Let me know if you need additional assistance, but thanks for rating FixYa!
Posted on May 03, 2008
I have had to replace my hard drive on my pc how can i get my music back on to pc from my ipod and back into i tunes
Backing up your iTunes library to a CD or DVD To burn a CD (CD-R or CD-RW), your computer must have a compatible CD burner. To burn a DVD (DVD-R or DVD-RW), your computer must have a compatible DVD burner. Check in iTunes Preferences to see if a drive is compatible. See below for steps.
To create your backup disc
  1. Choose File > Library > Back up to Disc.
  2. Select the option you want from the resulting dialog and click Back Up.
  3. The two options you can select from are:
    • Back up entire iTunes library and playlists
    • Back up only iTunes Store purchases
    Whichever of these two options you choose, note that you can also choose "Only back up items added or changed since last backup" to perform an incremental backup.
  4. Insert a blank disc (CD or DVD) into your computer's optical drive. iTunes will scan the disc and begin burning.
  5. Note: If the disc you insert does not have enough space to hold all of the content you will be backing up, a dialog will appear asking whether you wish to backup to multiple discs. You can click Data Discs to continue.
iTunes burns the number of items that fit on one disc and then asks you to insert subsequent discs to continue burning the remaining files. Don't eject a disc while a backup is in progress.
Spoken programs purchased from the Audible.com website are not backed up.
Discs you create using the iTunes backup feature can be used only to restore; they can't be played in a CD or DVD player.
Restoring from a backup disc
  1. Open iTunes.
  2. Insert your backup disc.
  3. iTunes will ask whether you want to restore from this disc. Click Restore.
Check drive compatibility
  1. Choose a playlist on the left side of the iTunes window.
  2. Click the Burn Disc button on the bottom right corner of iTunes.
  3. If the drive is listed, it's compatible.
Aug 16, 2010 | Apple iTunes
Sony DRU510A, will burn CD fine, but not DVD, will play DVD
Same thing is happening to me. Does anyone know of a solution to this problem?
Feb 06, 2010 | Sony DRU 510A DVD±RW Burner
Anyone know how to copy movies I purchased on itunes onto dvd so I can pop um in the dvd player?
HI,
Purchase Tunebite software. You may also download it, but will onlyreceive the first thirty seconds of video as a trial. Completeinstallation wizard, which can take several minutes.
Launch Tunebite software and click on the "Add" button. This process will allow you to load your iPodmag-glass_10x10.gif video library into Tunebite.
Click on "Convert Files" tab and place cursor over "Convert File to"drop down bar. Select WMV7 (1024kbps). Select "Start" to beginconversion process. The Digital Rights Management copyright is nowsuccessfully removed.
Download Aimersoft DVD Creator. Run and launch software. Simply click "Load Video" and drag videos onto storyboard.
Click "Burn". Select the "To DVD" option and adjust settings to NTSCfor television viewing. Insert a blank DVD-R/RW disc into DVDrecordable drive and record.
Jan 23, 2010 | Apple iTunes
Discs will not play back on dvd
What DVD's are you using +R/RW -R/RW some formats may not work especially on non-branded media some DVD players wont even play CD-R but will play some CD-RW of the correct brand.
I suggest that you try your finalized DVD in your PC then create an image using ImageBurn then burn the image onto a branded media and try again. Most firmware on DVD burners are very forgiving and will support a wider range of manufacturers and formats.
Hope this helps, you might want to look on your DVD players website for updated firmware you will need a blank CD and create a update disc using your computer.
Oct 18, 2009 | Sony DCR-DVD91E DVD Camcorder
I can't get my cd's I recorded on my sony dvd player
Check file extensions of files on your recorded cd's. Add file extension to Roxio, Windows Media player and check your drive settings.
Apr 22, 2009 | Sony DRU840A DVD-RAM Burner
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Ps3 was playing movies i had burned to disk now it wont
The best way to play burned movies is to copy them onto a memory stick or external hard drive then copy them onto the ps3 i use this method and find the movies play in much higher quality than dvd-r or+r or whatever discs you use
Jan 25, 2009 | Sony Playstation 3 (PS3) Console
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
LG LS50 DVD/CD-RW DRIVE won't recognize blank dvd-r
Yes does not read DVD-R because if your LS50 Labeled like this (DVD/CD-RW) means that can read only all DVD Disc and cannot write on DVD blank only CD blank.
You can burn only on the blank CD-RW or any blank CD.
Jan 17, 2008 | LG X-Note LM50 Notebook
Memorex (32025541) 25 Pack 4x DVD+RW Storage Media Logo
400 people viewed this question
Top Memorex Electronics - Others Experts
tdk1988
Are you a Memorex Electronics - Other Expert? Answer questions, earn points and help others
