Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
I am having trouble connecting my ps3 to my router can you help
  • 708 Answers
Connect Your router to a Computer(Wired)
Open Router Setup by typing 192.168.2.1 on the address bar of internet explorer
On the Left Click on firewall
Leave the password blank and click submit
Disable it and click apply changes
Scan and connect in PS3
Make a note of the IP Address in the PS3
On the Left Under Firewall Click DMZ
Give the IP Address of the PS3 in it
Click Apply Changes
Now test the connection
Let me know if it works at
http://belkinrouters.blogspot.com
Posted on Aug 12, 2010
Im having trouble connecting my laptop to the wireless router, it shows on desktop but not on laptop nor the PS3?
Chances are you are using WPA2 encryption, the PS3 and laptop may not have compatible wireless interfaces.
Drop your encryption to WPA.
Jul 21, 2011 | Belkin F5D7234-4 Router
All of my computers connect to the internet but my ps3 wont
Let's try the simplest things first. Restart the PS3. Then try restarting your router (unplug/replug it in). Make sure all the cables are nice and snug where they should be in both your router and the PS3.
If going for a wired connection, confirm that the cable to and port/cable slot on your router are good (try another cable and cable slot). If going for a wireless connection, confirm that other devices can access your router wirelessly.
Still having trouble? Check your internet settings on the PS3. Navigate to XMB > Settings > Network Settings > Internet Connection Settings. Run through it, selecting Automatic or Auto-Detect whenever possible. If that didn't work try setting it up manually. Here's a guide explaining each option of the manual set up process.
Hope this helps!
Mar 24, 2011 | Sony Playstation 3 (PS3) Console
Im having trouble connecting my xbox 360 to wireless but my computer has no problem connecting. can you help me?
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
Jan 10, 2011 | Belkin (F5D7231-4) Wireless Router
Trouble connecting to the Playstation Network or
check for the correct ssid and pws from router
and try again if questions try your is tech its free
Apr 28, 2010 | Sony Playstation 3 (PS3) Console
Server conection timed out (80028e06)
Can you access the internet with a computer still?
Try rebooting the PS3 and the router. Reboot the router first, wait a few minutes, then reboot the PS3.
Which firmware version are you running?
Apr 03, 2010 | Sony Playstation 3 (PS3) Console
My ps3 would connect to the internet
Try connecting to your router with a cable and see if that is able to get you online.
If it does, then 9/10 its a signal problem.
If it doesn't, then you have a settings problem.
Also, is your router close enough to the ps3 to supply sufficient signal to the console? From my experience, the router needs to be pretty close to the ps3 for it to get a good signal or if you have a wireless N type router. Wireless b/g routers usually need to be very close to their source for it to be fully effective as the ps3 requires.
Apr 16, 2009 | Sony Playstation 3 (PS3) Console
How do i change my NAT connection from moderate to open
This one is simple. Find the IP address that your Xbox is assigned by your router, then put it into the DMZ. This also goes for PS3 users who are having trouble with internet access.
Feb 10, 2009 | Linksys WRT160N Wireless Router
Playstation Network timed out
try moving ur ps3 closer 2 ur router dat should make da connection stronger. but another thing is wen da internet router is used by too many appliances certain ones for example ur ps3's internet becomes weaker. i hope dis helped=)
Jan 20, 2009 | Sony Playstation 3 (PS3) Console
Cant connect ps3 wireless to dlink router
The router should assign an IP address to your PS3 if it isn't manually configured. If you are connecting wirelessly make sure your security setting on your PS3 match your router. If the problem persists disable wireless security on your router and then try to connect with the PS3 with security disabled as well. Sometimes consoles have trouble connecting with WEP or WPA security encryption.
Jan 06, 2009 | D-Link AirPlus DI-524 Wireless Router
PS3 Trouble due to WEP/WPA-PSK Key trouble
You can always press the reset button and wipe all settings out. You will have to re-enter passwords and encryption to protect your network.
Dec 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
77 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
