Question about Ubi Soft Chessmaster 9000 for Windows
KEEPS ASKING FOR ORIG DISK. I HAVE LOADED THE ORIG. TWICE. WHAT IS THE PROBLEM?
    Novelist:
  • 105 Answers
Hi, Chessmaster 9000 needs the disc to be always in your computer in order to be played. If for example you just install the game then you remove the disc, it'll ask always for the disc to be inserted. If you need more help just ask.
Regards, Peter
Posted on Aug 08, 2010
  • louperlman Sep 11, 2011
    I don't have peter's problem. Mine is that Chessmaster 9000
    no longer shows the Thinking Lines, which is a big
    miss
The but does not help. every disk I load says samething even orig disk. Even put recorded on this player. Still says loading and then no disk. Any help appreciated.
Get yourself a cleaning disk from Walmart or an audio or computer retailer. Sometimes the optics get dusty and can't read the start of the disk. They are not expensive and worth a shot.
Sep 19, 2015 | Sansui VRDVD4005 DVD Player/VCR
Dell inspiron 1720 vista admin password recovery?
If you are running Windows 7, if you type in the wrong password once, it normally says reset password... below the box for the password. Insert a removable disk (such as USB, floppy disk, etc.)
and follow the prompts.
Oct 25, 2013 | Computers & Internet
Hi, My dad passed on his Old laptop for my 7yr old to use for homework. I would like to restore to factory settings and can not. I have tried the thinkpad button as well as f11 to no avail. System
the system is not design to return to its orig.form or program ,unless you you format it using the format they used.you can used a formatted hardisk to replaced the orig.disk .or try the latest operating system that fits the requirement of your laptop.
Apr 12, 2013 | IBM ThinkPad Computers & Internet
My e machine e525 keeps crashing. Windows 7 is loaded. Please help
If the OS keeps on crashing, it may be due to the issue with the Hard disk. If the system is still under warranty then you can ask them to replace the Hard disk stating that it keeps on crashing.
Or if the machine is old, then you can buy a new hard disk and replace it with the old one...
It should work...!
Plz comment back for any queries...
Cheers... :)
Jul 20, 2011 | Acer Computers & Internet
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
I'm trying to recover from Backup Disks made when i first got the computer, I've inserted Factory Default disks 1 + 2. Now its asking for the next Disk. Question 1: What is the next Disk to insert?...
The recovery disk consist of 2 DVD, the first is the System Disk (this is first disk to insert), once finished loading, it will ask to insert the second CD (Application and Drivers disk), if in case both are not working, then follow the below mentioned steps:
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
You can also place order for a set of Recovery disk by calling Acer Technical support at 1 800 816 2237
Thanks and regards,
Jitha
Jan 19, 2011 | Acer Computers & Internet
Cd player does not work
While holding 1&6 pushed ,press disc 3 times .
check will be displayed on the radio screen then press & hold N° 5 for 3 sec.
Then CLR will be displayed .
Now check if your disk works!
Oct 04, 2008 | 1997 Toyota Corolla
Loading disk
ill sugest u to talk to manu tech cause they can tsake access of ur computer and can pin point cause... a lots t/s needs to be done in this case
May 13, 2008 | Microsoft Windows Vista Ultimate Edition
The % of a discounted price
Lets say Your
MRP = 199
BESTSALE = 130
Now you want to calculate that howmuch percentage of BESTSALE i.e 130, will be added to get MRP i.e. 199.
If m right what do you want, then use the following formula:
Percentage = ((MRP/BESTSALE) - 1) x 100
In your case 199/130 = 1.5307....
So 1.5307 - 1 = 0.5307
Then 0.5307 x 100 = 53.07 %
Thanks
Iqbal
Mar 10, 2008 | Office Equipment & Supplies
Ubi Soft Chessmaster 9000 for Windows Logo
192 people viewed this question
Top Ubi Soft Video Game Consoles & Games Experts
dante
Tom Chichester
MegaByteMe
MegaByteMe
Are you an Ubi Soft Video Game Console and Game Expert? Answer questions, earn points and help others
