Question about Kenwood KRF-X9060D Receiver
While listening to DVD audio through the Amp, the audio muted with no selection on the remote. The mute light was not lit. Turned the amp off and then back on, the audio returned for 30 seconds, and then was replaced with very loud hash (white noise). Turning amp off and then back on repeated the problem, normal sound for 30 seconds, then white noise. All audio inputs tested and the result was the same.
    Brigadier General:
  • 8,546 Answers
If I understand you correctly, you're listening to a DVD-A (high resolution audio) through the 5.1 analog inputs.
OTOH, if you're listening to a DTS soundtrack via a digital connection it will produce loud hash noise if played via analog means. You may have digital audio, stereo analog and 5.1 audio cables running from your DVD player to the receiver (I do). Look to see if the digital feed is dropping out. Three should be a light in the receiver to indicate 'digital'. The unit couldc be defaulting to analog stereo in the absence of a good digital bitstream.
Then you might want to look at the DVD player to make sure it isn't malfunctioning.
In this world of ripped portable music and earbuds it's nice to hear someone else appreciates high fidelity on DVD-A. Too bad the retail market for them and SACD died. I found dozens of them on eBay so at least I have a lot to listen to.
Posted on Aug 08, 2010
I have a JVC RX 554v Receiver when it's turned on I have no sound their is a mute auto light that's lit in the window....Tried changing the speaker wires with no results...
From the remote control only: Press MUTING to turn off the sound through all speakers and headphones connected. "MUTE" appears on the display and the volume turns off. To restore the sound, press MUTING again. Turning MASTER VOLUME or pressing VOLUME +/- also restores the sound.
Sep 01, 2011 | JVC RX-554V Receiver
I have an old Technics SA-GX300 receiver that works fine except that the screen indicates that muting is on (still produces volume but at much lower levels). I lost the remote to the receiver. Is there...
Reliance on the remote instead of walking across the room to touch the unit will not solve anything. On many receivers, Muting is cancelled if the volume knob is turned to a louder level. Try that.
There's a used original remote for $12 delivered on eBay right now.
http://cgi.ebay.com/Technics-RAK-SA301P-Audio-Remote-Tuner-TV-VCR-CD-/230644267386?pt=LH_DefaultDomain_0&hash=item35b378397a
Jul 08, 2011 | Technics SA-DX850 Receiver
Just picked up a Marantz SR-19, Everything looks like it works but I get No sound out of it. Unfortunately, there is NO remote and was wondering if there is a setting like Mute or a speaker select on the...
A Mute indicator would tell you if it was muted. Make sure no Tape or Multichannel Input are selected by mistake.
There are supposed to be jumpers across the Pre_Outs to Main In's in the back when you're NOT using external amps. You could substitute short RCA cables.
Jan 28, 2011 | Marantz SR-19 Receiver
Hi there, our amp is giving us very low sound output even when volume is turned up to maximum volume. We have been unable to find the remote and are wondering if the remote was turned right down would that...
I'd look at the front panel for the Mute Button and the Mute Indicator, but turn the volume down for any further investigations. If you can't hera the sound at 1/2 volume, it ain't there. No sense risking a sudden volume surge that will kill your speakers when you finally find the problem.
http://www.retrevo.com/support/Harman-Kardon-HK3270-Receivers-manual/id/386bh430/t/2/
Also check the T-Mon Indicator. If it;s on you have the Tape selcted for listening instead of a source.
Volume/Mute Indicator: This
indicator will glow green when the
HK3270 is turned on. Its position
will enable you to judge the relative
volume of the unit even when the
speakers are muted or turned off.
When the indicator is pointing
towards the left, at an "8 o'clock"
position, the volume is low; when
it is pointing to the right, as in a
"3 o'clock" position, the volume is
loud. When the unit has been muted,
pressing the Mute button ïâthe
indicator will flash
Dec 26, 2010 | Harman Kardon HK 3270
C/d plays no sound
are you running the audio through an amp?? if so, it sounds like you are using the antenna remote wire(solid blue) instead of the amp remote wire (blue/white stripe) to turn the amp on. when listening to cds the antenna remote turns off.
Apr 02, 2010 | Alpine CDA-7892 CD Player
I have lost audio output seemsto be muted
Usually Laptop comes with sound mute button on the first row of your laptop or by the side.check out for that button.
If you can'r find them then
For Windows Vista & 7
Click windows button (Lower left),select "Control Panel ", Select "sound" Click "Comunication" tab>Make sure you select "Reduce the volume of other sound by 80%"
For windows XP & 2000 & 2003
Click Start button (Lower left),select "Control Panel ", Select "sound and audio devices" and click "volume Tab" and untick "Mute"
Dec 20, 2009 | Toshiba Satellite A105 Notebook
No sound
hi! press the audio setting and set on the audio set on
Sep 08, 2009 | Jensen VM9020TS Car DVD Player
Direct TV remote code for yamaha rx-v463?
It is 30376. The trick to discovering, is to turn the receiver off, first. Then it will power on when you input mute/select 30376. Then you can program the DirecTV remote to adjust volume (in AV2 mode only or in all modes). However, it will only power up the receiver. It has to be turned off with the original remote or at the receiver itself.
Feb 09, 2009 | Yamaha RX-V463 Receiver
Blinking light on volume control
i have a same problem, but on a rx-v1070, worked fine for a long time and one day i just turned it on and boom light blinking and no sound, if i crank the volume to about 80-90% i get distorted sound, i think our amps are gone, checked the fuses and they seem ok. Most likely its the amp. This unit was around $1200 back in a day. And it still produces sounds better then many recievers in stores today, too bad it has no 5.1ch surround.anybody have a solution pls let me know, for now i have a weak pioneer with 5.1 but no power.
Dec 11, 2007 | Yamaha RX-V870 Receiver
Alpine pkg-1000
Hello alpine_freak, You can disconnect power from the unit and this will kill the power feed to the system memory (the memory that hold commands from the remote)Now if this does not work I have seen where the unit indicated mute as a response rather than an actuator of an event. This is rare but it does happen. What could cause this is if the audio pre-amp goes out or is turned off by the mute button and there is no sound the unit detects this and indicates a mute. This I hope is not what is happening here, because this is a design flaw, the mute should turn off the pre amp and indicate a mute condition because the mute button was pushed, not indicate mute because of a no-audio condition. As said try to remove power from the unit and if this does not work, I would suggest finding a shop on fixya to take or ship your unit to for repair
Aug 24, 2007 | Venturer PVS1950D Car DVD Player
Kenwood KRF-X9060D Receiver Logo
80 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
