Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Yellow Tint over picture...
Samsung HCN4226W 42 in. Rear Projection - I have had this TV for 5-6 years now, and while under the 4 year repair contract, it was repaired twice with convergence issues where the picture was badly distorted, they told us they replaced a few chips on a board, I assume this is the convergence board that most have issues with here...
The current problem is that there is a yellow tint over the hole viewing area, like an old movie, I have no "white" color at all... The adjustments (ie: tint,color,brightness,sharpness) don't seem to do anything... All the convergence colors are aligned... perfect focus button comes up with a message after a few seconds "no sensor data"... I do have a slight curve along the left side of the screen (1"- 2" wide)... None of the preset color setting (ie: warm,cool,etc...) correct the issue... THANK YOU !...
  • 3 more comments
  • bandi42 May 03, 2008
    Also, Is there a PDF type manual on this TV, to show what each of the adjustments service mode do... I did find a write up that gives me some help, but just not enough detail, I guess I could give it a try, and always use the reset to put it back... Still looking for an answer to my original post... Thanks Much !....
  • bandi42 May 10, 2008
    OK, I have some imgaes I will post up... the convergence looks to be fine, there are no real misaligned colors, just this yellow tint type problem... As I said earlier, there is not much difference in the adjustments (ie: tint,color,brightness,sharpness), I do get a slight difference in the brightness setting, and also in the contrast, but nothing else seems to effect the picture or helps correct the image... The images seem to show alot more yellow then it is to the eye, but it should give you an idea of what I am seeing... Thanks Again...
    Leroy...
    CLICK HERE for the 1600x1067 images of the screen...
    I know my 27" TUBE tv has a degause opion, but this is a projection TV and I don't believe it is the same... Thanks for the response...
    So the actual picture tubes (3 colors) are bad or worn out basically, and I am sure the cost of these make this not worth fixing I would assume and it's time to move on to a new TV ?... I thought I read that there were 2 chips on a board that go bad on this model, and I believe that was what the replaced the last 2 times it was serviced a few years ago... I know I am probally just reaching here... :(...
    Tech person, depends on your meaning, I can pretty much fix anything or at least try, from building car engines to computers, and also can solder well, some board connections, wiring... Jack of all trades, master of none... But I am capable of it, if I know what needs to be done... So with this, I am weighing my options really...
    As far as this Samsung, you feel it has reached it's life cycle and it's time to let er' go ?... I just did not want to put er' out to the curb, if it could be fixed simpley... Like I said, the picture is actually great, clear, and running at 1080i, but just has this issue...
    I appreciate your responses...
  • 477 Answers
Do you have a speaker next to it? you need to de-gauls it try taking a magnet touch the screen and while you pull it a way from the screen slowly make a circular motion out wards and you should see the colors swirl keep doing this until it is clearer. This happens to tv and computer monitors all the time you can also check to see it their is a reset feature in your menu sometime this will degauss the screen for you. hope this helps.
Posted on May 10, 2008
    Genius:
  • 3,587 Answers
Well..it's simple really...yellow is from a degrading video unit and system board..so, you'll find that it's high time for a major service situation.
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels May 10, 2008
    hmmm...on the degaussing...most sensitive electronics and digital equipment is NOT happy with magnets around control circuitry..
    as to the service manual, none to be found in online universe..
  • Patrick Michaels
    reaching is fine..but there is a life cycle to all higher end equipment..you could use it as a monitor, if the convergence/video signal issues are resolved..
    are you a tech person, or usually call service folk in?
  • Patrick Michaels
    thankya for using fixya
Samsung DLP TV- colors seem to mess up -Faces have green streaks
sounds like you are haveing an issue with th color wheel timing. either the color wheel is bad or the dmd board is bad.only way to know is to have a technician look at it.
Oct 22, 2007 | Samsung HCN4226W 42" Rear Projection...
Whats the life time of a lamp for a hd tv
these could go for along time or not soo long depending on how many hours is on it. if it spends all day and night on it might last 5 years.
Jun 21, 2010 | Samsung HCN4226W 42" Rear Projection...
Green Picture
Sounds like you are not getting a red in your feed. Have you check the feed into your tv or if the cables are having a problem?? check it and let me know........
May 27, 2010 | Samsung HCN4226W 42" Rear Projection...
Picture has blue at the bottom and yellow at the top. Double images and the station logo is in the wrong place
This tv have convergence problems.Tries website Tvrepairworld.com to buy the whole refurbish convergence board for the replacement.The Samsung/Akai used the same convergence board.
May 15, 2010 | Samsung HCN4226W 42" Rear Projection...
My tv sumsung hcn4226w 42 inch rear projection will not turn on
either the lamp is burned out or the ballast and power supply board need to be replaced. can call 1-800-samsung for nearest service center.
Dec 11, 2009 | Samsung HCN4226W 42" Rear Projection...
No color!
we had this exact same issue with our Samsung projection tv. We solved the problem (temporarily) by trading in the cable box for a new one. All colors worked for a while, now the red goes on and off at will... I think we may have had a problem with the cable box AND the tv. Maybe this will help?? Good luck!
Mar 11, 2009 | Samsung HCN4226W 42" Rear Projection...
TOSHIBA TV- HCN4226W convergence PROBLEM
I charge 285.00 at my shop ,so if you cannot fix it your self you are looking at repair anywhere from that price or more .You have 2 STK ics these are your convergence Chips .You would need to replace both of them.If you can solder you have it made.
Dec 17, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN2446W -- Yellow/Greenish tint all over screen
That model should be HCN4226W, right? Because the other don't come-up. Sounds like the mirror may have moved. It's mounted on the upper part of the back of the T.V. Should be flat against the back. Check that. Then see if all 3 tubes are lighting up. Also possable the fluid leaked out.....but not likely. These sets are fairly robust. Do you remember jarring it in the drive home?? Did you have it laying down when you moved it?
Dec 14, 2008 | Philips Magnavox 51MP392H Rear Projection...
Bowing screen
You have bad convergence ic's. You can take the convergence board out yourself and take the part to a repair man to have him replace the ic's. I've had it done twice on my tv, it cost about 200 bucks.
Nov 04, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
167 people viewed this question
Henry  Thomas
Henry Thomas
