Samsung p28 sometimes fails to boot then freezes
  • 119 Answers
My P28 bought off ebay did the same so i removed the ram cards and using a artist fine paintbrush brushed wd40(or q20 or any lubricant of this type)into the card slots onto the pins and replaced the memory.Next i removed the cpu cover and then 4 screws holding the cpu heatsink down and cleaned off the heatsink paste from the cpu and heatsink then replaced it with fresh paste and that seems to have worked and solved my problem.Out of intrest the paste was hard and tacky .
Posted on Jun 21, 2009
  • clint Jun 25, 2009
    Hi all
    Just a update,on doing everything i described the freezing on startup reared it's ugly head again.I stripped the laptop down to plastics and cleaned everything and soldered battery terminals and any joints that looked weak but the problem is still there.When it happend again i gave the laptop a light tap underneath around the fan vent and then started it up.It works perfect and when it freezes i repeat the procedure so i can assume it's the cpu joints on the circutboard that are dry jointed but on inspection i cant see any possible way of getting to them so it's live with the problem or sell the laptop if youre getting frustrated.Out of intrest the cpu socket is bolted onto the motherboard(above the fan vent at bottom of laptop) and causes that area to distort and with all the heat dry joints are ineviatable sadly on this lovely machine.
sorry i got to this post so late. you are indeed correct dry joints around the cpu socket (we get tons of these all with this exact problem), this is a well know fault (but you knew i would say that) and has been fixed in the past by reflowing the mainboard, anyhalf decent repair store should be able to arrange this.
sorry this is not much help.
Posted on Feb 09, 2010
Samsung N102SP doesn't boot
Sounds like a Ram or processor failure. Any beeps?
Take the battery out and pull the power. Wait 2 min and put the power back in and try to boot. That is a start.
Nov 16, 2013 | Samsung NP-N102SP 25.7 cm 10.1inch LED...
My computer has never worked right ever since I installed the Samsung SyncMaster B2030. It freezes at all kinds of different points in booting up -- sometimes never gets started, sometimes freezes at...
Did you install the monitor driver? Uninstall it? I work on 100 and 100's of monitors and I have never seen monitor to cause the problem since the monitor does not really talk back to the PC. Other monitor works fine with this PC for sure?
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 12, 2011 | Samsung B2030 LCD Monitor
Samsung P28 Laptop, The Bios fails to see the DVD drive
Try taking a brush dipped in alcohol and cleaing out the connector on the motherboard. Do the same with the connector on the drive. Make sure it is dry before putting the drive back in. Alcohol dries pretty fast just blow on it for a few seconds. If that doesn't help then you may have a motherboard problem. I would only suggest this if you are sure that the drive is good. My first suspect would be the drive.
Jan 07, 2010 | Computers & Internet
P28 laptop blue screen it starts up with the windows logo then shuts down
i have problem my laptop no work and i search laptop P28. i want buy model laptop P28. i need in changer block mainboard for loptop P28
If you can me help. please help me. i buy old laptop Samsung P28
hope you help me
Thank you
my e-mail:
Sep 24, 2009 | Samsung V25 XVC 2800 Notebook
Freeze and black screen after re-boot
Go into bios screen and set the settings to optimal default and save then try again. if this gives you no results try f8 at the windows starting screen and safe boot if this allows you to enter window in safe mode your problem is outdated drivers. try any old vga video card and again see if you can enter windows normaly. and remember do not get frustrated this is how we all learn how to fixya.
Sep 22, 2009 | Computers & Internet
Samsung P28 freezes or blue screens on startup
This laptop is kind of old to put much money into it. I'll have to assume that you're diagnosing an overheating problem - screen lock up. BSD's or blue screen of death is caused by drivers. Before going to all the trouble of diagnosing hardware do a Windows repair. This is part of the original CD. If this doesn't work then do an operating reinstall. This should clear up all possibility of a BSD. Now to the hardware. If your fan has failed then I suspect the CPU and/or the video chip. You can check solder connections around the power supply connector. Good luck
Jul 29, 2009 | Computers & Internet
Samsung p28 laptop will not boot up
Do you not have a Reoery disk with this machine?
Jun 22, 2007 | Samsung V25 XVC 2800 Notebook
Computers & Internet Logo
386 people viewed this question
David Payne
David Payne
