Rundll32.exe have trojan vundo virus among other things. Can't system restore. won't let me open anything or run anything, asks me what program i want to open it with, tons of spyware.computer totally hijacked! What can i do to fix this?
  • wied Jan 20, 2009
    if I openone type application it's straight goes to quick player
I have 2 errors userinit.exe rundll32.exe 0xc0000005 i need help
Posted on Aug 06, 2008
    Genius:
  • 2,785 Answers
Disable system restore then uninstall your antiviruse install avast 4.8 from avast.com and do a full scan also download spybot destroyer from majorgeeks .com
Posted on Apr 28, 2008
Error rundll32
at pc? more info? i think wrong section ^_^
What is rundll32.exe (rundll32.exe error)?
rundll32.exe (rundll32.exe error) Description: Rundll32.exe is a program which would have been on your pc since the day you purchased your pc. Always verify the exact disk location as many virus and spyware writers will attempt to fool you by using a similiar name or same name in a different location. This file is part of the Microsoft Windows operating system. Rundll32.exe will actually execute functions in DLLs. If you are deleting files on your computer as a spyware removal protection method, then note that this is a required system file. Note that rundll32.exe can also be running many different other DLL or EXE programs, so you may want to check the programs listed after it in your startup list also, as these may be executed by it. Rundll32.exeis considered safe and is not spyware, adware, or virus related and does not need to be removed.
rundll32.exe error: rundll32.exe error. Be sure to always double check your spelling if you are concerned about spyware, as often spyware will use a very similiar spelling of system processes or other common tasks. rundll32.exe error
Click here to remove rundll32.exe virus
remove rundll32.exe virus: Remove rundll32.exe virus. Remember that although many files are always in default file locations, some files can easily be moved to different locations or change names like many spyware, adware, or popup programs do. If you suspect you have spyware or adware, check to see if you see a similiar names stored elsewhere. It always helps to check your tasklist also to see what is currently running on your computer. You can always view the tasklist on your computer by pressing ctrl-alt-del to view your "task manager", and then click the "processes" tab. This will show you all tasks running on your computer. Dll files will NOT show on your computer tasklist, as dll files are actually part of other processes. You may see similiar program names running if spyware or adware is on your computer, for example, ati2evxx.exe may be slightly misspelled to keep you from finding it, or spyware and adware may be named very similiar to a system file. Make sure always check the location of tasks or processes if you are concerned.Remove rundll32.exe virus
rundll32.exe Common Path(s): This will be found in your windows\system32 folder. You will see it starting up programs like: RUNDLL32.EXE C:\WINNT\System32\NvCpl.dll,NvStartup
^_^
Apr 20, 2014 | Nokia Asha 201 Blue Unlocked Dual-Band GSM...
Tip
How do I fix rundll32.exe on Windows XP?
Rundll32.exe is an important process for the Windows operating system. The process rundll32.exe take the dll file and put their libraries in the system memory. Without this process, the computer should be unstable and very slow.<br /><br />The process runs from your system directory C: \ Windows \ system32. If it executes or runs from elsewhere is most likely a virus or a Trojan. You should scan your computer immediately with a virus scanner. Viruses using the name rundll32.exe are W32.Miroot.Worm. Backdoor.Lastdoor and Trojan.StartPage (among others).<br /><br /><span style="font-weight: bold;">Fix rundll32.exe</span><br /><br />If a virus, such as Netsky, destroys rundll32.exe or, if for any reason, your rundll32.exe is corrupt or is accidentally removed, you must do the following:<br /><br style="font-weight: bold;" /><span style="font-weight: bold;">Find rundll32.exe DC system</span><br /><br />Check if you find a copy of rundll32.exe in the folder C: \ Windows \ system32 \ dllcache or in C: \ Windows \ Service Pack Files \ i386. If yes, go ahead and copy rundll32.exe to the system directory C: \ Windows \ system32<br /><br />If you can not find a copy on your system, try to locate the file on your Windows installation disc. Finally, you just reinstall Windows. It would be time consuming, and you may lose all your data. So what would be the last resort.<br /><br /><span style="font-weight: bold;">First, run a system repair tool to fix rundll32.exe</span><br /><br />There are various tools on the Internet that scan, analyze and fix your computer. In addition to solving your rundll32.exe these tools to remove all registry errors, remove invalid shortcuts and duplicate files, repair DLL files, and remove the errors start-up and running.<br /><br />
on Mar 07, 2011 | Computers & Internet
Emachine will not run anything
Rundll32.exe errors typically occur in response to the inability of Windows to access an application, program or file as the result of a corrupted or missing DLL (Dynamic Link Library) file or in response to a rundll32.exe virus that has been designed to look like a normal Windows process.
Here are the easiest ways to fix rundll32.exe errors.
Click "Ctrl + Alt + Delete" on your computer's keyboard to open the Task Manager window.
Click the "Processes" tab and search for a rundll32.exe program.
If one is running and appears to be accessing a lot of your system's resources, click "End Process" as it is likely a malicious program and not a true Windows program.
Run software to seek out, detain and remove viruses, malware, spyware and adware. Often these malicious programs corrupt DLL files or cause them to be deleted or moved and, as mentioned, some rundll32.exe programs may in fact be viruses on your system.
Reboot your computer to update any changes you may have made recently to your files and programs.
Many programs and applications require a reboot for successful installation.
Uninstall a recently installed or changed program or application and then reinstall it using the default settings.
An installed program may not have loaded properly, an installation via the Internet may have been interrupted enough to create errors or the program may have a bug.
If you uninstalled a program and see a rundll32.exe error, reinstall the program and then uninstall once more.
Retain the services of a Microsoft certified technician, if all else fails, to review and fix your system's Registry.
Dec 01, 2013 | E-Machines Computers & Internet
Windows cannot find rundll32.exe
Are you getting a window that pops up asking you to select which program to open with when you click on anything? If so your program file associations have been changed by a virus or infection.
Try restoring them by running the programs from the link below. Run each one of them. Don't worry, they are safe, tried and tested many times to get things back in order.
http://www.dougknox.com/xp/file_assoc.htm
Apr 18, 2012 | Acer TravelMate 5740-6529 - Core i5 430M...
Cant get automatic updates from mirosoft.cant down load .cant find rundill 32 exe.cant find help suport .
What is rundll32.exe? Is rundll32.exe spyware or a virus?
This program is part of Windows, and is used to run program code in DLL files as if they were within the actual program. However, many viruses also use this name or similar ones. This file is also commonly used by spyware to launch its own malicious code.
Note: The rundll32.exe file is located in the folder C:\Windows\System32. In other cases, rundll32.exe is a virus, spyware, trojan or worm!
If you don't have this file in System32 then you have other problems. Possibly a virus is onboard.
Oct 06, 2010 | HP Computers & Internet
Everytime i try to open an application or anything, it says the file "rundll32.exe" is not a win32 file, how do i change
Hi hansomeone45
Maybe you have virus on your computer, and it has infected the file rundll32.exe and therefore you cannot use it.
You can try several things I explain here :
IF you have a backup copy of your hard disc´s you can restore from the backup copy.
You can try to system restore in at the : start- all programs- accessories- system accessories- system restore
or in : start- help and support- and there find "system restore"
System restore will roll back the computer as it was before (day, week, month ago).
You can reinstall the computer for the procedure please look here :
http://support.microsoft.com/kb/315341
You can read about the file here :
http://en.kioskea.net/contents/processus/rundll32-exe.php3
Or you can try to run this app :
http://www.rundll-exe.com/
OR
http://www.goarticles.com/cgi-bin/showa.cgi?C=1945037
Remember you can try to copy the file from another computer to your computer !
Hope that helps
Have a nice weekend
Please rate my answer
Sep 25, 2009 | Microsoft Windows XP Home Edition
How to fix rundll32.exe-Application Error The instruction at &quot;0x009a068f" referenced memory at ''0x009a068f''.The memory could not be ''written''.Click on OK to terminate the program Click on...
It all depends on where the file is located.
The rundll32.exe file is located in the folder C:\Windows\System32 is a system file . In other cases, rundll32.exe is a virus, spyware, trojan or worm! .
Jun 04, 2009 | Computers & Internet
System won't open programs and files
hi. its purely a virus problem that prompts u from performing some actions in ur system. visit filehippo.com website. download AVG anti virus latest version scan ur computer. the problem wil get solved.
Jan 20, 2009 | Toshiba Satellite A105 Notebook
Acer Laptop - virus
try to boot in safe mode. if it does not work :
try 2 get a norton antivirus on DVD/CD. 2008 or 2009 edition.
and auto start setup will detect the virus and remove it.
if it still not solves ur problem insert ur vista installation disk and autorun Vista setup will start. Format ur drive when setup asks you.
Jan 10, 2009 | Acer Computers & Internet
You may have to reinstall Explorer is corrupted !. If you have a virus protection is your system make sure it is updated then scan your whole computer.You may have a virus in your system as well
Oct 12, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
