Question about Dell OptiPlex GX270 PC Desktop
Two sets of warning beeps when booting
Tried to install a second hard drive and must have done something wrong because now when I turn on the computer I receive two sets of beeps 4 then 2. Anyone have an idea how to fix it so both drives work?
  • Anonymous May 08, 2008
    I INSTALLED SEAGATE 120G WHEN BOOTED INTO WINDOWS XP IT TAKES LONGER TIME TO ACCESS THE FOLDERS AND FILES WHEN I DOUBLE CLICK ON IT.
  • 667 Answers
Please tell me the make and model# of the drive you're installing and we'll get you fixed up. Thanks.
Posted on Apr 27, 2008
How do I make Dell 530s boot and load windows?
Are there any sets of audio 'beeps' that occur during startup? If you get anything other than a single beep during startup, it could indicate an error code for hardware failure detected during the POST phase of bootup.
If you have recovery or Windows installation CD's, try pressing F12, go to the bootup menu and try booting from the CD.
Look at the bootup menu and see if there is a hard drive as one of the options. If the hard drive is not there, or if you try to boot from the hard drive from that menu and you get error messages, that might indicate something wrong with the hard drive.
If you can boot from the CD, you may be able to use the Windows Recovery Manager to restore Windows on your hard drive, if the hard drive is working. There may also be a recovery partition on the drive that will allow you to recover Windows, but beware that files on the hard drive may be lost when you use the recovery partition.
If you have files on the hard drive you need to recover, you may be able to remove the hard drive, put it on an USB drive adapter, and use another PC to copy files off of the old drive, even if it cannot boot the old computer. After you have recovered your files, you can try the recovery partition or format the drive and use Windows install disks to restore Windows to the drive.
Apr 01, 2015 | Dell Computers & Internet
No sound device, just multimedia device after adding a new hard drive and Windows XP reinstall.
Are you booting in from one of 2 hard drives at start-up .. ie. do you have a dual-boot system?
If your sound works fine when using the original hard drive but not when you boot from the slave, then it sounds like a driver problem -in the slave. You'll need to download the sound drivers for XP/Slave.
I can't think of any reason why your computer should beep after you have opened and closed the case. I don't think it is anything to do with the case. It's more likely that there's a bad connection or fault (maybe you have the slave and master on the wrong cable) - or badly fitted RAM.
Count the error beeps - there is a pattern of long and short beeps. You can find a list of their meanings here:
http://www.pcstats.com/articleview.cfm?articleID=1223
Though having said that, I would hazard a guess that you've got the master/slave configuration wrong. If you have both hard drives on one cable (ide) the MASTER drive should be at the end of the cable.
Remember there's a primary master (c) and a secondary master - your dvd drive. A 2nd hard drive would be set up to be the primary SLAVE. You cannot have 2 'master' drives on the same cable or bus. That would cause an error beep ...
Nov 28, 2013 | Packard Bell iMedia Computers & Internet
Spins but makes a beeping sound and wont register.
Well, It sounds like there is something lodged in your Hardware drive...The beeping is probably a warning signal to tell you that it is not properly booting up...You should go to a Computer Repairman...
Jul 11, 2013 | Seagate FreeAgent GoFlex Desk 1TB USB 3.0...
How to format my hard drive in dos
Rita,
Most computer recovery disks will perform the formatting for you. (This depends on the Manufacturer and Model though...)
If you put the recovery disk into the computer CD/DVD Drive and restart the computer - to boot to the disk, it should launch the recovery process and warn you that the hard drive will be erased and all data will be lost. This warning step is the recovery disks way of informing you that it will format the drive.
To boot to the CD/DVD you will need to tell the computer to do that. When the computer first turns on, you should see a brief message at the very beginning of the boot up process. The message will say something like: "Press Del for Boot Device" or "Press F12 for Boot Menu" or something of this sort. If your recovery disk is in the drive and you can get to the boot menu by pressing the key the computer prompts you to press, then you should be able to start up with that recovery disk.
Allowing the recovery disk to run through it's full process should format the hard drive and set your computer straight.
Make sure to run all of your updates once the recovery is complete and also make sure to install and update a good anti-virus software of some sort.
Nov 19, 2011 | Computers & Internet
Acer 3100 keeps saying media test failure chjeck cable
The BIOS, the control program built into the motherboard, is set to try booting from devices in a certain order when the power comes on. Most computers are set to try the optical drive first, possibly a USB device next, then the hard drive, and finally to try booting over a network connection. The error message you're seeing is because it's tried the network boot without success, and is telling you that maybe you have a bad connection.
What this all means is that the hard drive isn't being detected, or something has happened to your WIndows installation. It may be that the hard drive has worked loose from its connector, or has developed a hardware failure. There may be some problem on the motherboard. Or you may have picked up a virus or other malware that has done something nasty to Windows.
The hard drive is under a cover on the bottom of the computer so you can check that it's properly seated. You can also enter the BIOS setup screen when you turn the computer on and check that the hard drive is being properly detected. If you have access to a Windows installation disc, you can use the diagnostic tools it provides to check the hard drive. If you don't feel you can do it yourself, there's probably a computer service shop in your area that for some fee can check the computer for you and tell you what needs to be done .
Hope you can get the problem straightened out quickly. Thanks for using Fixya!
Apr 30, 2011 | Acer Aspire 3100-1405 Notebook
My hdd is a portable 500gb and its showing zero memory..how can i recover my data????????/
There are two causes for this.
1. Something wrong with the external case. Either not connecting to the HD correctly, not giving enough power, or just a software issue
2. Something is wrong with the actual drive
The best way to figure this out is to open up the external and remove the drive. Take the drive and connect it to a computer (computer is off) and boot up the machine and see if the drive starts to spin. If it makes any strange noises (clicks, beeps directly from the drive itself, grinding noises) turn off the computer right away as you might be causing more damage. If the drive is spinning though and not giving any warning signs then let the computer continue to boot and there's a good chance you'll be able to access the data. If you were having these warning signs, the best thing you could do is look into professional data recovery for the drive. It'll probably be pricey, so you'll have to decide how much the data is worth to you.
Mar 02, 2010 | Maxtor Hard Drive
HP Pavilion a384x PC, 8 beeps, doesn't boot up
This beep code indicates a possible motherboard fault.
Some components may not be making proper electrical connection.
Open the desktop and remove the cable connectors and components one at a time and insert them on back on the motherboard.
Also remove the various PCI cards etc. and insert them back into the various slots.
If it still doesn't boot up or cannot go into the BIOS configuration, then it is a faulty motherboard. The hard drive should be OK but you won't know for sure until you test it by connect it to an USB hard drive adapter and plug it into a working computer's USB port.
Dec 20, 2009 | Computers & Internet
Acer T-180 hangs at "Verifying DMI Data"
The cause of this problems is a corrupt boot files, Settings for hard disk drive are not correct,Floppy diskette or CD in computer causing issue, Boot devices not set properly, BIOS corrupt or misc. hard disk jumper setting not set properly, Connections loose or disconnected, Bad Hard disk drive or other bad hardware.
Note: Try this first. Check the cable setting of your hard disk in the BIOS. try swithching it to IDE, SATA, RAID. save your seetings and restart your computer.
if problem still exist... Follow this steps..
Step 1: If you have a USB stick with capacity of 4Gb and up or another hard disk... try installing a fresh Operating System in the USB stick or in the extra hard disk that you have.. after you install.. boot to bios and set the Primary boot in the extra hard disk or Removable Device (USB) save your settings and restart.. your computer will start normally booting the windows in your newly installed extra hard disk or USB stick. when you are in the Desktop, now try accessing your old hard disk and copy your files.. after you backup your files to the new installed hard disk. go to step 2.
Step 2: Turn off your computer... uninstalled the newly installed hard disk or USB.. after you uninstalled the hardware.. turn on your computer and reinstall your Operating System again. if the problem still exist go to step 3.
Step 3: if the problem stil exist. i think ther is something wrong with your hard disk.. try installing the OS again in second partitioned of your hard disk.. create first partition, then second partition. then installed your OS in second partition... if the problem still exist and you cannot go to windows desktop.. maybe your hard disk drive is damaged...
Hope I Can Help
CLCTECH
Apr 23, 2009 | Acer Aspire™ T180 PC Desktop
Acer ast180
The beeps that you are hearing are messages created by the POST (Power On Self Test) to indicate that something is wrong. If you know your motherboard type it is possible to find the documentation explaining what 3 beeps mean.
Because we don't know the motherboard type (At least for now) let's use the common sense.  Did you verify that the power supply is properly connected to the drive?  Can you confirm that removing the second Hard drive it boot again ok? In some type of BIOS 3 beeps means memory problem. By accident did you touch the memory? Are all the ribbon cables well plugged in?
Oct 20, 2007 | Acer Aspire™ T180 PC Desktop
Dell OptiPlex GX270 PC Desktop Logo
166 people viewed this question
Alun Cox
