Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn-air jcd2389G not making Ice. The idspensor workd but not the Ice making process.
    Genius:
  • 1,622 Answers
A chest freezer is great for storing additional food that may not fit in your fridge freezer. If your chest freezer stops working, it's important to be able to troubleshoot it quickly so that food waste is kept to a minimum. Keep the following tips in mind if your chest freezer stops working. Check the Electricity If your chest freezer doesn't seem to be working at all, check the outlet that the freezer is plugged into. Unplug the chest freezer from the wall and plug something else in such as a lamp or digital clock. If the new appliance doesn't work either, you know the problem is with your outlet and not your freezer. If the appliance does work, you will need to refer to other troubleshooting methods. Inspect the Relay The relay is a component that helps power the compressor. It is housed in a plastic box with the motor terminals and the overload protector and is connected to the Compressor; the relay is the largest component in the box. Closely inspect the relay and make sure it is not burned out. The relay can also be tested using a multimeter. If you see any signs that the relay has shorted out, you'll will need to replace it. If the relay makes a rattling sound when shaken, this is also a sign that it has shorted out. Examine the Compressor The compressor is essential to the performance of your chest freezer. It is the motor that powers the entire cooling system and if your freezer has ceased to work, you need to check it. This unit is located at the back of the freezer and sits in plastic housing; it can be identified by its football shape. You can tell that the compressor is broken if your relay is fine or if you hear a light hum followed by a clicking sound and silence. If your freezer is relatively new, it might still be under warranty and you could get a replacement compressor for free. If not, your compressor will need to be replaced by a professional. Investigate the Thermostat The fact that your chest freezer is not working could be down to the thermostat. This is the unit that regulates the temperature inside the freezer. To test your thermostat, remove the access panel on the side of the freezer. Next, use a screwdriver to remove the actual thermostat from the inside wall but do not disconnect the tube that runs from the unit into the freezer. Set the range scale on Rx1 on your multimeter to test for continuity. If your multi-tester reads continuity, your freezer problem lies in another spot. If your multi-tester does not read continuity, it means your thermostat is not working and you will need to replace it. Remove the tube from the old thermostat and attach it to the new one. Screw the new unit into place on the freezer wall and make sure the tube is not coiled or kinked as this will prevent the new thermostat from working properly.
Hope this helpout...
Posted on Aug 08, 2010
Not making ice
Probably dirt or hard water stopped up the supply tube bringing water to the unit. It's very small and doesn't take much to clog it up. Also make sure the lever in the ice making unit is down. If it made ice before and was full, the lever moved up and shut off the ice maker and now needs to be reset in the down position.
Jun 17, 2014 | Jenn-Air JCD2389G Side by Side...
Reset ice maker
7c3b8cbb-076b-4151-8484-231367a81955.jpg0ef80fea-be03-46a2-9d13-079d4e206d2c.jpg20a0932e-3a69-4ce7-8bf3-ad10bc82a262.jpgDoes the ice maker have ice inside the slots but will not drop the ice? What is the correct model number of your refrigerator? If the slots are empty try filling with tap water and once the water freezes and drops the ice and then does not refill with water that will point to the water control valve. If the ice maker does nothing it will be the ice maker that will need to be replaced. For the model JCD2389G uses the=> D7824706Q Ice Maker Assembly and the water control valve is=> 12001892 Water Inlet Valve I am here if you have questions....Sea Breeze
Aug 29, 2013 | Jenn-Air JCD2389G Side by Side...
We have an ice glacier building up behind and below our ice maker inside our Jenn Aire side by side refridgerator model JRSD 2450.
WATER LEAKS ON YOUR WATER SUPPLY CONTAINER TO THE WATER DISPENSER OR CONDENSATION PROBLEM RELATED TO FRIDGE DOOR FAULTY SEAL
Nov 09, 2010 | Jenn-Air JCD2389G Side by Side...
Water wil dispense, but unable to change to ice dispense. None of the bottoms will work, including lock and light.
It sounds like your control panel has a short, please call your Jenn-air rep for assistance. thank you.
Oct 11, 2010 | Jenn-Air JCD2389G Side by Side...
Ice maker will not make ice
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 10, 2010 | Jenn-Air JCD2389G Side by Side...
The ice maker in my Jenn Air refrigerator stopped working.
Check that there wasn't a clog in the line after replacing the filter. Make sure you get water going to the solenoid, if so, it may either be a clog in the solenoid or a fluke that it's no longer working.
Sep 10, 2009 | Jenn-Air JCD2389G Side by Side...
I have jenn-air jcd2389ges - the freeze keeps running and coils ice up. It is cold and does make ice. I shut it defrosted -put it back on and it just keeps running and frosts up again
It could be a bad defrost timer or a bad thermostat. Both are a cheap fix also, check to see if the condenser coil is clean. If it isn't clean it!
Another possibility if it isn't the T stat or defrost timer, the defrost heaters or overload might be bad.
Jul 05, 2009 | Jenn-Air JCD2389G Side by Side...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Ice Enclosure Broken
do you have a jenn-air JCD2389GEQ ? the part number you gave is not coming up...
Jun 12, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn Air Side by Side Refridgerator
You could have a layer of solid ice at the bottom of your icetray which is binding everything up. Remove ice tray and any ice from the bottom. Reinstall and be careful of the connection on the back of the ice tray, you may have to turn it a little to get it to mesh correctly. refill and try. Good luck.
Jan 08, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
121 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
