Question about Car Audio & Video
My car stereo needs a code but i dont no how to get into it all it says on the display is wait
  • Car Audio & ... Master
  • 4,979 Answers
Remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
Posted on Aug 08, 2010
Radio stuck in safe mode, holding the PSCAN and RBDS buttons doesn't display the "1000" where I am able to enter the code.
first off is it the original stereo that came factory if it is try this solution:
1:turn ignition on but do not start
2: turn on stereo
3: do not touch anything else
4: wait 5-10 with stereo on and ignition on 10 min to be sure
5: after 10 min turn of ignition only remove key exit vehicle
6: set alarm
7: wait 10 more min
8 disarm alarm
9:put key back in ignition and set to on do not run
10: stereo should now work
Nov 14, 2016 | Audi Cars & Trucks
Bought a used 1995 Toyota Avalon for daughter. Battery unhooked now Stereo locked. Model 16186349. Display shows HELP. Dealership gave me paperwork with unlock code and instructions but cant get it to work...
just replace it with a aftermarket stereo and dont forget to get both harness for easy diy install.thats what i did and it works fine & the best thing about it is i dont ever need a code again.
Feb 23, 2011 | 1995 Toyota Avalon
My zafira radio cassette is showing safe on the display, i dont know the 4 digit code, thanks
on you owners manual their sholud be a card with the code for the stereo i had this with my astra in the black booklet some are wrote on the stereo other than that i would get it de coded or fit after market stereo
Feb 09, 2011 | Car Audio & Video
Display for radio stuck in '7 SAFE' mode
This sounds like a Phillips Car Stereo:
To get the code in:
1. Turn the stereo off.
2. Turn off the ignition
3. Turn the ignition back on (dash warning lights on)
4. Hold and keep down the AS button on the stereo.
5. Turn the stereo on.
6. Release the AS button after 4 dashes appear on the display
7. Now enter code (if code = 7009. Press preset button 1 seven times, button
2 once
3 once
4 nine times
If you go past you can go round again by pressing the
preset button repeatedly
8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
9. The stereo after beeping will scan to program channels
You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
Time delays work as follows:
Attempt 1. 10 seconds
Attemp 2. 30 seconds.
Attempt 3. 10 minutes.
Attempt 4. 20 minutes
Attempt 5. 40 minutes
Attempt 6. 80 minutes
Attempt 7 160 minutes
Attempt 8 320 minutes
Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
So, be prepared for a VERY long wait to be able to enter the code!
Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
May 09, 2009 | Car Audio & Video
I have a radio in a 91 560 that needs recoded.
hi,you my leave the radio,with wait in display with in 10 to 24 hours,then code automatic appear in display,then enter the right number,careful,3 times wrong,wait appear again,ty
Dec 12, 2008 | 1991 Mercedes-Benz 560
Original stereo in audi 1991 90
i have the original book it says anytime the battery is disconnected it will do the lock up and read SAF on the display when this happens you cant use it again untill you unlock it... to unlock it turn the radio on the word safe will be displayed first press the am/fm button and then press the scan button and hold them down simultaneously until "1000" appears in the frequuency display release the buttons DO NOT UNDER ANY CIRCUMSTANCE CONTINUE HOLDINT THE BUTTONS DOWN OR PRESS THEM ONCE AGAIN THIS WILL CAUSE THE RADIO TO TAKE THE NUMBER "1000" AS THE CODE NUMBER. using the first four radio station buttons enter the code number found on your radio card (the codes you have) use button 1 to set the first digit of the code button 2 to set the second digit etc. the first digit of a four digit code must be "1" if your code number has three digits the first digit on the display must be set blank. Once the code is shown on the display press and hold the am/fm button and scan button simultaneously until the work safe appears in the frequency display release the buttons a radio station frequency will automatically be displayed ... MAKE SURE YOU PUT IN THE RIGHT NUMBER OR YOU WILL LOCK UP THE RADIO AGAIN AFTER 2 TRYS AND WILL HAVE TO WAIT AN HOUR BEFORE YOU CAN RETRY IT. IF YOU LOOSE THE CARD WITH THE NUMBER SEE YOUR AUDI DEALER
Aug 24, 2008 | 1991 Audi 90
Kenwood Deck KDC-MP3032
Hey mate
We always used to use the remote to enter the code and the unit would reset. Without the remote, dont think it works, sorry man. Go to a Kenwood installer and they will probably be able to help you will you wait. I would, if you are in Greenbank QLD Australia. :
robotek
Aug 09, 2008 | Kenwood KDC-MP2032 CD Player
No display
HI THE FLEXI RIBBON IS FAULTY MAKE SURE YOU HAVE THE CODE AS YOU WILL NEED THIS TO MAKE THE STEREO WORK AGAIN
IF YOU DONT HAVE THE CODE THEN
LOOK ON THE BOTTOM OF THE STEREO YOU WILL SEE A SQUARE SECTION MISSING INSIDE THIS 4 BLOBS OF SOLDER JUST SOLDER THE FOUR BLOBS TOGETHER AND THIS WILL WIPE THE CODE OUT ALTOGETHER
THIS DOES HOWEVER MEAN THERE WILL BE NO SECURITY ON THE STEREO
HOPE THIS HELPS
Aug 05, 2008 | Sony CDX-M800 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
