I have a micromark z23022 alarm panel and have lost the user code,how do i get the factory default settings and restore my user code.
  • 17 Answers
SOURCE: restoring factory default settings
System Configuration of Fujitsu Amilo D-7820 PC Notebook:
Manufacturer:  Fujitsu
Family:           AMILO
Model:            D-7820
Speed:            PC-2100
Fixed RAM:      0MB
Standard RAM:  128MB
Banks:              2
Maximum RAM: 2GB
Sockets:            2
Chipset:             Intel 855 GM
Please check whether you have a systems disk or cd with an operating system e.g. MS XP Home edition.
If you have the original operating system disk or cd, reformat your hard drive i.e. assuming that you have windows XP click the Start button, then select Run, then type "cmd" then Enter, an MS DOS screen will appear.
Type "format c:" and enter and it will then ask whether you really want to delete all files on the hard drive and then type "Y".  The computer will then wipe everything on your computer.  You can then insert your Operating Disk or CD and follow the instructions that appear on the screen to reinstall the original default settings or the Operating System.  Hoping that this will help you solve your problem.
Posted on Oct 24, 2007
leroyal
  • 2120 Answers
SOURCE: Factory Default Settings
Press Menu * 2864 (within 2 seconds) [MAINTENANCE MODE] press 01 (INITIALIZE)
Posted on Oct 07, 2008
nyilasrobert
  • 627 Answers
SOURCE: i cannot restore the factory setting for my nokia 6030 mobile
1 way: Select Menu > Settings > Restore factory settings
or:
*#7780# reset to factory settings.
Posted on Jul 31, 2009
support506
  • 3 Answers
SOURCE: I need to restore factory default setting for acer aspire 5920.
depending on the age and model, most acers come with a self-branded "recovery CD" creation program. I'm not sure why you need to do the restore, but assuming the computer will still boot, you need to find that program and have a couple cd's or dvd's handy and step through the prompts to create the cd's. Once you do, you need to restart the computer and boot it up with that CD you just created and step through the process. Make sure all your stuff is backed up first.
Posted on Nov 10, 2009
SOURCE: restore factory settings
HOW TO RESTORE FACTORY N72
Posted on Feb 01, 2010
Change language on DSC maxsys keypad
I can help you default the system. I got this out of the manual.
Hardware Reset of Memory to Factory
Defaults
If the Installer's Code is lost through inadvertent
programming, the only means of reprogramming the
system is by a hardware reset. If the Installer's Lockout is
enabled, there is no way to reprogram the system without
entering the correct Installer's Code.
The PC4010 can also be reset through software in the
installer's programming. See "Factory Default" in the
Programming Guide.
Note: Panels returned to DSC with the Installer's
Lockout feature enabled and no other apparent
problems will be subject to an additional service
charge.
To reset the panel to factory default conditions:
1.Power the system down by removing both AC and
battery power to the main panel.
2.Short the zone 1 terminal and the PGM terminal on the
main panel.
3.Restore power to the main panel.
4.Wait for 20 seconds then remove the short between
the PGM and zone 1.
5.The system will have reloaded the memory with
factory defaults. All modules will have to be enrolled
again. The event buffer is the only part of memory that
is retained during a factory default.
May 21, 2014 | Home Security
How do I factory reset a Lexmark x658de?
When you first enter the printer menus from the operator panel, you may notice an asterisk (*)
next to a value in the menus. This asterisk indicates the factory default setting. These settings
are the original printer settings. (Factory defaults may vary for different countries.)
When you select a new setting from the operator panel, the Saved message appears. When
the Saved message disappears, an asterisk appears next to the setting to identify it as the
current user default setting. These settings are active until new ones are stored or the factory
defaults are restored.
To restore the original printer factory default settings:
1 Make sure the printer is on and the Ready message appears.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Factory Defaults, and then press Select.
4 Restore appears on the second line of the display.
5 Press Select.
The message Restoring Factory Defaults appears followed by the Ready
message.
When you select Restore:
No other button actions are available on the operator panel while Restoring
Factory Defaults appears.....
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
May 01, 2014 | Lexmark X658DE All-In-One Laser Printer
Go back factory condition
Hello Cynthia,
There are several ways to achieve this.
Reset phone
The Reset feature allows you to set your phone options back to
the factory defaults.
  1. From Idle mode, touch Menu-> Settings -> Phone -> Reset phone.
  2. At the "All settings reset to factory defaults. Continue?" prompt, touch Yes to reset, or No to cancel. Once your phone has been reset to its default settings for those selected options, it will restart itself in order to incorporate the new settings.
Restore phone
The Restore feature allows you to delete any user information
that has been added, in addition to setting your phone options
back to the factory defaults.
  1. From Idle mode, touch Menu-> Settings -> Phone ->Restore phone.
  2. At the "All settings reset to factory defaults and all user data will be deleted. Continue?" prompt, touch Yes to reset, or No to cancel.
or
Reset code
Enter *2767*3855# in phone dial.
Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup on your PC before full reset!
Dec 06, 2013 | Samsung SGH-A877 Impression Cell Phone
I have an WNR1000 and I have lost the password but have the disk. How do I reinstall?
On the back of the router there is a very small button something you would need to use a paperclip or other small object to push push and hold that button for a few seconds that will restore the factory default settings to the router. then admin should be the user id and leave the password blank to get into the router settings
Mar 23, 2011 | NetGear WGT624 Wireless Router
If I take out the battery on my skylink sc-100 does it reset it back to factory settings.
I guess the question is about the control panel SC-001.
If power is totally removed (disconnecting DC jack and removing battery) from the control panel, user settings will be restored to factory default. These include all passwords and zone settings. Master PIN will be reset to "000" and secondary PINs will be deleted. Home, Away, and Night sequence default zone setting can be found in the manual.
However, all programmed sensors and remote controls will remain intact. This means that all programmed sensors would still trigger the control panel if activated. And programmed remotes would still operate the control panel. To remove installed sensors or remotes, simply disconnecting power will not work. User must follow instructions in the manual to remove sensors or remotes from a zone.
Feb 19, 2011 | Skylink Group Skylink Sc-100 Security...
I have a micromark mm23244 alarm and have lost the instrustons, need the reset code so i can use it as some1 tryed to get in the house last night tyx
You can find most user instruction manuals at, www.managemyhome.com.
You will need the model number off the unit. The search box is on the right side of the page.
Jul 05, 2009 | Micromark England Microcooler Plus Compact...
I need a manual for a micromark mm23062 can you help i have lost the user manual and i do not know the code to get it to work please can someone help me #
The alarm is factory set. Press 1 twice then the E key to arm/disarm.... or press 1 twice then the P key ... choose your own code ie. 2553 then press the P key again (2 beeps will be heard) and your new code is active.
Mar 16, 2009 | Refrigerators
Sim problem please help me
just goto settings n then phone settings there u ll find option for restore to factory defaults..
do it.
Then default security code is:12345
Dec 05, 2008 | Nokia 1100
Computers & Internet Logo
206 people viewed this question
Alun Cox
David Payne
David Payne
