Question about Cobra Radio Communications
Problem with Cobra CB23 transceiver. In weather channel mode, everything works perfectly. But in CB mode, no audio heard on any CB channel just a whining hum (this is indoors with a clean DC power supply). In CB mode, squelch works all right, but volume control has little effect on the whine. Connecting or disconnecting a good antenna has no effect in CB mode. In transmit mode, red transmit light comes on but no RF is generated. Inside the unit, everything is screwed down tightly, no cold solder joints are apparent, no burnt-looking components, no odor of burnt electronics. "Rocking" the band switch into and out of CB mode does not change the problem. Since problem affects CB reception and transmission, my guess is there is a common path between these modes that has a problem. I am obtaining a copy of the schematic and will troubleshoot with my oscilloscope but wonder whether this problem has been experienced before.
  • Mike107 Sep 16, 2010
    John, there is no PA on this model Cobra. My guess is that an electrolytic capacitor has dried out in the CB portion of the transceiver, and is producing oscillation when in CB mode. I still have not gotten around to connecting my oscilloscope to the transceiver to see what might be happening. thank you, Mike
    Genius:
  • 1,274 Answers
Hi, my name is John. Try putting the unit on PA and PA speaker plugged in the back, try another cobra mic on it, if that does not do it, then we will look at the audio chip. Let me know how it goes, I will post the tools needed and procedure here. Hope this was very helpful....Rate this solution on the four thumbs-up....... John
Posted on Sep 12, 2010
The weather channels quit working on my cobra 29 nightwatch.
its an internal problem , take it to a tech and let them fix it. the board for the wx probably has jumped freq. and thats why you can't receive wx.
Apr 10, 2015 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra CB 29wxnwst no weather?
I think you have a capacitor on the wx board thats been cut and / or removed.If it has been cut and its still in the radio all you have to do should be replace it. I think it # C608 ???
Jun 26, 2013 | Cobra 29 WX NW ST 40-Channels Base CB...
I can not send out
Is the DYNAMIKE turned all the way to the right? Check the mic wires, pin 2 on the mic plug is the audio wire, If you are using a stock mic the audio wire is yellow. If you are using an astatic mic, the audio wire is white. Is the PA/CB switch in the CB position? Does the radio have weather capability? if so make sure the weather/cb switch is in the cb position and the weather channel selector is set to off.
Feb 03, 2012 | Cobra 29 LTD CB Radio
I jus was wondering, can the cb radio and the handheld radio transmit on the same channel? Im a security officer and im interested in purchase a cb radio so we can use it at work but i dont know if its...
CB radios and hand-held CB radios can operate on the same channel and be in contact with each other. Other hand-held radios do not operate on the same frequencies and even though they may have channel numbers the channels have different frequencies and will not operate to CB radios.
Oct 29, 2010 | Cobra 150 GTL DX Base CB Radio
Cobra 75 wx st everything seems to work eccept receiving signal meter will spike on trx and it seems to receive but no sound there is sound in wx mode
WX is for weather. If you put it on WX, and you do not hear anything, then you need to change the weather station it is on. in wx mode, you change weather channels by pressing channel up and down. To communicate with 2 way, press the cb/wx button so it is on CB mode.
Sep 28, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Twilli811@hotmail.com
check the SWR's on antenna. check microphone it has to work for the RX to be heard. cbshop
Sep 06, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Weather bleads Over on 21 LTD WX CLASSIC(*HELP*)
sounds like your wx receiver is being activated by a bad switch replace the switch to disable the wx when you dont want it to come thru
Jun 10, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Wx stations disappeared
They did not put all the plugs back in from the weather board. Part of what has to be fiddled with is underneath the weather board.
Open the bottom cover where the speaker is, on the right side you will see a board separate from the main board. Look for any plugs unplugged. Its probably one that got over looked.
If there are no plugs out, who ever you took it too may have turned something they should not have. most likely its a plug. Its probably the plug that runs the audio into the radio from the weather board. its working, the audio just isn't getting to the rest of the radio.
there are about 3 or 4 plugs from the weather board to the main board of the radio.
Nov 10, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
NO sound
Make sure the switch is in the CB position. If this is so, then you may have a bad switching transistor or a bad diode in the board. Also on some of the weather band cobras I have worked on in the past, I have found bad pll chips. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 30, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
100 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
