Laptop memory iv tried to upgrade the memory in my laptop from 1g to 2g , but it has only been running on 766mb since i got it , i put the 2g in restarted the laptop and it still only running on 766mb what can i do ,, many thanks,,
  • 558 Answers
Wrong type(brand) of memory some laptops are very fussy about what type of sodimm you put in them, I would put the 1 gig back in since it is more than the 766mb your getting with the new memory.
Posted on Apr 27, 2008
Constant beeps
this laptop can take 4G ram http://www.crucial.com/upgrade/Gateway-memory/M-1000+Series/M-1625-upgrades.html
if the memory modules are not from the same brand range, this can often be the issue.
it SHOULD be able to run with just 1 2G module but will run better with 2 1G rather than the single, assuming it's the right type for the machine.
If I'm upgrading pc memory, I remove the old and replace with Crucial or Kingston kits so as not to mix brands and ranges.
Apr 13, 2013 | Gateway M-1625 Notebook
I upgraded my memory RAM 2g and added 1g so it makes a 3G of ram but how come when my pc boot up up i can only see 2G ram single chanel. wen i go to my my computer----properties----general under computer:...
Could you please go online and in a search engine type "MAX RAM E-Machines (here put your model #)." Pick a link that secribes your maxi,um ram and if it's only 2GB you'll have your answer. If the max is higher there should be instructions on how to set the computer to acess and show the RAM.
Regards,
Selk
Nov 19, 2010 | E-Machines eMachines Desktop PC
Trying to upgrade memory, have tried three sticks purchased at Best Buy terrific Geek Squad. None work. Where can I purchase a upgrade memory?
You may have non OEM memory, your system may not be able to handle that much mem, or you could have something wrong with the connector that your mem fits into. If your original mem still works then the connector is not the issue. You should also make sure you are putting in the memory stick correctly. Make sure it is put in straight and is firmly placed in the connector. If you don't it will cause your problem. Capacity is 1G. If you are trying to put in a 2G it will not work. Hope this helps.
http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch&model_id=61473
Try this site. They say if it doesn't work you get your money back.
Feb 07, 2010 | Gateway MX3215 Notebook
Ram upgrade problems
looks like you have the wrong ram for your system Kingston is showing this for your system KVR667D2S5/2G
but try refreshing your bios i doubt it will work but give it a shot with your ram installed just hit F2 to get into bios when starting your computer save and exit that should refresh it
Nov 03, 2009 | ASUS Eee PC 900HD Netbook
My computer will not boot up when 2 g ram
Try upgrading your Bios first, also make sure that the memory that you ar putting in your Laptop is type PC-2700. Other than this, I know that this comptuer has a 2G limit and should have no problem with it.
Sep 06, 2009 | Compaq Presario R3000 Notebook
I own the asus 901
I assume that you are referring to the maximum memory of this computer. It is only 1 gigabyte, not upgradeable to 2.
Nov 29, 2008 | ASUS Eee 4G Notebook
Toshiba laptop problem
The right memory for your laptop is
256MB Memory (PC2-4200) KTT533D2/256, PA3389U-2M25 KTOS534
512MB Memory (PC2-4200) KTT533D2/512, PA3412U-1M51, PA3412U-2M51 KTOS535
1GB Memory (PC2-4200) KTT533D2/1G, PA3411U-2M1G KTOS536
Using the wrong memory can caused motherboard failure.
Try reinserting the old one memory module.
Be sure that the memory is placed in the right way
Nov 06, 2008 | Toshiba Satellite A135-S2386 Notebook
IBM ThinkPad T40 2GB Max RAM
The T40 has two ram slots, you can put a 1g chip in each totaling 2g. If the chip will remove, then it is changeable. Vista needs a minimum of 256 to run, so, when you change BOTH chips to equal 2g it will probably read 1.744g, or it may read the full 2g. If it only reads 1g, then the second slot under keyboard may have malfunctioned. It could also be that the 256 chip is bad and your really only running 512 now. With all that said, in order to achieve 2g, you will need to put a 1g chip in each slot.
Jul 08, 2008 | IBM ThinkPad T40 2373 Notebook
Laptop memory
hmmm..ok...try them one at a time, and make certain that the laptop can id each of them. if that works, swap them in the sockets..if that does not work, then one of your sockets is unhappy.
also, use F2 when loading up, and see if memory is present in system setup screen..be careful in there, of course, since it's the nerve center of that whole computer.
Apr 27, 2008 | Fujitsu AMILO PC Laptops
Computers & Internet Logo
145 people viewed this question
David Payne
David Payne
