Diplomat APM 8703/2 Washing Machine & Tumble Dryer I have moved into a flat which has this washing machine. The powder tray is filthy. It does not seem obvious how the tray can be removed without potentially breaking it. I am looking for an online document for the user guide so that I can see how the tray can be removed without damage. Also, the online guide will allow me to see how to fix the drain sump whenever there is too much lint clogging up the area and preventing the water from draining.
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow link regarding your query…
http://www.repairclinic.com/Washing-Machine-Repair-Help
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itwontdrain
http://www.ehow.com/how_2353143_remove-washing-machine-mold.html
http://www.washerhelp.co.uk/diy-repair-help_4.html
When you wash very linty materials, remove lint from the tub after removing the laundry. Soap deposits may cause laundry to smell bad. To solve this problem, fill the tub with water and add 1 pound of water softener or 1 gallon of white vinegar; then run the machine through the complete wash cycle. If the deposits are really bad, wash the inside of the tub with a solution of household ammonia and mild detergent. Rinse thoroughly and wipe the tub with liquid bleach. Caution: Rinse the tub thoroughly before wiping it out with bleach. Ammonia and bleach can combine to form a very dangerous gas. Finally, run the machine through a complete wash cycle before you put any more laundry in.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 08, 2010
I have model 7411-900 is leaking from the bottom ? May i have to right video to watch to fix the leak and this part i found broken when try to find the leak
First you have to find the leak. First place to look is the pump and its hoses. Often there is a removable panel at the front, or a cut out section at the rear. Then check the door seal. Pull the machine out and tilt it back. Put something sturdy under the front so it doesn't drop on you.
Google
make model spare parts
and you will end up somewhere like here. Unable to tell what your broken part is, but wholesalers carry or can order all of them.
Washing Machine & Tumble Dryer Spare Parts & Accessories ' eSpares
www.espares.co.uk/browse/ca1236/washers-and-dryers
For Tumble Dryer Spares and Washing Machine Spares you've come to the right place. Give your appliance a new lease of life with our huge selection of ...
Washing Machine Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a11/Washing-Machine-Parts Washing Machine Parts - Shop online or call 800-269-2609. Fast shipping. Open 7 days a week. 365 day return policy.
Washing Machine Shop ' Partmaster
www.partmaster.co.uk/washing-machine-parts/catalogue.pl?path=66991 Find Washing Machine products - repair your Washing Machine with a Washing Machine ... Get the Washing Machine products you need at Partmaster. ... Over 1 million spare parts and accessories from the world's leading brands including ...
Jul 03, 2017 | Washing Machines
Diplomat washing machine
Try Sliding the Soap Dispenser Drawer Lock to the RIGHT and then pull straight back... It is located under the handle
Mar 03, 2014 | Washing Machines
Washer won't drain, it is a Diplomat washer dryer model HJA 8703, is there a filter on the machine?
there is a filter down on the bottom right hand side. twist anti clockwise but drain it first if you can. If not lean it back a bit and put a bowl under the filter
Mar 29, 2010 | Washing Machines
Tumble dryer not working
SOUNDS AS THOUGH YOUR HEATER ELEMENT HAS GONE..
IT IS POSSIBLE TO FIX IT YOURSELF BUT VERY COMPLICATED, CALL OUT FROM A REPAIR PERSON IM AFFRAID, COMBI WASHER/DRYERS ARE RENOWNED FOR THIS & ALSO BEARING KITS
May 22, 2009 | Indesit W 123 Front Load Washer
Put washing powder in tray ,machine doing wash but leaving large residue of powder
Don't put the powder in the tray. Select you wash cycle, let the water run into the washing machine, then add the powder.The powder should dissolve before you put your clothes inside the machine. Let the washing machine fill up to almost half way and add clothes. This should stop the clothes from getting the residue powder on it.
Mar 23, 2009 | Whirlpool Washing Machines
Diplomat 8512 Washing machine - water spilling out of detergent tray? Here's hoping for a simple solution.... When I start any program the water fills up the drum and then starts to pour out of the...
This is a problem with the pressure system usually caused by a build up of powder residue but can be caused by other blockages. Remove machine lid and locate pipe which is about 6mm in diameter. follow pipe down which will lead to pressure bottle. Clean out and replace and should be ok. If bottle is clear check pipes for other blockages and check preesure pipe for damage.
Nov 07, 2008 | Washing Machines
Diplomat washer drier
all you have to do is:
select half load
set drier timer to required time. set main timer to dry program
i suspect you are not pressing half load button - this is essential
Jul 20, 2008 | Washing Machines
I have a Diplomat APM 8702 integrated washer / dryer, it has decided to stop working! its been great but does get used alot, the electrics come on, ive checked all the connections inside the machine made...
I have one of these machines. I don't know whether this will be of any help but I had issues of the machine not activating a final spin and the clothes being left sodden once the cycle had finished. The engineer replaced the PCB module at the rear of the unit which fixed the problem. If your APM 8702 is not even starting I'd guess its a motor problem and time for an expensive repair or new washing machine.
Apr 26, 2008 | Washing Machines
Any ideas on cleaning where you put powder and fabric softer?
You can remove the tray by pusing in on the tab right behind the fabric softner compartment(on top). This would make cleaning very easy as you could take it and clean it right at the sink. Just make sure you don't over due it and wear out the tray.
Sep 07, 2006 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
523 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
