Question about EnGenius EUB-362 (EUB362 EXT) Wireless Adapter
Computer wont recognize the device, it makes a weird sound when you plug it in, not the usual sound when you plug hardware.
  • 835 Answers
Does the sound come from the device itself or your computer speakers? If its coming from your adapter itself the their something physically wrong with it. I suggest returning it or getting a new one.
Posted on Aug 08, 2010
  • humaidank Aug 08, 2010
    The sound is the sound the computer makes when you put in hard ware, or remove it. It makes an unusual sound when I put it in, adn then it doesn't recognize it at all.
  • Norman
    Norman Aug 08, 2010
    did your adapter come with a install cd? just make sure that you have the correct drivers installed for it. If that does not work their may be something wrong with the device.
No sound while attaching to my mp3 player via usb and aux pin cable
No Sound? Don't Worry! Troubleshooting Tips For Your ...
www.makeuseof.com/.../no-sound-dont-worry-troubleshooting-tips-for-...
Apr 23, 2013 - Using your computer seems like a purely visual experience, but the aural experience is surprisingly ... There's no sound coming from your speakers. ... Which is weird, because my hearing isn't that great. ... MP3 Player/Phone ... If they are USBspeakers, check your USB drivers while you're in there. no ...
Why won't my system recognize my USB device? - Ask Leo!
https://askleo.com/why_wont_my_system_recognize_my_usb_device/
Oct 26, 2005 - My system won't recognize anything that is connected into USB unless ... Why is my USB device asking for a CD when I attach it? .... Follow-up: I plugged a 4-port USB hub into my computer and then attached my MP3 player to it, .... sounddetecting any usb device but in my computer there's no sign of it. i ...
My laptop does not recognize my mp3 player [Solved] - CCM.net
Dec 29, 2015 | Cell Phones
Free sound driver
Do you know what type of sound card you have? Look in Device Manager in your Control Panel. Usually, a Sound Blaster, or Microsoft default driver will work unless you have a hardware problem or some really weird sound card.
Jun 30, 2013 | Intel Pentium Dual Core E2140 / 1.6 GHz...
How can i install a magicjack?
Magic Jack is a plug and play device, just plug the USB to the jack and to your phone, and your computer will instantly recognize the hardware connected to it.
Sometimes, it does take a bit of time for the computer to recognize the hardware, so be patient! It'll take about 1-2 minutes for it to fully recognize and load, and you'll be up and running making calls in no time!
Jun 30, 2011 | Computers & Internet
Received a error message "This software can only
This may sound stupid but make sure it is plugged in. Check the operating system and hardware requirements, if they don't meet the requirements, software will not recognize the device. Try different usb ports because sometimes computers have selective hearing and make sure your computer is initially recognizing the device when it is plugged in. If all else fails, don't try to install the software and head over to computer/my computer in the start menu. Right click and select properties. Click device manager in the hardware section or the bar to the left and look in the cd drive section. If you see your drive, right click and try any option about installing.
Mar 03, 2011 | LG Super Multi Blue Slim Portable Blu-Ray...
MY speakers are making weird noise, i have logitech x240 and on youtube i can only listen audio, not voice. Everything is connected but its still making weird noise.
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
Feb 26, 2011 | Logitech X-240 Computer Speakers
USB not recognized during printing and scanning
Some motherboard or operating systems have problems if you leave usb devices plugged in. They don't recognize that the device is still there and ignore it. These are referred to as "Legacy USB devices". There are a couple of things to try.
Make sure the problem isn't the printer if you can. If you have another computer just plug it in long enough to for the operating system to recognize something has been plugged in.
On this computer giving you the problem. unplug the usb cable and insert into a different USB port. Usually this is enough to "fix" it and make it usable.
Next is to unplug the usb and reboot the computer a few times. Then insert into a different usb port.
Past this point if it still isn't working then you need to go to control panel-system-hardware manager-usb devices and delete all entries under the usb header. Then reboot. This forces the operating system to find all the usb ports and reinstalls the drivers. Then plug in the usb and it should work again.
Oct 23, 2009 | HP Photosmart C3180 All-In-One InkJet...
Speakers making weird sound
This is the test tone for the speakers, usually means you have connected the input lead into the diagnostic port. The input leads plug into your computer/ipod/TV etc. there may be 2 of them but you only need one plugged in.
Jun 16, 2009 | Harman Kardon HK695 Computer Speakers
Ipod isnt detected.
For it to recognize, maybe try:
1: go to control panel
2:add hardware
3:connect your hardware device and click "yes i have connected the hardware"
4:scroll down and select install new hardware device
5:select install hardware that i manually select from a list
6:scroll down to windows portable devices
7:and choose MTP device
this should make it so your ipod is now recognized by the computer
---John
Give credit to Randomassist
Dec 01, 2008 | Apple iPod nano
My Computer and iTunes does not recognize my iPod
For it to recongnize, maybe try:
2:add hardware
this should make it so your ipod is now recognised by the computer
---John
Nov 24, 2008 | Apple iPod nano
EnGenius EUB-362 (EUB362 EXT) Wireless Adapter Logo
75 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Bhagyanath N
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
