No input and out put on GE TV.
I have a GE TV model 25GT507. I can't find anyplace to hook up my DVD player. It was my Uncle's TV, and he passed away, but I know he had a player hooked up to it. How do I do it? Thank you in avance for your help.
    Scholar:
  • 131 Answers
Hi if it does not have the rca connector ports. because its older.
you need to go to radio shack and by a converter. that will connect to tv and dvd off of channel 3 .ask the sales people how to hook it up he can draw you a picture. cost is 20.00.
PS maybe you could find the other part that he had .it is silver little box
thanks DOCTOR VIDEO
Posted on Apr 27, 2008
Cant figure out how to hook up the receiver to my phillips hi def tv and get the sound?
its old model, will not pass hd video, good only for audio. Connections depend on your equipment. If you use a cable box to watch tv, connect cable box audio out rca connectors (red and white), by an audio rca cable, to audio TV input on the back of the receiver. Now when you swith your receiver to TV input you get sound from cable box trough your speakers.
If you use DVD player: connect audio out of the player to dvd audio input of the receiver. Switch the receiver to DVD input, you have sound from DVD.
Jan 08, 2011 | Denon AVR-1403 Receiver
Im trying to set up my tv, it was given to me as a gift, my uncle was using it it works i can change the channels but when i try to work my dvd player with it, only the audio comes on the screen stays...
Please few things...
1- Make sure audio and video wires are hooked correctly in AV input of tv and you selected that AV input in tv with its remote.
2- Also check your dvd has not been set on progressive mode if you hook dvd player through yellow-red-white wires with tv.
3- if dvd player is set on progressive mode, then hook it with tv by component video input, red-green-blue for video and red-white for audio.
Hope this info will solve your problem.
Thanks.
Mar 17, 2010 | Toshiba TP55H60 55" Rear Projection...
How do i hook up a DVD to tv. I have lost mannual
Use a RCA cable put the video in yellow,red,white to the tv.
Use the RCA cable put the video out yellow,red,white to the DVD player.Press the video input 1 or 2 play ur dvd.
Sep 23, 2009 | GE 27GT616 27" TV
Video mode on GE 27GT610
Try hooking up the dvd player and turning it on. Then use the setup and add/erase channel feature to look thru all of the channels. On my older GE tv I found that channel 91 was the correct channel for the video input. I saw the logo for the dvd player on this channel. I just added that channel and now it works. Your channel might be different.
Feb 22, 2009 | GE 27GT616 27" TV
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
Connect magnavox dvd to ge tv HELP!
You need to go get an RF modulator. They can be purchased at Radio Shack or a number of other electronic shoppes for a reasonable price.
The RF modulator connects to the coax cable connector and it has inputs for the RCA connectors.
Cheers ... Best wishes
Jan 30, 2009 | Televison & Video
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
Can i hook up to my satelite dish direct or do i have to go thru my receiver first. Thanks; Delmar currah@mts.net
The satelite dish will not pass-through the video/audio from your DVD player. You will need to find an open area (preferably DVD selector) on your receiver to input the DVD video/audio. Most satelite boxes are one way devices.
Satelite box --> Receiver (satelite input)--> TV
DVD Player --> Receiver (DVD Player input) --> TV
or
Satelite box --> TV
DVD Player --> TV
Mar 13, 2008 | Televison & Video
DVD Player
The remote will have an input button on it, this will put it in video mode. Many stores sell RCA / GE replacements, just make sure it has the input button.
Sep 03, 2007 | GE 27GT616 27" TV
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
