Question about Rockford Fosgate Punch 401S Car Audio Amplifier
What is the rms for the punch 401s 1200 watt amp
    Scholar:
  • 55 Answers
Rockford Fosgate 401s 400 watts RMS x 1 bridged
Posted on Aug 08, 2010
What is the output of the 451s rms power
Dynamic Power Rating (measured at 14.4V):
  • Bridged Into A 4-Ohm Load: 450 watts x 1
  • Per Channel Into A 2-Ohm Load: 225 watts x 2
  • Per Channel Into A 4-Ohm Load: 115 watts x 2
Apr 14, 2010 | Rockford Fosgate Punch 401S Car Audio...
I have a RF punch 401s 1200 watts and the RCAs broke off the mother board what do i do to fix it
If you have a soldering iron simply epoxy the jack down to the board and then take some wire and solder rthe center conductor of the RCA jack and the other end would go to the trace on the PCB. Do the same for the ground connection.
Jan 26, 2010 | Rockford Fosgate Punch 401S Car Audio...
Can you run a single 15" 2 ohm woofer on a 1200 watt 401s?
yea you could run a single fifteen it would be a good combination
Dec 29, 2009 | Rockford Fosgate Punch 401S Car Audio...
What is the auctual watts fpr the Rockford Fosgate Punch 401S?
rockford fosgate doesnt have watts its considered monoblock it gives off watever the speakers want....it gives them the power they need
I have two pioneer champions that are pushing 1200 wats a piece, how much wat amp do i need to push out the whole amount?
most likley they are 1200 peak if we r talking about the same ones then they are 400 rms a piece a solid 800 rms monoblock amp will poundem
Aug 16, 2009 | Rockford Fosgate Punch 401S Car Audio...
Not a problem just a question
  • 100 watts RMS x 2 at 4 ohms
  • 200 watts RMS x 2 at 2 ohms
  • 400 watts RMS x 1 at 4 ohms in bridged mode
  • stereo or bridged mono output
  • 4-ohm stable in bridged mode
  • Tri-Way capable
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • 50-250 Hz high-pass/low-pass (12 dB/octave) crossovers
  • wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
  • MOSFET power supply and output devices
  • MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
  • TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
  • Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
  • NOMAD — advanced protection circuitry for "intelligent" shutdown protection
  • speaker- and preamp-level inputs
  • 11-1/8"W x 2-3/8"H x 9-7/8"D
  • Wire your sub in bridged mode (4 ohm mono)
    + to + on amplifier
    - to - on amplifier
    (using bridging terminals)
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Apr 25, 2009 | Rockford Fosgate Punch 401S Car Audio...
    Amp or something cutting out.
    Power caps store power from the battery and they feed constant power to the amp so you dont get no drainage! this could be one reason..
    have you bridged both subs and wat gauge wire are you using.
    these amps can only handle one bridged sub at 4ohms and this amp is recommended that u use 8gauge or higher. if your running to subs i normally reccomend using 4 gauge power wire as you get more rms power feed to the amp
    you can get a power cap or anyother accersory cheap online at my suppliers.. caraudiosecurity << click to enter >> hope this helps and please rate me :)
    Apr 22, 2009 | Rockford Fosgate Punch 401S Car Audio...
    Is it enough to power to 12 volge=ahagen 12oowatss dual 4 ohms
    your Volfenhag 12" subs are rated at 1200 watts they are only 600 watts rms and the Rockford punch p4004 is only 200 watts rms so the answer is yes it will work but if you get a amplifier that pushes out 500 - 600 watts rms you will love the sound from subs
    there is nothing wrong with the Rockford amp it just wont pound out the bass as hard but the good news is you will never blow the subs with it
    when buying amps or subs make sure to look at rms rating that is the true power they actually have ie. (sub box says 1200 watt you think powerful but if you divide it in 1/2 you actually get 600 watts rms) don't get me wrong that's a nice rating. for a sub but you will want to match that number with the amps rms rating or lower. The RMS is what makes the car pound the higher the RMS the better
    hope this helps
    Mar 05, 2009 | Rockford Fosgate Punch P4004 Car Audio...
    Rockford Punch HE2 wiring question.
    if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
    Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
    Rockford Fosgate Punch 401s starts then smokes
    Can somebody email me the schematic for the Rockford Fosgate 401S?
    Feb 04, 2009 | Rockford Fosgate Punch 401S Car Audio...
    Rockford Fosgate Punch 401S Car Audio Amplifier Logo
    845 people viewed this question
    Top Rockford Fosgate Car Audio & Video Experts
    seankane89
    Level 1 Expert
    hoyzee1
    Robert Rankin
    Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
