Question about Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX
I have used win7 os i have missed my motherboard driver model awrdacpi so i need a driver. physical memory 1gb ram. hd 80gb.
    Novelist:
    Champion:
  • 226 Answers
You need to goto the manufacturers website, find their support section and there should be a list of drivers for your specific machine. Installing these should resolve your problem. I have a list of links to most manufacturers drivers on my website.
Hope this helps,
www.PuterCare.com
Posted on Aug 08, 2010
I have a medianpc it has a awrdacpi mother board do i have to update bios to install windows7.And how do i do this?
I use Belarc software to get me the info of a System when labels and or am too lazy to open PC and physically view Motherboard Details so that I can figure out whether Installing a later version of an OS is possible.
Other factors to consider is Audio and Graphics drivers for it, i.e. are there any as well as is the cost of updating any or both those components worth the effort especially when more Memory might be needed and so forth.
To answer your Q regarding Upating BIOS, the answer most of the time is NO, just awrdacpi is probably not the motherboard manufacturer name or model but reference to the BIOS chip.
Best wishes.
Sep 17, 2014 | Microsoft Windows 7 Professional SP1...
Sys config: 80gb hd 2gb ram os:win7 animation are
Is everything quite slow? Sounds to me that your hard disk is almost full - check to see that there is 8gb (10%) free space The other possibility is that you have too much on the desktop (file size not number of files).
Oct 04, 2013 | Dell Computers & Internet
I have 2 questions:- 1. I have a hard disk of 80GB capacity.I want to augment my storage capacity with an additional Hard Disk of 500GB in the second slot of my CPU.Will my motherboard support that.My...
The motherboard has 2 memory slots with each slot allowing up to 1GB modules of DDR PC2700, DDR PC3200, DDR2 PC2-5300 with a maximum of 1GB per slot. Do not mix RAM speeds.
As for hard drives, the board has the capacity of:
PATA (Parallel) - 2 x ATA100 4 Dev. Max
SATA 1.5 Gb/s - 2
I would assume that the 500GB drive you have is a SATA drive. and the 80GB as PATA. If that is the case, then the two drives would be on different controllers and would work in the system. Typically, it is recommended that the SATA drives is the main hard drive holding your OS.
As always, you would need an open bay in your computer case as well as adequate power to the PWS to complete the installation.
Nov 19, 2010 | ASUS P5VDC-X Motherboard
I have one computer with E210882 intel motherboard..i was open this computer for replace the harddisk i connect one used hard disk now this computer is working but the audiosystem is not working picture...
> used hard disk
If you have installed a drive from another system, it probably has settings applicable to the system from which it was removed. The original system could well have had settings for a different audio chip and video resolution. You need to look at the device drivers for audio and video and make the changes needed so they apply to the laptop you have.
Nov 18, 2010 | Intel Motherboard
When I install vista os the blue screen appear in monitor(Dumping physical memory in disk). i used (...80gb sata HDD) ...
The operating system is not compatible with the physical configuration of you computer...
this is the reason...
install XP and install a tranformation pack for vista to have a glossy look of vista in XP...
Aug 22, 2010 | Intel D845GVSRL 533MHz FSB 845GV Chipset...
I was lost my motherboard drivers. Plz send information. this is my system configuration. OS Name Microsoft Windows XP Professional Version 5.1.2600 Service Pack 2 Build 2600 OS Manufacturer Microsoft...
go to the manufacturers website and download the drive for your mobo, if your internet doesnt work you may have to download them on another computer burn them to disc
Mar 08, 2010 | Intel D915GAG Socket 775 Motherboard -...
What ram to get.
http://www.memory-up.com/Memory_finders/DesktopSelector.aspx?modelId=14398
go here to see and buy. you can have two gigs, not three. no such thing as 1.5 gig chips.
Aug 23, 2009 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
Cannot see 4 gb ram
Hi Ciccio8670,
If you are running 32-bit Windows, you must live with it. You will not ever see all 4GB of RAM you've paid for.
If you are running 64-bit Windows, you may have to live with it. Depending on your motherboard's chipset, your system may support memory remapping. If so, you will be able to use all 4GB of RAM.
Detailed:
Due to an architectural decision made long ago, if you have 4GB of physical RAM installed, Windows is only able to report a portion of the physical 4GB of RAM (ranges from ~2.75GB to 3.5GB depending on the devices installed, motherboard's chipset & BIOS). This behavior is due to "memory mapped IO reservations". Those reservations overlay the physical address space and mask out those physical addresses so that they cannot be used for working memory. This is independent of the OS running on the machine. Significant chunks of address space below 4GB (the highest address accessible via 32-bit) get reserved for use by system hardware: • BIOS – including ACPI and legacy video support • PCI bus including bridges etc. • PCI Express support will reserve at least 256MB, up to 768MB depending on graphics card installed memory
What this means is a typical system may see between ~256MB and 1GB of address space below 4GB reserved for hardware use that the OS cannot access. Intel chipset specs are pretty good at explaining what address ranges gets reserved by default and in some cases call out that 1.5GB is always reserved and thus inaccessible to Windows.
Feb 13, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX Logo
64 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
