Question about Car Audio & Video
I need code for anti-theft lock - Car Audio & Video
    Problem Solver:
  • 5 Answers
The code should be on the back of the factory head unit.
Posted on Aug 08, 2010
Do you no the number to anti theft fuse for 2004 Chevy caliver
theirs no anti - theft fuse security system wouldnt be one if you could just pull a fuse
Jun 06, 2017 | Cars & Trucks
How do I reset the ProLock system?
Hi Carol , do you mean PATS passive antitheft system ? Locked up your car ,do you mean it won't crank over an start ?
The passive anti-theft system uses radio frequency identification technology to deter a driveaway theft. Passive means that it does not require any activity from the user.
  • During each vehicle start sequence, the ignition key identification code is requested by the vehicle protection anti-theft electronics.
  • If the key's ID code has been programmed into the system, the powertrain control module (PCM) (12A650) is signaled to enable the vehicle to start.
  • If the key's ID code is not programmed into the system, or if no encoded key is detected, then the powertrain control module is signaled to disable the vehicle.
The passive anti-theft system communicates the state of the security system to the powertrain control module via the J-1850 communications network data link connector (DLC). The powertrain control modulebased on the communications from the passive anti-theft system, will determine if the vehicle's engine is enabled to start. The passive anti-theft system differs from the active anti-theft alarm system in that the passive anti-theft system enables/disables the vehicle from starting and only operates with the ignition switch in RUN/START position. The active anti-theft alarm system has perimeter protection capabilities and operates only with the ignition switch OFF. Refer to Section 13-11A for active anti-theft alarm system information.
Vehicle Disabling The passive anti-theft system will be activated and disable the vehicle from starting if any of the following conditions exist:
  • damaged encoded key
  • unprogrammed key
  • non-encoded key (key has no electronics)
  • wiring concern
  • transceiver concern
  • Passive Anti-Theft System (PATS) control module concern
  • J-1850 Communications Network concern
  • Powertrain Control Module (PCM)
Apr 15, 2015 | 1995 Ford Taurus
NOKIA E5 ANTI-THEFT LOCK CODE FORGET
nokia e5 antitheft is locked and now asking for security code but i forgot so help
May 30, 2012 | Nokia Cell Phones
Anti thief device
Check the help links mentioned below :---Relearn Theft deterrent module? http://technoanswers.blogspot.com/2012/01/relearn-theft-deterrent-module.html
---------theft deterrent module Relearning? http://howtobyme.blogspot.com/2012/01/buick-theft-deterrent-module-relearning.html
--------Engine will not crank after relearning Theft deterrent module? http://howtobyme.blogspot.com/2012/01/engine-will-not-crank-after-relearning.html
--------Can car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
Car Factory Alarm will go off? http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html
---------Car will not start security lock out? http://technoanswers.blogspot.com/2011/12/car-will-not-start-security-lock-out.html
---------Alarm will not disengage? http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html
--------This will help.For more info keep updated.Thanks.
Feb 09, 2012 | 1998 Plymouth Voyager
Lights were left on killed battery then anti-theft light came on and now the car wont start do we need to reset the compter?
should be able to call the dearlership to get a code to reset the antitheft system unless u know it
Mar 04, 2011 | Saturn Ion Cars & Trucks
Anti theft activated-now car won't start and radio won't work. Radio won't take radio code and car cranks but doesn't start, horn blares, and headlights flash. I don't have the other code for the anti...
to turn off the theft system, all you have to do is put the key in the door lock and lock and unlock the door, this shuts down the anti theft system,now this has nothing to do with the radio, the only way the radio would ask for the code is if it was removed or the battery unhooked,anyway try the unlocking of the door even try the passenger door, hope this helps.
Feb 16, 2010 | 1992 BMW 5 Series
VEHICLE WONT START
Section 13-11: Anti-Theft System, Active 1998 Windstar Workshop Manual DESCRIPTION AND OPERATION Anti-Theft Alarm System NOTE: The system immediately monitors the ignition key lock cylinder upon removal of the key from the ignition. It is not necessary to arm the system for ignition key lock monitoring.
The anti-theft alarm system:
  • protects the vehicle from unauthorized entry into the passenger compartment, engine compartment and cargo area.
  • monitors the status of the ignition key lock cylinder.
  • is controlled by a remote anti-theft personality (RAP) module. The remote anti-theft personality module also controls the electronic door lock functions. Refer to Section 01-14B for more details.
  • when armed, detects unauthorized entry into the passenger compartment by using an input from the GEM module regarding the state of the door or liftgate (open or closed).
  • protects the engine compartment with a hood switch which is located on the LH cowl vent panel and is part of windshield wiper motor wiring (17A477) .
  • triggers an alarm if the ignition lock cylinder is forcibly removed from the steering column.
Once triggered, the system responds by:
  • flashing the low beam headlamps, the parklamps, rear lamps and the alarm indicator warning light emitting diode (LED).
  • sounding the horn (13832).
  • disabling the starter circuit until the system is disarmed.
Remote Anti-Theft Personality Module
  • The remote anti-theft personality module is located behind the instrument panel (04320).
  • It contains a radio receiver that receives the RF signal from the keyless entry remote transmitter (15K601) through the alarm and lock system antenna (15603) and sends the appropriate command to the power door locks, the horn relay, or the generic electronic module.
  • The remote anti-theft personality module is equipped with an internal backup power supply which holds the programmed code in memory in the event the vehicle battery is disconnected.
Remote Anti-Theft Personality Module Removal
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove radio. Refer to Section 15-01 .
  1. Remove lower instrument panel center finish panel. Refer to Section 01-12 .
  1. Lower glove box.
  1. Remove two remote anti-theft personality module bracket retaining screws.
  1. Disconnect electrical connectors and alarm and lock system antenna (15603).
  1. Remove remote anti-theft personality module and bracket.
  1. Remove remote anti-theft personality module from mounting bracket.
Installation
  1. To install, follow removal procedure in reverse order.
  1. Tighten remote anti-theft personality module bracket retaining screws to 6-8 Nm (54-70 lb-in).
Components The system is composed of the following components:
  • remote anti-theft personality (RAP) module with integral antenna
  • alarm indicator LED
  • door lock cylinder switch RH, door lock cylinder switch LH
  • liftgate door lock cylinder switch (220A40)
  • hood switch (part of windshield wiper motor wiring (17A477))
  • ignition lock anti-theft switch (19A438)
The following vehicle components are also used by the anti-theft alarm system:
  • generic electronic module
  • power door lock switch (14028)
  • door open warning lamp switch (14018)
  • autolamp relay (14N089)
  • horn relay and bracket (13853) and horn (13832)
  • low beam headlamps
  • rear lamps (13404) and parking lamps (13200)
  • starter relay
  • door lock relays
  • keyless entry remote transmitter (15K601)
Disarming an Untriggered System NOTE: A perimeter alarm will "shut off" after 165 seconds, but the system is still triggered and is not disarmed.
An armed but untriggered perimeter anti-theft system can be disarmed by one of the following four events:
  1. Unlock the doors by pressing the keyless entry remote transmitter (15K601) UNLOCK button once.
  2. Unlock any door with a key.
  3. Turn ignition switch to RUN or ACC.
  4. The remote entry PANIC button will disarm the anti-theft system only when the perimeter alarm is triggered and sounding.
System Triggering NOTE: Although the remote entry PANIC alarm is not associated with the monitoring of the vehicle, the user will frequently say that the theft system was triggered when actually the keyless entry remote transmitter PANIC button was inadvertently pressed. A panic alarm will not flash the THEFT indicator.
The alarm can be triggered by the following events if the system has been armed and has not been disarmed first:
  • Open any door or liftgate.
  • Open the hood (16612) (if the hood was open when the system was armed, it must be closed before it can trigger the alarm).
  • Dislodge the ignition key lock cylinder.
  • The anti-theft system may be triggered inadvertently when the module is disconnected and then reconnected. To avoid inadvertent alarm triggering, disconnect the smaller 22-way connector first.
When the system is triggered the perimeter alarm will operate as follows: The remote anti-theft personality module will pulse the following outputs at approximately 1.3 Hz, 50 percent duty cycle for two minutes 45 seconds for North America. NOTE: Other perimeter alarms can be programmed for the system.
  • parking lamps
  • horn
  • THEFT indicator
The perimeter alarm can be retriggered, after a perimeter alarm has sounded for 165 seconds. After a perimeter alarm has timed out, if any trigger input is first seen as normal and is then seen in its trigger state, the perimeter alarm will be retriggered. The perimeter alarm can be triggered a total of three times between an arming sequence and a disarm event. An active panic alarm will be deactivated when a perimeter alarm is triggered (a perimeter alarm overrides a panic alarm).
Mar 02, 2009 | 1998 Ford Windstar
Car won't start
Hi, does the alarm shut off when you unlock the passenger door?
If it does not I will give you a test that you can do.
1. disconnect the harness anti-theft control module. (loctaion depend were you live USA next to fuse panel Canadian models above the glove box.) Check the continuity between Light Green/Black wire and Black wire of the anti-theft control module.
2. Continuity should not be there with the door lock in, lock or neutral position. With the door lock in-between lock and neutral position (any door) continuity should be present.
3. If continuity is as specified replace the anti-theft control module. If continuity is not as specified, check operation of the door lock switches.I will add that test at bottom.
4. If the door lock switches are ok check the continuity og LIGHT/BLACK wires between anti-theft control module and door lock switches. Check Continuity of BLACK wire between door lock switches and ground. Continuity should be present if Continuity is not present repair harness or connectors.
5. If Continuity is present, check continuity LIGHT GREEN and BLACK wire of anti-theft control module. Continuity should not be present with trunk lock in lock or neutral position. With trunk lock in-between lock and neutral position, Continuity should be present.
6. If Continuity is as specified replace anti-theft control module. If Continuity is not as specified, check operation of truck lock switches. If necessary replace trunk lock switch.
7. If trunk lock switch is ok, check Continuity og LIGHT GREEN wire between anti-theft control module and trunk lock switch. Check Continuity of BLACK wire between trunk lock switch and ground. Continuity should be present. If Continuity is not present repair harness or connectors.
DOOR LOCK SWITCHES
Disconnect 4-pin door lock switch connect (left and right front doors) With door lock in neutral, full lock or full unlock position, there should be no continuity between any terminal and BLACK wire terminal. Continuity should exist between LIGHT GREEN?WHITE wire and BLACK wire terminals with door lock in-between neutral and full lock position. Continuity should exist between LIGHT GREEN/BLACK wire and BLACK wire terminals with door lock in-between neutral and full unlock positions. If continuity is not as described, replaced door lock switch.
Hope this help its a place to start. let me know if you need anything else.
Cheers
Aug 23, 2008 | 1994 Nissan Maxima
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
