Question about HP LaserJet P3005 Printer
The printer menu is showing ready but for printing the document then shows the panel is 52.00 error
  • HP Master
  • 1,121 Answers
Laser scanner faulty, replace it no advise for repair
Posted on Feb 03, 2012
  • 990 Answers
SOURCE: HP4000 not printing LPT1
Dear sir;I believe you can try " cold reset", that's means going to clear all data from the printer memory and sets all the defaults back to the factory settings.performing a "cold reset" resets the jetDireect configuraion. to avoid making changes to yourconfiguration, remove the jetDirect card before performing a cold reset. if possible, print a configuration page prior to performing a cold reset. this will document current settings for later reference.
to perform a cold reset;
1, turn off the printer.
2, while pressing "go", turn the printer on. COLD RESET appears briefly on the display, then INITIALIZING appears.after a few seconds, RESTORING FACTORY SETTING appears on the display, followed by OFFLINE.the cold reset is complete.
3, press "go" to return the printer online "ready " appearson the display.
Little bit complicated but is easy ,hope can take care your problem, GOOD LUCK! Let me know the resolve please!
HAVE A HAPPY HOLIDAY !!!
Posted on Dec 18, 2008
md_ehsan_1
  • 255 Answers
SOURCE: Printer installed correctly however will not print.
1. uninstall your printer
2. restart your system
3. re install your printer
4. after installation take a test print
5. hope this will correct your problem..
6. otherwise, run Advance system care to fix your computer problems, such as registry errors etc., due to some registry problem are some other problem in your software makes like this problems.. download from the following link..its a freeware software..download it and install it, Press CARE to start the program.
Advance system care (registry cleaner)
http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html
Posted on Jun 22, 2009
  • 3741 Answers
SOURCE: print spooler not running
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
thanks.
Posted on Jul 11, 2009
  • 63 Answers
SOURCE: Jobs don't print, though printer is ready
This printer is notoriously problematic and you may be better off getting a new printer. We had one of these and it only lasted about 1 year before the same problems occurred. We trashed it after fighting for a while.
The problem is with the printers formatter. Unfortunately, if it is out of warranty, you are out of luck as a new printer is probably less expensive than the fix. Here is a forum regarding this issue on HP's website.
HP 3005 Issues
I would contact HP directly to see if this machine can be fixed. Sorry to break the bad news and I hope you find a solution soon.
Posted on Mar 02, 2010
Testimonial: "Thanks so much for the link to the issues. Having that is invaluable to getting support."
Rider On Way
  • 1679 Answers
SOURCE: PRINTER IS ALWAY SHOWING IN OFFLINE MODE
This link will be helpful for you
http://www.fixya.com/support/r5095488-unable_print_hp_printer
Posted on Jul 06, 2010
My printer HP laserjet P2015, have a problem that no error light blink ready status light on (GREEN) but no test print out and nor other printing by USB cable from computer. Please advice about this i
May be cable loose or heavy dust available in printer that`s why your printer not proper response it. Or may be printer main board damage position so i suggest you contact it printer technician or checking it, which area damage.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01764440&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=3811075
Thanks,
HP Printer Support
May 15, 2014 | HP LaserJet P2015 Printer
Hp 2600 no longer prints from my laptop
Hi Friend,
I think One time uninstall printer software and restart laptop and installation before clean the virus in laptop then install printer driver. If any error show in installations time then antivirus sort time disable. And software full install then proper check it printer driver show in control panel. If problem same then change printer cable connector.
If then not solved then finally you check other OS laptop may be find error.
Thanks..
Jan 14, 2014 | HP Photosmart 2610 All-In-One InkJet...
Panasonic KX-P7110 printer won't print from the auto feed tray, shows error when printing is attempted.
Please check the entire length of the paper feed path from input to output for a small piece of paper that is stuck causing a "Paper Jam".
You are lucky that you can still print manually as this usually shuts a printer down until the jam is found and removed!
Good Luck!
Rich Lilja
Jan 06, 2014 | Panasonic KX Office Equipment & Supplies
The printer is not working, toner is always showing low toner and not give the print.
hello try to do this
press menu#1934 and right arrow key disply show ready tech
press menu button and press left arrow key
display show new cartridge.press enter button twice. then restart your printer.error message didnt display
Aug 31, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Mfc7340 will not print--it was working just fine and then it errors out. Uninstalled and reinstalled and it shows ready but errors out
Hello ,
First, please make sure there is no error message displayed on the LCD screen of the printer
Now we will check the status of your printer in the printers menu in the control panel.
The printer’s status should be set to “ready”
If the printer is “paused” simply clear the print queue, right click on the printer and select “resume printing”.
If the printer says “offline”, follow these steps.
  1. Clear the printer queue
  2. Shut down the computer
  3. Unplug the USB cable from your computer and your printer
  4. Unplug the power cable from the printer and wait 15 seconds
  5. Plug the USB cable back into the printer and the computer.
  6. Plug the printer’s power cable back in.
  7. Turn your computer back on.
Your printer status should be back to ready now and you are able to print.
Thank you,
Mar 26, 2010 | Brother Office Equipment & Supplies
No printing, printer says ready, will test print from menu button
Go to my computer, click on control panel, click on printer/fax and see what is set for default. What ever printer icon that says ready, right click and set as default.
Mar 11, 2010 | HP LaserJet 4 plus Printer
SHARP AR-5320 is not printing. it is connected by USB. It is showing ready and when i give print command it shows that the document is printing and there is some action with the printer but the print...
remove driver from control panel,disconnect USB restart pc insert cd ,install again ,when pc wants to connect copier,do this and wait to complete.your cassete size must be same as your print size
Mar 05, 2010 | OCE 3140 Copier
Document failed to print" message
Hi go into settings on you're printer & clear the pending queue it will not print till u delete them ..cheers
Jan 18, 2018 | Dell 1600n All-In-One Laser Printer
Won't print document
i believe this is a usb printer if so if you have turned off the pc you may need to go into the printer and faxes part of the start menu and open it up go to properties and make sure that the printer is set to print online not offline and usb connections can sometimes reset otherwise go to the control panel and see how many times your printer is listed delete all but the one that is listed online and try printing from that one set it as default
best luck
Aug 27, 2008 | Lexmark X4270 All-In-One InkJet Printer
Green ready light on, but will not print
When you refilled the paper, did you load a different size paper? Try this: on your PC, left click on START, then left click on CONTROL PANEL. Next, left click on PRINTERS. Find your BROTHER on the printers page and view the status box. Does it show READY? Are there any DOCUMENTS pending? Left click (you may have to click twice)on the BROTHER icon. The PRINT QUEUE appear, showing any documents waiting to be printed, and their status. If anything is in the queue, cancel all documents so the queue is clear. Next, RIGHT CLICK on the BROTHER icon . On the drop down menu,left click on PRINTING PREFERENCES. Make sure the settings match the paper you have loaded in your machine. If something is not right (Paper size, orientation,etc) the machine will not print. Carefully check all the settings and correct as necessary. To test, first click OK to exit PRINTING PREFERENCES. On the same menu, left click on PROPERTIES. On the GENERAL tab, left click on TEST PAGE button to generate a test print.
Aug 09, 2008 | Brother HL-2040 Laser Printer
HP LaserJet P3005 Printer Logo
41 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
