Question about Sony Playstation 3 (PS3) Console
Ps3 disc wont eject at all. have tried holding it in horizontal, vertical, diagonal and upside down positions but still wont eject.
    Novelist:
  • 105 Answers
Hi, i'm assuming you have a phatty PS3. Let's try this:
  • - turn off the ps3 with the main switch, behind the console
  • - press the EJECT touch-key on the front, HOLD on it while you turn on the console with the main switch... keep holding the eject key, if it'll work you'll get your disc out.
  • - If it won't work just try a couple of times more then if you don't succeed please advise me with more information about your PS3 model and I'll try to bring you other solutions :)
Regards, Peter
Posted on Aug 08, 2010
  • aikimoe Sep 04, 2010
    Hi Peter, I was having the same problem and tried your solution. When I did as you described, the fan blew really hard for about 20 seconds and then the system turned off, the red light blinking again. I am able to eject discs when the system is on, but only by holding down the eject button for 15-20 seconds. This happed before, but then stopped, and is now happening again. I have an 80g model I purchased about 3 months before the slim was released. Thanks!
Disc Stuck In 60G Console
  • Press the "Eject" button on the PlayStation 3 console and hold it for at least 10 seconds; if your PS3 has the "force eject" feature included it will eject the disc regardless of whether the console is frozen or not. Turn off the console and turn it back on before inserting new discs.
  • Unplug the power cord and any other cords from the PS3 console if the "force eject" feature does not work and you own a PS3 Slim. Turn the console upside down so that you have access to the bottom of the console.
  • Locate the small compartment door on the bottom of the console. Remove the door by pulling it up and off the console; a blue screw and a small hole should be visible inside the compartment.
  • Insert a Phillips-head screwdriver into the hole. Turn the screwdriver in a counterclockwise direction to manually eject the disc. Once the disc is removed, replace the compartment door and turn the PS3 console back to its correct position before reconnecting the power cable and any other cables you previously removed.
  • Jan 29, 2012 | Sony Playstation 3 (PS3) Console
    Game disc dosent pop up and when click on stuff it freezes
  • 1
  • 2
  • 3
  • 4
    Console won't eject disc or shut down
    Same thing happened to me a while back. First try unplugging the Wii for 30sec-1min. Then plug it back in, turn it on, and then hold the eject button for 10 seconds. If that doesn't work try it again with the Wii in a different position. (Horizontal instead of vertical or vice-versa). If that doesn't work it might be a disc drive problem and it might have to be sent to nintendo.
    http://www.nintendo.com/consumer/webform.jsp
    This is their service site. Hope it helps!
    Mar 02, 2011 | Nintendo Wii Console
    The wii is giving the message "unable to read
    • This message can display if you eject a disc during game play. If this is when the message displayed, make sure that you return to the Wii Menu before changing discs if you wish to play a different game.
    • If your Wii console is laying flat, it may be positioned upside down. Ensure that is positioned right-side up: the game disc slot should be above all three buttons and the SD Card slot.
    • Ensure that you are properly loading a Game Disc.
      • If your console is placed vertically, the disc label will face to the right.
      • If your console is placed horizontally, the disc label will face upwards
    Dec 29, 2010 | Nintendo Wii Console
    Wii cant read disc hod i fix it
    Hello :
    1:This message can display if you eject a disc during game play. If this is
    2:If your Wii console is laying flat, it may be positioned upside down. Ensure that is positioned right-side up: the game disc slot should be above all three buttons and the SD Card slot.
    3:Ensure that you are properly loading a Game Disc.
    4: your console is placed vertically, the disc label will face to the right.
    5: If your console is placed horizontally, the disc label will face upwards.
    6:If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc .
    good luck .
    please don't forget to rate !
    Apr 04, 2010 | Nintendo Wii Console
    Could not read the disc.for detail read the console manual
    Hello :
    Good luck .
    rate please !
    Mar 26, 2010 | Nintendo Wii Console
    We turn the console on and start playing....but after 5 or 10 min the console showes a black screen with this message on: this disk cannot be read please reffer to your operations manual.
    Hello :
    1:This message can display if you eject a disc during game play. If this is when the message displayed, make sure that you return to the Wii Menu before changing discs if you wish to play a different game.
    4:If your console is placed vertically, the disc label will face to the right.
    5:If your console is placed horizontally, the disc label will face upwards
    Contact if that didn't help please !
    rate if useful please !
    best regards .
    Mar 21, 2010 | Nintendo Wii Console
    My Wii will not not read Wii disc's...HELP
    Hello :
    good luck .
    rate please !
    Mar 20, 2010 | Nintendo Wii Console
    Ps3 jammed disc
    Unfortunately their is no step by step or guaranteed method to fix this. Here are a few things you could try: turning it off and on, press/hold the eject button, resetting while holding the eject button, shaking or tapping it a little while trying to eject it, holding it different ways ex. face disc opening down towards floor while gently tapping and pressing the eject button. Essentially do whatever you can to get the disc to jar loose, >but whatever you do, don't for any reason stick anything in the slot or try to open the case <Doing this will void the warranty for sure! If none of these work your last resort would be to return it for a new one (providing you still have your receipt and it's less than a year old) or take it to a costly repair guy.
    Jan 26, 2008 | Sony Playstation 3 (PS3) Console
    PS3 Blu Ray Drive won't eject
    open that **** up,have similar problem,mine was caused because of a sticker on a dvd, couldnt find my warranty,and force eject wouldnt work,i was afraid to open the bluray drive completely,just to the point where i could manually eject the disc and found a round sticky mark on the disc,the sticker is probably still in there,but keeping the ps3 horizontally seems to help,your problem however could involve with the thingies in the driver not being propperly alligned
    Jan 20, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    249 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
