Question about Cell Phones
How do I store phone numbers into my Uniden phone
  • 146 Answers
Its not avalible for low end models
Posted on Aug 08, 2010
Storing numbers
Select the model of your phone from the list at
http://uniden.com/index/manuals_results.cfm
May 10, 2010 | Uniden 5.8GHz Dual Cordless Phone
How to store phone numbers to dial out on the handset?
Since you declined to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
May 17, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Need to erase numbers stored on speed dial
Go to uniden.com and look in customer service/manuals. They may have it to download. You'll need the model #
Mar 26, 2009 | Uniden Cordless Phone
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
Uniden Model EXP7900 How do I program button m1
One-Touch Dialing
Your phone is equipped with three .One-Touch Priority. keys for
instant dialing (m1, m2, and m3). You cannot store phone
numbers directly into m1, m2, andm3. They are only used
to dial phone numbers stored into memory locations 1, 2, and 3
on the keypad.
1. To instantly dial phone numbers stored in memory locations
1, 2, or 3, simply press m1, m2, or m3. (There is no need to
press talk, the phone will automatically dial.)
2. If no phone number was stored in memory locations 1, 2, or 3
on the keypad, pressing m1, m2, or m3 will do nothing.
I hope this helps.
Rollin CBs
Dean
Nov 04, 2008 | Uniden Cordless Phone
Cannot edit stored phone numbers
goto phone book hit menu find the number and or persons name you want to edit edit the number hit ok to get to the number or you can do the easier way
delete there name and number and put it back in with the right digits
May 30, 2008 | Uniden Cordless Phone
Unable to Store Phone Numbers
The store memory function is very similar to this phone in the EXA series phone made my Uniden.
See the instructions to store/delete/add numbers in the manual below on page 22.
http://www.uniden.com/pdf/EXAI2248Iom.pdf
hope this helps
- Pete
Jan 31, 2008 | Uniden Cordless phone EXS9950
Speed Dial for a Uniden Model DCT648-3
Do you have a copy of your owners manual? If not, here is a link to a pdf format version of it, from the Uniden website:
http://www.uniden.com/pdf/DCT648-3om.pdf
Speed Dialing
If you store a phone number in a speed dial memory location (10 locations: SPD1 - SPD0),
you can use the speed dialing feature. When the phone is in standby mode, press and hold a
number key (0-9) associated with the speed dial until the phone number appears and then
press talk/flash or speaker. The number stored in the speed dial (SPD1 - SPD0) is dialed.
Nov 30, 2007 | Uniden DCT648-3 Cordless Phone
Storing numbers in memory
1) Pick up the handset and press the STORE button
2) Dial in the number you wish to store
3) Press the STORE button again to indicate that you have completed the number
4) Press the location where you want to store the number (i.e. 1, 2, …9, or 0)
Oct 21, 2007 | Uniden EXP4241 (050633300466) Cordless...
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
