Question about Fujitsu AMILO PC Laptops
Laptop memory iv recently upgraded my memory to a 2g it was a 1g but only running on 766mb , iv put the 2g memory in restarted the laptop and its still showing the memory is 766mb can you help me in any way , the laptop is a fujitsu amilo li 1705.. many thanks kerry..
    Genius:
  • 3,587 Answers
Hmmm..ok...try them one at a time, and make certain that the laptop can id each of them. if that works, swap them in the sockets..if that does not work, then one of your sockets is unhappy.
also, use F2 when loading up, and see if memory is present in system setup screen..be careful in there, of course, since it's the nerve center of that whole computer.
Posted on Apr 27, 2008
Constant beeps
this laptop can take 4G ram http://www.crucial.com/upgrade/Gateway-memory/M-1000+Series/M-1625-upgrades.html
if the memory modules are not from the same brand range, this can often be the issue.
it SHOULD be able to run with just 1 2G module but will run better with 2 1G rather than the single, assuming it's the right type for the machine.
If I'm upgrading pc memory, I remove the old and replace with Crucial or Kingston kits so as not to mix brands and ranges.
Apr 13, 2013 | Gateway M-1625 Notebook
I upgraded my memory RAM 2g and added 1g so it makes a 3G of ram but how come when my pc boot up up i can only see 2G ram single chanel. wen i go to my my computer----properties----general under computer:...
Could you please go online and in a search engine type "MAX RAM E-Machines (here put your model #)." Pick a link that secribes your maxi,um ram and if it's only 2GB you'll have your answer. If the max is higher there should be instructions on how to set the computer to acess and show the RAM.
Regards,
Selk
Nov 19, 2010 | E-Machines eMachines Desktop PC
Wha t is the memory upgrade;how much acer 3000
Your memory that is in this is SO-Dimm 333 MHZ pc2700 and newegg has 1G sticks for about $40 each. So you probably can get 2 of them with a max of 2G for your laptop.
Nov 03, 2010 | Acer Aspire 3000 Notebook
Ram upgrade problems
looks like you have the wrong ram for your system Kingston is showing this for your system KVR667D2S5/2G
but try refreshing your bios i doubt it will work but give it a shot with your ram installed just hit F2 to get into bios when starting your computer save and exit that should refresh it
Nov 03, 2009 | ASUS Eee PC 900HD Netbook
My computer will not boot up when 2 g ram
Try upgrading your Bios first, also make sure that the memory that you ar putting in your Laptop is type PC-2700. Other than this, I know that this comptuer has a 2G limit and should have no problem with it.
Sep 06, 2009 | Compaq Presario R3000 Notebook
Upgrade to 2g memory
If its a desktop it should be fine with two 1 gb sticks. Check to see how much ram is being shared for video. You can see that in the bios setting. Not sure how much can be shared but it may read differently depending how much system ram is being shared for onboard memory.
Sep 03, 2009 | Compaq tc4200 Tablet PC
I own the asus 901
I assume that you are referring to the maximum memory of this computer. It is only 1 gigabyte, not upgradeable to 2.
Nov 29, 2008 | ASUS Eee 4G Notebook
Toshiba laptop problem
The right memory for your laptop is
256MB Memory (PC2-4200) KTT533D2/256, PA3389U-2M25 KTOS534
512MB Memory (PC2-4200) KTT533D2/512, PA3412U-1M51, PA3412U-2M51 KTOS535
1GB Memory (PC2-4200) KTT533D2/1G, PA3411U-2M1G KTOS536
Using the wrong memory can caused motherboard failure.
Try reinserting the old one memory module.
Be sure that the memory is placed in the right way
Nov 06, 2008 | Toshiba Satellite A135-S2386 Notebook
IBM ThinkPad T40 2GB Max RAM
The T40 has two ram slots, you can put a 1g chip in each totaling 2g. If the chip will remove, then it is changeable. Vista needs a minimum of 256 to run, so, when you change BOTH chips to equal 2g it will probably read 1.744g, or it may read the full 2g. If it only reads 1g, then the second slot under keyboard may have malfunctioned. It could also be that the 256 chip is bad and your really only running 512 now. With all that said, in order to achieve 2g, you will need to put a 1g chip in each slot.
Jul 08, 2008 | IBM ThinkPad T40 2373 Notebook
Laptop memory
wrong type(brand) of memory some laptops are very fussy about what type of sodimm you put in them, I would put the 1 gig back in since it is more than the 766mb your getting with the new memory.
Apr 27, 2008 | Computers & Internet
Fujitsu AMILO PC Laptops Logo
178 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
