Question about Microsoft Computers & Internet
How can i change the arial font size to 110 at microsoft excel 2003
  • 748 Answers
Instead of clicking the pulldown icon to choose a predefined font size, click the white box containing the number itself, and type in the desired size and press Enter.
Posted on Aug 08, 2010
Microsoft Excel Font issue Tahoma Arial
Hi this is kaira am expert to help you to fix this issue for you,kindly call me on +1(518)348-9393 and we will be glad to help you.
Aug 21, 2017 | Microsoft Computers & Internet
Tip
TOSHIBA DVD REGION FREE HACK METHOD.
1. Power on.
2. Open tray.
3. Push the info on remote once (with supplied remote). You will see numbers.
4. Press 9 for multi-region. Keep trying until you see the number 9 appear in upper left corner.
5. Power off.
Power on.
on May 21, 2012 | Toshiba Televison & Video
Tip
Common Projection TV Problems and Fixes
In this article we will will outline some of the most common projection TV problems, fixes, pros and cons, and average lifespan.
Average Lifespan: 7-20 YearsPros: Large screen size and excellent picture quality. Some model support HD. Very reliable when they are cared for.
Cons: Heavier and bulkier than the newer plasma or LCD sets so if you live in a cardboard box it may take up a bit more room.
Common Problems/Fixes
Common Problem #1 - Convergence: One the most common problems that you will run into eventually is a convergence failure. This is when the TV colors do not align anymore and the TV will look 3D, warped or distorted. This is a very common problem and a fairly simple DIY fix. Parts to repair this can be found over the internet from sites such as www.TvRepairKits.com . Below are a few photos of a typical convergence problem and a link to a video on YouTube with more details.
utube.png You-Tube video "9oI1Nzq7CR8" placeholder (do not delete) utube.png
Notice how the image looks 3D...this is a classic example of a convergence failure...it may also look warped or have a wave look. But the wave will not fluctuate.
Common Problem #2 - Dull or Dark Video
The second most common problem we see on projection TV sets is whats known as the dull video issue. This is commonly caused by discolored cooling fluid in the lenses. Over many years - usually around 5-7 years - the fluid will discolor and cause the video to wash out or look dull. Changing the CRT fluid out every 7-10 years will restore the image clarity back to factory new conditions. You will actually be amazed at how sharp and clear the video looks once a fluid repair has been done.
Here is a before and after photo notice how it looks washed out. In some cases the images will look like they have halos around them or the screen will have a reddish tint. Bottom line - if your projection TV has never had the lens fluid replaced the video is not as sharp as it can be. You can get fluid kits from the same sites mentioned above. Doing this repair yourself or through a shop will make the video look amazing.
After a fluid replacement
Common Problem #3 - Dead set with no videoIn these cases there can be more than one common issue depending on the TV brand and model. But to make things simple if the TV has no audio or video and its making a constant chirping sound the issue is caused by a short in the convergence. The fix is to do a convergence repair. If however its not chirping constantly it can be one of many issue from failed capacitors, diodes, flybacks, etc.
on Apr 25, 2012 | Televison & Video
Tip
System Restore for Windows 7
1. Open the Start Menu.
A) Click on All Programs, Accessories, System Tools, and System Restore.
2. Open the Control Panel (All Items View).
A) Click on the Recovery icon.
B) Click on the Open System Restore button.
A 'System Restore' window will appear. Here you will have to check "Restore computer to an earlier time'
A) Click on the Next button
Now you will find a window with Dates, Description and Type,
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start. Click on the Finish button and windows will take a reboot.
on Nov 02, 2011 | Microsoft Computers & Internet
Tip
Flash From a Cameras on 3 Phase UPS
Possible interruption to customer load due to Photo Flashes. While testing a new service, we hope to be offering soon, the Dallas based engineering department has discovered that the use of a flash camera in or around the UPS may cause a fault in the unit that could result in the loss of power to the critical load. We have noticed two different scenarios: 1. While taking a picture of the inside of a running unit in the test lab, the flash affected the firmware,
resulting in a lock up. The unit did not transfer, it just shut off! 2. At an actual customer site, prior to doing a PM on a number of units, we wanted to test the new Thermal cam. Part of the test involves taking a digital photo. Upon turning the digital camera on while standing next to a UPS, the RF of the flash charge circuit was enough to interrupt the inverter drives. Fortunately, the unit did successfully transfer to bypass, but only after the loss of a few fuses.
on Oct 21, 2011 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
