My simpson 175 dual action agitator is agitating, loading and discharging water but sometimes fails to spin.I have to reset by pressing the button behind because the power is sometimes cutting off once the spin won't happen. Can you help me with this problem, please?
  • Ryan Aug 11, 2010
    The solution that was provided by one expert does not convince me. I always use the normal mode and I always rebalance the wash tub but the defect of my washing machine has never changed. I suspect there are loose parts inside like the connection of the agitator and the washer motor but I don't have any idea how to troubleshoot it. Can any expert help me with this?
  • 12,061 Answers
This is happening because the load is unbalanced, try evening out the load all round the bowl. Then the protection switch won't be tripped... Also make sure it is sitting flat and even too.
Posted on Aug 11, 2010
  • Ryan Aug 15, 2010
    My load is always balance and my machine is sitting flat but the problem still persist
    Brigadier General:
  • 3,513 Answers
Hi
You may have selected Drip Dry. If so, remove any drip dry items and select Normal with the Options control to restart the program. Otherwise, the wash load may be out of balance, rebalance the load and close the lid. You should check these points thoroughly and also that the machine has been installed according to the Instruction manual, before calling for Service.
http://www.simpson.com.au/faq/search?category=Washing+Machines
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 08, 2010
  • Ryan Aug 10, 2010
    I always selected the Normal option so the dip dry issue is out of the question and I always rebalance the load when that problem is happening but it still keep on repeating. I have to put my washing machine in standby for more than an hour so that it will spin again after the reset. Do you have further solution?
GE washer WNSB9080B only allows me to run "Drain and Spin", no other cycle. It wounds like there is still water inside when I move the drum around.
In top loading washing machines, the agitator is responsible for moving the clothes through the water and detergent and is driven by the output shaft of the transmission. The output shaft is normally splined and the center of the plastic agitator will have a matching spline to ensure a tight fit. Depending on the brand of washing machine, the agitator may be a single piece unit or a two piece dual action agitator. If the single piece agitator or the lower portion of a dual agitator does not oscillate back and forth during the wash cycle, or if the agitator can be turned on the transmission shaft, then the spline may be damaged and the agitator may need to be replaced. Most agitators are held in place with a bolt that threads into the top of the transmission shaft and is located below the softener dispenser or top cover. Some models use a small set screw in the barrel of the agitator just above the base to secure the agitator to the shaft, while some will use a rubber o-ring to provide a tight fit. When the retaining device is removed you should be able to lift the agitator from the shaft.
Jul 18, 2016 | GE Washing Machines
Hi, we have Simpson top loading washing machine model number Esprit 550, the drum is not rotating and the spinning plastic rod in the centre of the drum is not spinning/rotating either
that is a direct drive
is the agitator (plastic rod )loose or sloppy
if you look down the inside of the agitator
do you see a nut at the base holding the agitator tight
if the timer is working
and water can pump in and out
that is good
bad
if you cant hear the motor click in
it will need to have the inspection cover taken off
for service or part replacement
May 20, 2016 | Simpson Washing Machines
Simpson agitator
This is usually caused by a faulty capacitor failing that a broken cluth pawl
Sep 26, 2017 | Simpson Washing Machines
Washer wont agitate or spin
Aug 03, 2017 | KitchenAid Washing Machines
Simpson 175 shorting out
there are 2 items that come into play when the wash cycle starts 1 is a capacitor for the motor and the other is the module that works the agitator.. The module when it fails will not spin the motor so I seriously suspect that the capacitor has failed giving you a direct short to earth
Jun 01, 2013 | Washing Machines
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
Kenmore 92587400... The dual action or top portion is not spinning
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92587400
I assume that you mean that the top agitator is not.
See the section of the Sears site for Agitator, Basket and Tub.
You'll see an item #5 "Clutch, Agitator". These are basically used to allow the top agitator to move only one way. If they are worn (which happens since they are plastic parts) the top agitator may not move either way.
There is also a part #6 "Agitator Auger" that screws into the main agitator shaft from the transmission. If this is loose, the top agitator may not move either.
Both of these are easy to check and repair.
Sep 28, 2009 | Kenmore Washing Machines
Simpson washer 22S950 not spinning..not agitating..water pump works...L6 come on the screen...bipps most of the time...part of numbers missing on the screen..
simpson washer 22S950 not spinning..not agitating..water pump works...L6 come on the screen...bipps most of the time...part of numbers missing on the screen..
Jun 22, 2009 | Washing Machines
Simpson 175 HD washing machine Programme keeps stopping Is it the timer or some other problem
image_bubblequestion_04.gif Can you please identify the problem with my washing machine?It appears all the functions of my simpson 175 washing machine work normally except the agitator only moves briefly and harshly for between 1 and 2 seconds.
Simpson 175 HD (Dual Action Agitator) Washing Machine.
1517 5M40 A 28 June 1990
Jul 12, 2008 | Washing Machines
Wont spin or agitate
Not sure what you mean? if you have normal wash action then it is agitating in the wash cycle.  Otherwise if it doesn't agitate or spin but does fill with water then your motor or motor control board is bad.
Oct 27, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
