Question about Refrigerators
I punctured the freezer with a knife moving ice I put silicone on the small hole will the freezer work
    President:
  • 2,030 Answers
As long as you did not cut a wire or refrigerant line it will be fine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 08, 2010
Testimonial: "OK this was helpful i will see by in the morning if it works thanks"
I put a knife puncture in my tru cold refrigerator, freezer combination in the freezer part
Is the freezer/ refirdge still working? If everything is still working, then the puncture did not cause damage to any great extent. Just place a piece of aluminum duct tape of the puncture hole. You can purchase the tape in a hardware store or Home Depot/Lowes, in the plumbing, heating dept. If the refridge is not working, then there is a major repair to be done.
May 05, 2014 | Refrigerators
Is it possible to repair a small puncture in the freon line inside a small fridge
The hole can most likely be fixed with epoxy and a filter drier added to the refrigerator by an experienced refrigerator technician but the problem involved will be the cost to have the repair done. It would be less expensive to replace the refrigerator, Thanks Sea Breeze
Dec 04, 2012 | Haier Black and Decker 2.7 Cu. Ft....
The freezer part of the fridge used to work so well n ice would form in a few minutes of switcfhing on the fridge. but now, ice rarely forms and ice cream simply melts. what could be the prob
Cause of that problem is a clogged in the tubing system, if your refrigerator is 5-10 years old it is a candidate for that problem. But if the refrigerator is newer, few years old then be sure the evaporator has no small hole or punctured cause by sharp object when removing frozen thing on it. Inspect it visually if you haven't found hole in evaporator then a system is clogged.
Thanks for asking.
Sep 01, 2011 | Refrigerators
Water flowing into refrigerator. Ice build up behind freezer back wall. Will clearing ice from drains suffice or do I need a new heater? Foam drains to fridge are open. There is a small hole under...
hello again,
part 2 of the answer,the metal pan is the drain in the center of it is where the drain is blocked,the foam vents are the vents where the air from the freezer flows into the fresh food compartment,GENTLYclear that small hole so as not to puncture the tubing in the coil above it,or you will loose all the refrigerant(freon) an dthe ref, will be dead
Gene
Aug 09, 2011 | Roper RT16DKXK Top Freezer Refrigerator
Whirlpool fridge freezer stopped making ice
Make sure the freezer plug cord has power on the outlet. Also check the thermostat control if working, in desired settings especially in low degrees, it should have some freeze. If not, then thermostat is defective.
See to it that the evaporator has no dent, punctured cause by sharp object ( knife, screw driver, etc.) when removing frozen food or drinks. If it has small hole, it will cause refrigerant to evaporate hence freezer will stop making ice.
A defective defrost timer will also cause that same problem. You will know it by dialing the knob, it should smooth and no friction and if it has failed to go back to original position.
Thanks for asking.
Jul 03, 2011 | Whirlpool Refrigerators
Ice built up in my small kenmore fridges freezer and i was chippin it and made a hole and cold stuff came out will my fridge still work
You most likely punctured one of your tubes, letting the freon escape. If that is the case, the system must be repaired and recharged for it to operate and cool. Running your compressor without refrigerant will cause damage. Pull the plug, move the food, and have a repair person look at it. All hope is not lost; the tube may be repairable and the system recharged. It would pay to have the repairs estimated. Small fridges will be close in cost to repair or replace.
Best luck to you,
--W/D--
Jan 16, 2011 | Kenmore Refrigerators
My GE refrigerator Model TBX18SA is draining condenste water at the bottom and also inside.How to get rid of it ?Thanks.
That happened to us on our freezer side by side. Pull out whatever is in the bottom of your freezer, a shelf or a basket. Look on the floor of the freezer toward the back. You should see a small dime or nickle sized hole that may be covered in ice. It should have a cover on it with small holes. Check that nothing is blocking that hole. Something has probably fallen on top of it and has blocked its ability to drain thru the hole into the drain pan under the fridge when the defrost cycle comes on and the melted ice can't drain down properly. We used a hair dryer on low to carefully melt the ice that had formed on the bottom to find the drain. Sure enough a small piece of plastic wrap was blocking it. We removed the plastic and continued with the hair dryer til we could pour water in the hole and it flowed freely to the drain pan and didn't continue to back up into the freezer floor.. Be very careful with the hair dryer, put it on lowest setting and keep it moving back and forth, don't hold in one place, or it could melt or warp the plastic sides of the fridge. When the hair dryer is on low, put your hand about a foot in front of it and it should feel warm not hot. Move your hand forward til you feel the air is just warm, this is the distance you want to keep it from the ice you are melting. As the ice melts use a small towel to mop up the melted ice as you go. Good luck
Aug 03, 2010 | GE J Series 18.2 cu. ft. Top Freezer...
Punctured gas line/ uses R-12
not very easily. Most freezers have the evaporator and condenser inside the wall of the cabinet and you cannot access them. If the puncture is in the condenser you can put in an exterior condenser however the parts break down for your model does not offer this option (:
Apr 08, 2009 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
REPAIR or REPLACE?
OMG ROFL!!!
Well... here's an idea.
Drill a 1/2 inch hole where you punctured the wall of the freezer, make sure you don't hit the coils. Then goto lowes/home depot and get that expansion foam that is used to insulate windows and holes in houses. Grab a razor blade and scalp off the excess after it's dried. Now cover the foam on the inside of the freezer with 2 part epoxy or "shoe goo" or e6000 (these are the toughest glues I have ever used) which is available at a hobby shop. Make sure you do a test with the foam and the glue on cardboard first to make sure the glue won't eat at the foam.
Are you sure you punctured the coil? If you did you can goto an auto part place and ask for a compression fitting (most commonly used to repair brake lines on cars) for what ever tube size the coil is, use a fine ruler is the best. Then you can repair the coil by using a pipe cutter to cut the coil and put it back together with the compression fitting. Now call the appliance service guys and have them come out and recharge the system.
Fixed, total cost... about $50 bucks
Other solution, replace entire fridge, total cost $$$$$
Sep 04, 2008 | Thetford Norcold® Model DE0061
Refrigerators Logo
640 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
