Tv-dvd connections we just bought a samsung 32"lcd tv at best by.we have a older dvd player and want to hook it up.Our connectors have a yellow-red-white end but that doesn't match the tv how do I do this.I ahave tried several ways but nothing works
  • Anonymous Mar 24, 2014
    My DVD player has got a Red, white and Yellow outlet. And a Blue Green and Red outlet. The same on the TV inlet, which cables go where?
  • 558 Answers
First what model samsung? second if the tv has yellow red white then you need to change the tv to the input you are using. for best picture I would use an s-video cable it will give you superior video images since I don't know what brand dvd player I only say this if you have an output on the dvd player
most important is to make sure the tv is on what input you have plugged in. and dont forget to power up both units.
Posted on Apr 28, 2008
I have a Philips 32'' LCD, when I hook a DVD it plays in black and white. It will play in color in side connecter only. Please help
The side connectors are usually composite connectors meaning the have a Yellow-video Red-right audio and White-left audio connectors. Now when you are connecting them to the back and you connect the Yellow wire from the DVD player to a component input which have Green,Blue and Red connectors to the green connector, you will get a picture, but it will be in black and white. Please take moment to rate my answer. Thanks...
Nov 22, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
How do i hook my dvd player to my tv? i have no manual to show me where to plug the wires into the back of my tv.i have a proscan 32LB30Q LCD
Hello pebbles12137,
This depends on what you want to do SD or HD
First if you just want to connect for SD only
Here are Three ways:
1) connect the coaxial cable to the DVD player F-connector (sliver screw connector) and the to the TV's Antenna in F-connector.
2) connect the yellow, red and white RCA connector end wires to the yellow, red, and white RCA Jacks of the TV Yellow (video in), Red (Right Audio in), White (Left Audio in) do the same for the other end into the DVD player (Best SD Method)
3) connect the svideo cable into the s-video socket of the TV and the other end to the s-video socket of the DVD player
For HD, Here are the connection methods:
1) Connect the HDMI cable to the HDMI in of the TV (HDMI1)and the other end of the HDMI cable into the DVD player. (best HD method)
2) connect the Component video cable (RGB) into the RGB sockets of the TV (should be marked as Component 1) and connect the other end to the DVD player (using this method you will have to connect the Red and White audio cables to the audio input jacks of the TV from the audio out of the DVD player)
These are the SD and HD methods.
I would suggest using the HDMI cables only, its the best choice and the simplest.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 21, 2009 | Proscan 32LB30QD 32 in. LCD TV
Which channel do i put the tv on, and which do i put the dvd player on in order for them to work together? I have a sanyo flat screen tv and a sony dolby digital dvd player, and i don't know how to get...
You do not put your TV on any channel. DVD players need to connect to a TV with video cables and not a RF cable. This means 3 connection options on how your DVD player should connect to your TV. First, since your DVD player is NOT a bluray player, then HDMI connection is not needed. 2nd, the best choice would be component cables. These are the RED/GREEN/BLUE RCA connector that are on the back of your DVD player. They got into the input of your TV that has the RED/GREEN/BLUE RCA connectors. These are your video connector. Now, you need to connect the audio. Look for the RED/WHITE analog audio connectors out of your DVD player. Connector those to your AUDIO RED/WHITE input of the TV. Power on the DVD player and then power on your TV. Press the SOURCE or INPUT button on the remote for the TV until you see the DVD on the TV....The second option is the connect your DVD player up to your TV with composite video, YELLOW/RED/WHITE cable...
May 16, 2009 | Sanyo DP32648 32 in. LCD TV
No signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
Feb 03, 2009 | Proscan 32LA25Q 32 in. LCD TV
Connect magnavox dvd to ge tv HELP!
You need to go get an RF modulator. They can be purchased at Radio Shack or a number of other electronic shoppes for a reasonable price.
The RF modulator connects to the coax cable connector and it has inputs for the RCA connectors.
Cheers ... Best wishes
Jan 30, 2009 | Televison & Video
UPCONVERT DVD PLAYER HDMI PROBLEM
I have the same issue with this player hooked up to a Samsung 58 inch 1080p plasma.
Jun 06, 2008 | Televison & Video
Connecting Panasonic DVD to TV
What kind of cables are you using to hook up the DVD to the TV? Are they they composite, component, or S-Video? What are the connectors you're plugging both ends of the cables into labeled? Are you plugging the audio cables into the TV or directly into the sound system?
Jan 12, 2008 | Panasonic TC-32LX60 32 in. LCD Television
Magnavox mwd7006 dvd player hookup
if you are useing componet output and the pic is black and white you have them hooked up in the wrong order
The Cableguy
Oct 17, 2007 | Philips Magnavox MWD7006 DVD Player
Televison & Video Logo
147 people viewed this question
Top Televison & Video Experts
