Question about Panasonic (KX-TDA200)
Panasonic tda200 we have 2 extention 1 is 888- 2 is 889 if both number are busy co call is transfer the 883 ? i dont want to Transfer
  • 90 Answers
You can cancel the call forwarding from both phones by dialling *7100(lift handset first) from each phone
Posted on Nov 13, 2010
Transfer calls to External Number and Hangup
have you tried staying on till the other arty answers then hang up
Mar 18, 2015 | Panasonic KXDT343 Phone
CO 1 cannot call out or receives incoming.
Panasonic KXDT321 Phone
Conference call Call party 1 and speak
Press transfer
Call party 2 (press 9 for outside line if needed)
Party 2 answers
Press transfer then 3 speak to all three people
Repeat if required
Jan 24, 2014 | Panasonic KX-T7731 Corded Phone
Every extention on the console is showing with the red led light, as if the lines are busy. Therefore I cannot transfer calls, when in actual fact, the lines are not busy
ouch, sounds bad...
possibilities~
1) everyone has DND turned on if so have them disable their call forwarding entirely (intercom*7100)
2) your buttons are all suddenly programmed wrong, reprogram them to the correct extensions
(press "PROG" then the button you want to program, press " 1 " then the extension number, then enter)
3) major error with the system, have a serviceman come out and take a look
Jan 04, 2011 | Panasonic KX-T7630 Corded Phone
MY TRANSFER BUTTON TRANSFER TO LAST NUMBER DAILED
sounds like the programming for that button was changed to last number redial. To re- program the button, press feature *3, press the button labeled transfer, and press feature 70 (transfer).
Sep 18, 2009 | NorStar M7324 Telephone
Ringer/ Voicemail Bounceback
Well, this one is kinda tricky. If the receptionist knows there's no one there, they can use VoiceMail Transfer.
From the phone, the user can set CF Busy or CF Busy/No Answer with the following codes on the intercom:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding2.gif (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
The last piece of the puzzle is the timing. That's *713 (00-99). Start with 24 (4 rings) and go from there. If it hits the receptionist before the forward takes place, you probably have to adjust the recall timer for call transfer, a system program.
Carl
Aug 11, 2009 | Panasonic KX-T7630 Corded Phone
Can I transfer another mobile number to my Nokia 82 so it can answer two numbers. I have a personal mobile and a business mobile. I get equal amount of calls (both personal and business) on both phones. It...
u can transfer these by using blue tooth. first select ur numbers and then click option and select send via bluetooth. but first active ur bluetooth ur both mobile. and the other way to transfer ur no in pc by cable connection or usb connection. thanks.
Jul 30, 2009 | Nokia Cell Phones
One of the Co lines. CO 4 has a constant fast "busy" tone when off hook. Bad CO card?
The red light will stay on until you clear the alarms. Those alarms can be for any reason, so the idea is to just ignore them and let a technician read them when he comes.
If you don't have a Line 4, it will give you a fast busy because there's no dial tone. Just because it appears, and you can select it, ie green light and display saying Line 004, if it has no line connected to it, you will get a busy. Either get dial tone on the line, disable it, or take it off the set. The first is in program 400, the second is PROG press the button press TRANSFER twice and STORE.
Carl
May 26, 2009 | Panasonic KX-TDA50 Phone
CAN'T TRANFER CALLERS TO VOICE MAIL
A Panasonic system and Pana branded voice mail has a VM Transfer key that lets you send a caller to voice mail. It's programmed by picking a button down the left side of the keystrip (CO) and pressing PROG, the button, 94+ the VM extension, and STORE. (In a TA-824 system it would be either 107 or 115).
The TRANSFER button would work if the extension has CF set (All Call or Busy/NoAnswer), but there would be a delay. At the very least, when you tried yours, you were either dialing the VM extension which is probably not vailid because it won't let you transfer to yourself, or an invalid extension.
Carl
Jan 27, 2009 | Panasonic KX-T7730 Corded Phone
Relocating my extension.
The reason it doesn't transfer is because there is an extension plugged into the jack you are trying to transfer to. Unplug and do it again. If this is helpful, please post as such.
Jan 15, 2009 | Vodavi 30-Button XTS Telephone
Answering machine
Your phone can be programmed to transfer a call to different places and have different rules for day-ring mode and night-ring mode.
Sounds like what you want to do is change your phone to transfer to another extension instead of your voice mail box. This would in effect eliminate your voice mail box because a call would never automatically be sent to it unless you use (and program correctly) night mode.
Your phone model type does not help resolve this. You can have this phone on different Panasonic phone systems. You will need to determine which phone system you have and locate "programming" manual for the specific system (not a user guide)
There should be a section or option called "no-answer forward", "forward timer", "forward extension" etc...
Dec 13, 2007 | Panasonic KX-T7630 Corded Phone
Panasonic (KX-TDA200) Logo
187 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
