My rinnai gas log fire cuts out after 8-10 seconds when turned on,& the number 12 flashes on the displey
    Novelist:
  • 120 Answers
Fault code 12 means the flame lit ok but hen for some reason went out. In my experience this usually means a fault on the gas supply itself. If you are on lpg I have had many problems with gas regulators recently. If you have something else on gas like a cooktop, fire that up first, then try the log fire. If this seems to fix the fault get a gas fitter to change the regulator.
Make sure all taps and isolattion valves are fully on.
I'm have assumed this is not a new installation so the unit has worked ok before.
Does the flame stay strong after it lights. If it slowly fades then definately a gas supply problem.
If it stays strong but just shuts of with a click, then possibly a fault on the heater, check the rod the flame heats is well in the flame. Could be the electronic otherwise but very rare.
If the flame goes yellow like a candle and then shuts off you will need to check the flue or chimmney as this might be blocked..
Cheers, let me know if anything works and re-post with any more info if you are still stuck, I will keep a look out for you.
Posted on Aug 09, 2010
Hi I have a rinnai flame fire royal model ib35etr It keeps going out and flashes number 12 on the screen we are moving and packed the book
I had this same problem last year and went through all the checklist in poshpoms suggestions ( I am on mains Gas ). The issue was caused by the Flame rods. Near the 2 pilots at the front and the back. Those small rods each that 'senses' the flame become inadequate, so they were replaced with a new pilot assembly from Rinnai that had longer rods and better coverage. Issue was fixed. Good Luck.
Aug 23, 2010 | Heating & Cooling
I get a blinking light with the number 12 flashing on my rinnai heater
With the unit turned off, hold down on the economy button, the up arrow and down arrow all at the same time for three seconds. A number of error codes will start flashing. Copy the numbers down and repost them so we can help you. I suspect a dirty flame rod or poor gas pressure. Can you give us any info on when it fails or does it light when you turn off and back on?
Feb 07, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 556 ftr keeps flashing code 12
Hi
Thanks for using FixYa. Error code 12 on a rinnai 556ftr means Flame failure. Check gas is turned ON.
Also see this error manual.
Please refer to this user manual for more details --
Rinnai 556ftr User manual
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Rinnai EnergySaver 556 Air Conditioner
This things beeping and flashing 12 everytime we
check the error codes on it by pressing the on off button for 2 seconds then while holding the on/off button press the up button this should display the last 9 error codes let me know what they are
Jul 28, 2009 | Rinnai Water Heaters
Rinnai tankless water heater code 12
12 - Flame Failure or Poor Ground
1. Immediate code 12 is usually a defective gas valve, power supply problem, or defective fan motor wiring harness.
2. If code 12 occurs after a few seconds it indicates that proper operation was established, but then stopped unexpectedly.
3. Verify that fuel is being supplied to the unit.
4. Check for proper electrical ground. Unit must use a grounded power supply.
5. Check for flue blockage on inlet or exhaust.
http://www.foreverhotwater.com/service-codes.php
Dec 31, 2008 | Rinnai Webstone The isolator EXP tankless...
Rinnai natural gas log fire heater
12 is a fault code, look in the book if you have if, i think 12 is no or low gas pressure, cheers
Oct 06, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Rinnai monitor heater 1004F
http://www.rinnai.us/Rinnai.aspx/FileLib
hope this helps
Feb 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
239 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
