Question about Car Audio & Video
I am istalling a new stereo into an eb falcon,, my question is what colour is constant battery terminal wire,,wire to ignition switch
  • 12,061 Answers
Usually it is either Orange or Yellow.
Posted on Aug 08, 2010
1991 ea ford stereo wiring colours ? i know the speakers,im left with green/yellow,blue/white,black,
Hi there:The Falcon EA (Australian) also called Granada/Scorpion (Europe) or Taurus (America), check this informacion...
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4" Speakers
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Red
Car Audio Rear Speakers Size: 9" x 9"
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Light Green
Left Rear Speaker Negative Wire (-): Dark Blue/Orange
Right Rear Speaker Positive Wire (+): Pink/Light Blue
Right Rear Speaker Negative Wire (-): Light Brown/Red
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Nov 09, 2012 | Cars & Trucks
I need a radio wiring diagram for a Holden Commodore LS 1991
Regardless of colour coding, please follow the following instructions (require multimeter):
Note: Attach multimeter earth wire (black) to the vehicle body. Convenient places may be the metal ignition barrel, the vehicle's car arial plug, cigarette socket body etc.
1) Testing for voltage with key out of the ignition, locate the permanent positive wire. This will wire into the yellow wire on your new stereo. The yellow wire circuit powers the stereo's memory.
2) Testing for voltage again. This time you are testing for a wire which only offers power with the ignition turned on. This one will wire into the red wire on your new stereo, and will power the unit only with the ignition on.
3) Now you know which your vehicle's positive wires are you can now test for an earth wire. Switch the multimeter to the resistance setting. There is one setting which will allow a buzzer to sound once you find continuity. With the ignition off test each wire until you get a buzz and a low resistance reading. This should be your earth wire. Double check this with the ignition in the on position. It should remain the same. If it changes to a positive with the ignition on and with the vehicle's lights switched on, then this is the dimmer feed for the stereo's screen. If you unintentionally found the dimmer feed, then you can ignore this wire, and search again for a wire which only offers an earth.
Now you have your power and earth wires located and can wire these into your stereo before continuing.
4) Next you need to use the stereo's balance and fade controls to allow only one speaker output to work from the stereo. So let's start with Left Front speaker output only. turn the stereo volume to mid way so that you can hear when you have connected to the right speaker. bare the remaining wires on the car side and test combinations of the remaining wires until you find the front left speaker of the car. Wire your stereo's wires once you find the correct connections.
5) Repeat the above steps with all remaining wires, remembering to adjust your stereo's balance and fade controls to only allow one speaker output at a time, to ensure the only one possible channel to work and help you identify which of the car's wires power the speaker you have selected.
Before re-assembly of the dash panel, check that your stereo and all functions work properly, being sure to use your fade and balance controls again to test all speakers individually.
If you want to be extra careful and wire the vehicle's speakers positive and negative, according to your stereo's outputs, not that this makes much difference on standard stereo arrangements, then follow this next step:
Make sure you can see the speakers themselves and connect a 1.5 volt AA or AAA battery to the speaker wires. If the speaker's cone pushes forwards, then the wire you connected to the battery's + terminal is indeed the positive wire and should be wired as such. If the speaker does the reverse, then you have the wires the wrong way around. Do not repeat this test for extended periods as damage may be caused to the speaker circuit.
Tip: Always solder all connections and insulate well from each other. Stereo connections can corrode over time and are prone to movement behind the dash. Poor connections may cause faults and low quality sound.
Oct 30, 2012 | Cars & Trucks
I need the wiring diagram of the stereo cassette radio am/fm, please help my radio is dead (positive and speakers terminals)
You're going to need a multimeter/voltmeter and a 9v battery to do this. It's easiest to first find your constant and switched/ignition wires.
For the constant, you can get ground from any piece of metal inside the dash, and begin touching all the wires, one at a time until you get a voltage. The meter should show 12v or just under. This is your constant. Do the same for the ignition/switched, but this time with the ignition on. Check the remaining wires until you get one at 12v or just under. To check now turn off ignition and the voltage should go away.
For the speakers, it's a little more guessing, but you can check them with a 9v battery. Start with any of the remaining wires and hold it on the positive terminal of your 9v battery. Now go through the remaining wires and touch them, one at a time, to the negative terminal. You should hear a pop from the speaker when you come across the pair. Note the colors and the speaker where it came from. Now move on to another wire and repeat.
You may come across a wire that will not pop when paired with any of the other wires. This could be your ground. Put it a side until you've figured out all the speaker wires. Now go back to the possible ground and use your multimeter to see if you get 12v with your constant wire on positive and the negative wire on the possible ground. If it does it's your ground. If not, it could be something like a dimmer, power antenna or remote line that isn't necessary in replacing a stereo.
The downfall of doing this is that it doesn't tell you polarity. After you finishing connecting the radio to the in-dash wiring turn it on. Listen to the sound carefully. If it sounds tinny one or more of the speakers polarity are incorrect. Try to determine which speaker/s sound tinny and reverse there wiring. Check again and hopefully everything's sounding good.
I hope this is helpful.
Ray
Mar 03, 2011 | Scosche Industries Scosche MN1377B 199902...
Starter activates when battery wire connected and starter is grounded to frame with or without solenoid wire connected. No short between posts on new starter. Only does it when the power source is from the...
sounds like you are hooking up the starter wrong. the positive goes to the starter main terminal from the battery. the ignition wire goes to the s on the solenoid, which activates 12 volts when the ignition switch is turned on which causes a magnetic field
inside the solenoid and joins the connectors
in the solenoid to the main positive wire from the
battery to the main starter unit brushes/armature inside the starter unit. If you have a constant
12 volts from the ignition wire it will keep the solenoid engaged. If you put the main positive wire on the wrong solenoid terminal it will immediately engage the starter. try putting the main battery wire to the correct terminal or perhaps check the ignition wire for a short or constant voltage to the solenoid.
Feb 10, 2010 | 1999 Jeep Wrangler
Original wiring in car for stereo what goes where?
This are the colours 1993 Ford Thunderbird Car Radio Wiring Diagram Car Radio Battery Constant 12v+ Wire: Green/Yellow Car Radio Accessory Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Black/Light Green Car Radio Illumination Wire: Blue/Red Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: Orange/Blue Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 5′ x 7′ Car Audio Front Speakers Location: Doors Left Front Speaker Positive Wire (+): Orange/Green Left Front Speaker Negative Wire (-): Black/White Right Front Speaker Positive Wire (+): White/Green Right Front Speaker Negative Wire (-): Black/White Car Audio Rear Speakers Size: 5′ x 7′ Car Audio Rear Speakers Location: Side Panels Left Rear Speaker Positive Wire (+): Pink/Green Left Rear Speaker Negative Wire (-): Pink/Blue Right Rear Speaker Positive Wire (+): Pink/Blue Right Rear Speaker Negative Wire (-): Green/Orange
Jan 08, 2010 | Car Audio & Video
Which wire is constant power 4 the radio, and which color is when the ignition switch is on, 91 ford f150?
1991 Ford F150 Truck Car Stereo Wiring Schematic
Car Radio Ground Wire: Red or Black
Car Stereo Antenna Trigger: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
This should help you with more then just the constant power wire, good luck.
Dec 14, 2009 | 1991 Ford F150
I need wiring color coding 4 pioneer deh 2050mpg? i know red is constant power.
Not to question you about the red being constant power but I have a pioneer deh-1600 car stereo and red is hooked to electric terminal controlled by ignition switch (on/off) and if your unit has a yellow wire that goes to constant power. The only problem with hooking up the red wire to constant would be if you happened to accidentally leave your player on it could drain the battery. Hope this helped a little. Good luck.
Oct 10, 2009 | Pioneer DEH-P2000 CD Player
After replacing my battery i have to put the code in every time i start the car for the radio is this electrial or fuse problem
ok , as you may know, your car has a security feature that disables the stereo every time the power is disconnected from it. so that is your problem. you have 2 power supplies to your stereo. one is a wire that is connected to your ignition switch, so that is like an electrical switch so to say, that powers up the unit when you start the car. the second is a slightly larger wire that supplies a constant current to the stereo, even when the cars off. this wire allows the stereo to save your sound and radio presets, and other memory when you turn the ignition off. this constant wire is most likely your problem. im not sure where this wire is spliced into your battery. it may be at athe battery, or it may be a wire leading into your under hood fusebox. check the owners manual for the fuse locations, and check to see if they are bad. then, check to make sure there werent any wires or connecters that may have been left off by accident when the stereo was disconnected. finally if that doesnt work, you can locate this wire, and replace it, if you know how to use a digital multimeter. just determine what wire is the constant, cut and splice a new wire into the stereo-end of the old constant, then run that wire to a constant power supply, like directly to the positive battery post. if you do though, just make sure that the wire will be clear from any moving or hot parts, and dont forget to install some kind of fuse near the battery. im guessing a 10 amp fuse should be sufficient. hope this helps you, or at least gives you a good starting point.
Aug 03, 2009 | 2004 Mitsubishi Galant
Info on what colour rear speaker wires are on 2005 pontiac g6
Here are the radio wire colors of the whole system, please rate this solution.
2007 Pontiac G6 Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power or use the brown wire (+) at the ignition wire harness.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jan 06, 2009 | 2007 Pontiac G6 GT Convertible
1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Feb 22, 2008 | Car Audio & Video
Car Audio & Video Logo
70 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
