Question about Char-Broil CharBroil 4637318 Grill
I just put a new tank of gas on the charbroil and the flame does not get very high
  • 140 Answers
Turn the tank upside down for 20 seconds that should do it
Posted on Aug 09, 2010
I had my charbroil grill for 2 yrs and I now when I turn on the propane tank and ignite, I hear hissing followed by it lighting then flames proceed to come out the front middle burners. Do I need a new...
Before buying anything, look into the burners for spider webs. The webs block gas from getting to the burner and will fire back. This is dangerous. Look carefully where the gas nozzle enters the burner tube.
Gary
Sep 04, 2011 | Char-Broil CharBroil Master Flame Gas...
I cleaned my grill to try and solve this problem. I blew out the burner and there's no debris in it. I put everything back and connected to the propane. I still only get a flame that is on low. ...
To get a high flame, do the following:
Be sure you have adequate gas in the tank to maintain combustion. If that checks out OK, start with step # 1.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!! Thanks for choosing FixYa.
Aug 09, 2011 | Char-Broil CharBroil 4637318 Grill
I have a Char-Broil Grill that I bought at Home Depot. I tried to use it tonight, and I couldn't get a strong flame. I had put in a new propane tank, and this was the first time I used it. What would you...
The new tanks have a safety feature, if the connector is cracked and there is low pressure it will shut off the gas flow from the tank.
Check the connector at the tank, I had a cracked plastic one.
Aug 13, 2010 | Char-Broil CharBroil Master Flame Gas...
New Charbroil gas regulator leaks
The connector on the grill side that connects to tank may be bad. Call manufacturer and they should send you a new hose and regulator for free since it is a new grill. If grill does the same then replace tank.
Apr 25, 2010 | Char-Broil CharBroil Master Flame Gas...
I have a gas grill that has set for about two years and now it has a low flame when gas is set to high. Is it the burner or the regulator
I shut off the gas at the tank and grill. Removed the regulator from the tank and turned on the knobs on the grill for one minute. Then turned off the grill reconnected the gas line to the tank and opened the tank knob slowly.
Oct 31, 2009 | Char-Broil CharBroil Master Flame Gas...
Yellow flame from all carryover tubes. This grill is brand new
if the unit is running on natural gas, this is not unusual. if running off propane tank something is wrong with the regulator
Jul 05, 2009 | Char-Broil CharBroil Master Flame Gas...
Flames only come out very low on both sides
disconnect tank, hook tank back up, then open valve slowly. When opened to fast it thinks valve is leaking and shuts down.
Jun 11, 2009 | Char-Broil CharBroil Master Flame Gas...
BBQ LOW FLAME WHEN ON HIGH HAVE NEW TANK ON IT CHANGE HOSE GOING FROM TANK TO BBQ HAD TANK CHEAKED FOR LEAKS OK TRIED OTHER TANK STILL HAVE PROBLEM. CAN YOU HELP ME IAM MUST FRUSTRATED I have a grill whose...
Your frustration is common because the new tanks all have a safety feature built into them which is a pain in the you know what. Unscrew the tank to reset the safety valve and then screw it in again. That should result in the valve being in the open position and working for you.
Jun 02, 2009 | Char-Broil CharBroil 4637318 Grill
Charbroil master flame gas grill the flame is either very high or very low
How old is the grill? The size of the holes in the burner is critical. As burners age, the holes rot out, and get bigger. The velocity of the gas exiting the holes has a large effect on flame size. New burner is the most typical solution.
Mar 08, 2009 | Char-Broil CharBroil Master Flame Gas...
Char-Broil CharBroil 4637318 Grill Logo
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Jim Thurston
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
