Question about Samsung WF203ANW Front Load Washer
I have a samsung 7Kg J845 front load washing mechine, when i turn on, water not fills enough ( only water fills couple of seconds after stops flows. the error shows 4E, Then i clean up all mesh filters Again we face same problem,
  • 15,935 Answers
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Samsung washing machine nf Error code
Here is the best troubleshooting manual i've ever seen. It's PDF:
http://downloadcenter.samsung.com/content/UM/201106/20110628141933509/WF350AN-Tech-02834A-02.pdf
I found it here:
https://www.samsung.com/us/support/owners/product/WF350ANP/XAA
NOTE: If water is not entering tub, you almost certainly need to replace the water valve. If water is entering tub but won't fill your drain pump is suspect. Hope this helps.
Dec 30, 2012 | Samsung WF350ANP Front Load Tumble
Our samsung j845 front loader wont drain we have pulled every hose off and flushed them all out we have drained it and still nothing everything still sounds as if its working properly but it just wont...
I have a Samsung J845 front loader washing machine, A few weeks ago, no water would go into the machine, so replaced the broken solenoid. Now the water never stops going into the machine ??? The solenoid is working but not getting electrically turned off. When I pull the terminal from the solenoid the water stops. What has gone wrong now???
Jun 04, 2010 | Washing Machines
I have a Samsung Front Loading Washing Machine 7kg and it isnt filling up the water is coming out front under the machine any ideas what the problem maybe, thankyou
Remove the lid and check for fill hoses split....This could account for both faults..Check inlet hoses not loose...Please leave feedback
Apr 08, 2010 | Washing Machines
Samsung j845 oe error
What you need to be looking at is the water lever sensor. Take the top off by removing 2 screws in the back (Top right and top left). Slide the top off. Now you want to be standing in the front. The front right side is the sensor. Make sure the hose is properly connected underneath. If you have a meter, take a resistance measurement across the two end pins. Should read about 20 ohms or so.
Dec 13, 2009 | Samsung Washing Machines
I need a manual for a Samsung 7kg Front loader washing washine model number J845
I googled the make and model of the washing machine and it bought up a site that had manuals that were in PDF form and I printed it from that.
In fact I got the manual for the washing machine, oven and microwave.
Nov 12, 2009 | Samsung Washing Machines
Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Oct 22, 2009 | Samsung WF337AA Front Load Washer
Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Sep 30, 2009 | Samsung Washing Machines
7kg J845 frontloader keeps leaking water even
check and see if the float moves freely , could be sticking and causing too much water to enter the dishwasher.
Sep 13, 2009 | Washing Machines
Our samsung j845 front load washing machine won't
You have a blockage in the drain pump or sump on the machine, it could be anything from a coin, bra wire or an elastic band, best thing to do is switch off the electricity and incoming water, remove as much water from the machine as possible, pull machine out place a suitable container below the drain filter and then open up the filter (if fitted) once cleaned check hoses and drain pump internally for blockages.
Sep 07, 2009 | Samsung WF337AA Front Load Washer
4E error....samsung J845
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Aug 23, 2009 | Samsung WF203ANW Front Load Washer
Samsung WF203ANW Front Load Washer Logo
736 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
