Question about Fisher Audio Players & Recorders
I have a Fisher ST-845 speaker that I just replaced the foam around the subwoofer. Now I have a bass rattle in just one speaker when I turn up the volumef. Any suggestions?
jerryg50
  • 1689 Answers
SOURCE: Rattle Problem w/ subwoofer
When you put the new foam, maybe the cone went off center. Get a new kit, and re-do the job with more care. Check to make sure that the spider is okay, and that the speaker coil is not warped or anything like that.
There are speaker companies the professionaly rebuild speakers. They are better equiped and have the jiggs and facilities to properly rebuild the speaker from the coil up.
If you really want your speakers, you should consider giving the complete set out for rebuilding and testing.
Jerry G.
Posted on Apr 28, 2008
  • 15 Answers
SOURCE: Low treble
I suspect that the speaker levels need to be set. You connected everything right - many people would not have connected the sats via the bass section (which has their high pass crossover and overload protection). But I am betting the HSU is turned up a bit on the high side.
Try this. Set all speakers to small, set all levels to 0. Play the receiver in stereo all mode. If the bass is strong, you need to turn the HSU down closer to a natural sound. Then use the speaker setup tone and adjust as needed.
Posted on May 15, 2008
  • 6 Answers
SOURCE: Subwoofer preout and bass
did you tell the receiver that you have a subwoofer connected (thru the quick setup)?
Posted on Aug 05, 2008
  • 119 Answers
SOURCE: What is the significance of
Yes, buy a speaker system with smaller speakers and a sub woofer. Bose, Boston, JVC or the likes
Posted on Feb 25, 2009
  • 336 Answers
SOURCE: The foam edge support for
Check out this site: http://www.mcmelectronics.com/search.aspx?C=&K=speaker%20repair
or google search "speaker refoaming" to find a local or somewhere to ship them to be repaired.
Posted on Mar 08, 2009
I have a 2004 Avalon, all of the speakers (except the subwoofer) work, I noticed there is no bass and then found out the subwoofer makes no sound, does anyone know what might be the problem?
Toyota Avalon JBL Speaker Subwoofer Foam Repair 86160 ...
? 18:34
https://www.youtube.com/watch?v=vDHEbiyBt9I
Jul 16, 2012 - Uploaded by Simply Speakers
Toyota Avalon JBL Speaker Subwoofer Foam Repair 86160-AC180 .... Luckily you don't have to remove the rear deck to get at the subwoofer, ...
Removing rear subwoofer / rear deck - Toyota Nation Forum : Toy
Nov 19, 2015 | 2004 Toyota Avalon XLS
Need speaker box Measurements for a 10 inch 8 ohm kicker comp
Look in the manual that comes with your subwoofer. For most 10" subwoofers, you need to make sure there is at least 1" to 2" around the subwoofer for the front plate. And the figure out how you want it to sound for the depth of the box. Slimmer box equal higher bass, wider box equals deeper boom. You always want to account for the thickness of the wood. If it's thinner wood you won't have that deep of bass. If you have thicker wood it will give a richer sound. Mainly if you building a single box you need at least 12"X12"X12" would be just fine. It gives plenty of room for everything to fit and you can just fill it with foam to make the bass sound deeper.
Sep 20, 2012 | Car Audio & Video
My bose ps28 is making a rattling noise whenever bass is involved. How do i fix it?
You have lost the sponge roll surround of your subwoofer ( suspension ). Its known as foam rot.
Either you can buy new woofer drivers for the subwoofer or repair the surround alone. Kits are available. But you will need some technical skill.Check out this link.
http://popular.ebay.com/consumer-electronics/bose-speaker/bose-speaker-repair.htm
Mar 10, 2011 | Bose Lifestyle 28 System
Our speakers have a "rattle"
Without the foam they will definitely rattle as you mentioned.Probably 3/8" - 1/2" thick should do it as it should compress when you reattach the speaker.It really doesn't need to be specifically for speakers.At least I would just find something available cheap.Foam is foam really.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.Good luck,Greg
Dec 05, 2010 | ElectroVoice . Speaker
One of my kicker cvrs rattle really loud at high volumes
It could be the foam edging where the speaker meets the edge of the cone. Rubber works better than foam, and I believe kicker uses foam for this model. Check for any missing screws because sometimes air leaks make that sound you hear. also try turning down the amp a little bit
Mar 07, 2010 | Kicker CVR12 Car Subwoofer
Kinyo t3100 bass speaker has a rattle when playing music
try turning the bass down and make sure that the rattle is inside the speaker check around it and see if its not something nearby the speaker it could be something came off inside.
Oct 08, 2009 | Kinyo NB-100 Computer Speakers
Bass sounds muggy it rattles alot when volume is turned up. It just started to happen. What is happening? The bass from the head unit is at -8 while the subwoofer level is a +15.
Have you had it checked out, if it rattles when bass hits hard, it could be busted, have you had it up extremely loud before? If so, that is probably what done it, otherwise, I would call whoever you bought it from, and ask them if they know anyone who has had similar problems to yours.
Sep 03, 2009 | Eclipse SW8102.4 Car Subwoofer
When i play certain bass, like mainly highs, but not all highs, my speaker seems to rattle. no im not an idiot. i know subwoofers rattle stuff when you have them on. i know almost all there is to know...
It is possible to overdrive a speaker beyond what it can handle.
DO NOT BELIEVE the spec sheets regarding power and capabilty, especially those for automobile amps and speakers.
If the cone moves too far, the voice coil leaves the active area of the magnetic field and the speaker will "rattle".
The speaker AND its enclosure may be resonating at particular frequencies.
If these things are happening, you will permanently damage the speakers.
Jul 29, 2009 | Rockford Fosgate P112-200 Car Subwoofer
Jerry G.
Apr 27, 2008 | Audio Players & Recorders
382 people viewed this question
Top Fisher Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
SHARCNET-USA
SHARCNET-USA
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
