Question about Alcatel One Touch C750 Cellular Phone
How do i put music on my alcatel phone from my computer??
Caan't get my phone re-installed to wi fi/ all it's showing is basic icons for camera, selfie music and contactcs - please help as no instructions given with phone!!
wifi is in the settings icon so click on that and then click on the wifi adjustments
the settings icon comes up on opening the scree after you put in the password or security code
Dec 17, 2016 | Alcatel Cell Phones
How do I change the ringtone on my alcatel big easy 392G
The manual is here
PAGE 36
10. Buy Ringtones and Graphics To customize your phone with ringtones or graphics, visit your service provider's web page. Phone You can access music and audio clips or images you have saved in phone.
http://www.phonearena.com/phones/Alcatel-THE-BIG-EASY-Flip_id8775/manual
Alcatel THE BIG EASY Flip Manual User Guide
Jun 17, 2016 | Alcatel Cell Phones
Hoe do you transfer music to a alcate one touch from a samsung cell phone?
You can connect your Samsung to your computer via USB, locate your music folder, drag it onto your computer and wait for the transfer to be completed. Next, connect your Alcatel One Touch via USB to your computer and drag the music from the music folder into your Alcatel Music folder.
If you do not have a Computer or laptop, then you could also send all your music via Bluetooth, which will take longer but it does the job.
May 30, 2015 | Samsung Cell Phones
How do you send Music on Bluetooth from Samsung phone to Alcatel and What's the password ?
To send music from You phone using bluetooth from Your samsung to a alcatel phone is very simple. Please follow the steps below to be able to send songs from samsung bluetooth to the alcatel:
  1. Turn on the bluetooth on the samsung,
  2. Turn on the bluetooth on the alcatel,
  3. Select the song You want on the samsung,
  4. Go to the option and select send through bluetooth,
  5. It will search for the available bluetooth device that is turned on,
  6. Then it will see the alcatels bluetooth, it will pair the device first before it sends the song,
  7. Once it asks for a passkey, press 1111 on both phones,
  8. Then the song will be sent to the alcatel phone.
Hope this helped. Thank You for using FixYa!!!
Jan 18, 2011 | Cell Phones
When I use the USB cable to connect my Alcatel ot-880 to the computer, all it does is charge my phone. How can I add music and pictures to my phone using the cable as well?
surely it might be showing connected while ur usb is charge ur phone. Go & check in your computer whether it is detecting the sotrage drive
Jul 31, 2010 | Alcatel Cell Phones
How do i use my computer to put music on my one touch tribe
First convert the songs to the format accepted by the phone, if you have the data cable for the phone plug it to the pc and phone..go to my computer copy and paste..or if the pc has a bluetooth device you could just send it by bluetooth
Feb 01, 2010 | Alcatel One Touch C750 Cellular Phone
ALCATEL 4028/4029 PHONE. WOULD LIKE TO KNOW IF IT PLAYS MUSIC SO I CAN HEAR IT WHILE I WORK?
Depends which Alcatel system the 4028/4029 is connected to.
If OXO, you will require an external music source to be connected to the AUDIO-IN port on the CPU (RJ45 plug using pins 1&2) and is recommended to install MOH/Paging isolating transformer. To enable background music on 4028/4029, hold the green speaker key for several seconds. Starts flashing and the volume can be adjusted with the + & - beside the mute key. To disable, just repeat hold process.
If OXE, will require engineer to program softkey & again will require an external music source...
Good luck...
Sep 03, 2008 | Alcatel Lands Phones
Alcatel One Touch C750 Cellular Phone Logo
1,789 people viewed this question
Top Alcatel Cell Phones Experts
D. E. Hev
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Dakshinamurthy...
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
