Bios will not boot - Computers & Internet
    Brigadier General:
  • 4,044 Answers
I was going to advise "Try downloading and installing the Bios update from the manufacturer website. If the programming on the Bios EPROM was corrupted this should resolve the problem. " problem is even if you did this you wouldn't be able to install the update since there is nothing to tell the computer what devices it controls. Even a bad Bios battery will not cause this situation. You could try getting a replacement EPROM of the Bios from the manufacturer but I would either replace the motherboard or take it to a shop that might be able to reprogram the EPROM with the correct BIOS. I haven't priced an actual BIOS chip in a very long time but it should be relatively cheap.
Posted on Aug 08, 2010
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Usb boot drive using bios
You may need to enable USB boot function in the BIOS or change the boot order. In some cases the USB boot function has to be forced from boot priority in the BIOS.
Or goto the boot menu when you first turn the PC on there should be an option to use USB Boot assuming the option is enabled in the BIOS already.
Nov 22, 2013 | Toshiba Satellite C655-S5125
Bios boot screen comes up
Bios Boot Screen? OK, You don't boot from the Bios, the Bios has settings to let you control where to boot from the Hard Drive, the DvD/CD drive, the USB Port or a LAN (Local Area Network). So, what exactly is your screen showing when you press the Power Button to boot it?
Apr 07, 2012 | Toshiba satellite c660
I want to get in the bios to change the setting to boot from disk platform windows 7
  • Shut down your computer. Check your computer manual for the key stroke to get into your BIOS. Typically it is your "F1" or "F2" key.
  • Restart your computer.
  • Press the BIOS key that was indicated in your computer manual. Continue to press the key until the computer enters your BIOS.
  • Once entered in bios look for boot option and set primary boot device.
    Then restart your system
    Feb 20, 2011 | Acer Computers & Internet
    I want to reformat my computer, my question was how to first boot my cd rom to install...
    Start your computer.
    When you see the 'Press DEL to enter BIOS SETUP mode", press the 'DEL' key.
    Change the "boot-order" to put your CD-ROM as the "first" (highest-priority) boot-device.
    Save-and-exit from BIOS setup.
    Insert the disk into the CD-ROM.
    Your computer should boot from the disk in the CD-ROM.
    Apr 07, 2010 | EliteGroup P4VMM2 V7.3 (P4VMM273)...
    Only booting after pressing f12 and select boot devise
    You must change the boot sequence from your BIOS.
    To do this, when your computer starts press F1 or F2 until you enter the bios setup menu. Usually on Toshiba is F1 or Esc key.
    Now that you are in the BIOS, you must locate the boot order section. Just go through every page until you see something like Boot Device, Boot Order, Boot Management, Boot Sequence, etc. (its different for each computer)
    There, change the boot order to move the Hard Disk or DVD ROM in the top two items in the list.
    Save your settings and exit the BIOS.
    Your computer will restart and it should boot up normally.
    Feb 02, 2010 | Toshiba Satellite Pro A200-EZ2204X...
    Can only get to BIOS, system will not boot to CD Rom. Unable to upload settings.
    can u c the boot sequence in the BIOS....
    if yes make to boot it from CDROM insted of Floppy/HDD
    keep this boot seq. in BIOS
    1 boot from CDROM
    2 boot from Flopy
    3 boot from HDD
    Dec 17, 2009 | Acer Aspire 6930-6771 Laptop
    Won't boot
    Under normal circumstances you do not need to boot into a drive to flash your BIOS. Normally you would take a dos boot floppy and the latest BIOS firmware and put them on a floppy, which is then inserted into the floppy drive before turning the computer on, and if the bios boot priority is set to boot from floppy before the harddrive, it will ask to boot from the floppy, which allows you to flash the bios from a command line or text graphical interface.
    *Note that you may be able to use a cd, but floppy is the oldschool way - if you could boot into an operating system you could use the modern methods which flash the bios while running an OS.
    Your board comes with Q-Flash in the BIOS, which means you are able to log into the bios and flash it using this utility and by putting the BIOS firmware on a floppy and inserting it into the computer.
    Please see Here for instructions and Here for the latest firmware.
    If you cannot access the BIOS, meaning the BIOS is completely bricked, then you will need to buy a new motherboard. Unfortunately there is no way to fix a BIOS which is completely bricked.
    Dec 16, 2008 | Gigabyte GA-K8VT800 Motherboard
    Unable to boot from USB fey on D850MV Motherboard
    Download updated bios here
    follow instructions carefully to update bios
    use the F8 key right after power up to select boot device.
    May 09, 2008 | Intel D850MV Motherboard
    Computers & Internet Logo
    85 people viewed this question
    Alun Cox
    David Payne
    David Payne
