Question about Refrigerators
My GE PSC23NG side by side stopped getting cold today. The compressor is not running but the condenser fan is. The turbo fans and all other electrical work ok. Is there a reset button for the compressor that I could try? All the electrical connectors near the compressor are ok. Thanks.
  • 306 Answers
SOURCE: ge side by side tpx24biyaww freezer not cold enough.
You have to find out why the compressor shuts down at 28 degress rather than going on to zero?
You probably need a voltmeter to see what shuts down at 28. The thermostat may be faulty.
What is stopping the compressor from continued opertion until zero freezer degrees is reached?
Go figger!
Posted on May 01, 2009
SOURCE: Compressor not working warm fan inside frezer run
Heat exchanger was iced over, took a hair dryer and melted ice. I think defrost heater element is bad will check it this week end. I put a new computer in the frige about 3 mounths ago and will check if it has gone bad. The compressor is working fine.
Posted on Jun 05, 2009
rylee_smith
  • 8619 Answers
SOURCE: ge side by side profile. freezer works fine, all
Hi!
First of all you need to clean the coils (condenser coils under the unit or evaporator coils inside the freezer). The coils inside could be iced over because of failure of defrost system. Now check that the condenser fan under the fridge is working properly. Check that the fan in the freezer work which pulls cold air from the coils inside freezer and blows it to the fridge side. Are the temperature control knobs in the fridge adjusted correctly? It actually just opens a vent to let more or less cold air in from the freezer. It takes a while for the ice to build up in the freezer enough to affect the cooling.
My first guess would be the defrost timer. You can manually turn it to engage the defrost cycle and observe whether or not the defrost heaters come on. Now use a hair dryer to speed up melting the ice when there is lots of ice buildup. Most timers are 24 hour timers. It will turn the defroster on every 6 or maybe 12 hours depending on the model.
Before testing the defrost heater, unplug the refrigerator to avoid an electrical shock hazard.
The defrost heater is usually located at the back of a side by side freezer or under the floor of a top freezer. It will be necessary to remove obstructions such as the contents of the freezer, freezer shelves, icemaker and the inside rear or bottom panel of the freezer.
The heater is connected by two wires. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 24, 2009
  • 59 Answers
SOURCE: HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator: stopped getting cold condenser fan runs but compre...
This is what to do. On the side of the compressor is a relay overload set. Unplug the power cord. Connect a meter to the wires going into that set. If there is no power you will need the mother board linked below. If there is power you will need another overload relay set.
Mother board
Posted on May 20, 2010
Macmarkus
  • 2605 Answers
SOURCE: GE Profile fridge: freezer is
Hello, welcome to FixYa.
I understand based on your post you have a GE profile PFS22MIS fridge not cooling in the fridge (upper cabinet) section, correct ?.
It is possible the problem is related to the condensor fan, but not likely. The difference with these fridges and many others (especially the older fridges) is the condensor fan does not run all the time. Instead the control board at the back (pcb) tells it when to run and at what rpm to run as well, it is a variable speed fan motor...and may in fact not run at all at periods.
The one thing I'd suggest you inspect is the back wall of the freezer. You mentioned the evaporator fan motor is operating, correct ? Is there any frost build up on the back wall of the freezer section, or if not visible have you removed the back wall of the freezer ?
I will need to watch for your reply before going forward. I hope you can appreciate there are so many variables since the fridge has many factors controlling air flow which in turn determine what the possible problem and solution will be.
Sounds to me it is a damper or blocked evaporator initially at least. Let me know what you find and we'll go from there.
Regards,
Macmarkus :)
Posted on Sep 20, 2011
I have a GE tfx27 or 25pp side by side fridge. Neither the fridge or freezer are getting cold. Fan in freezer is running, condenser runs. Any help?
is the large side of the tube coming from the compressor pump very cool /cold.
is there fuzz in the coils . does the fan to the compressor work always , in the bottom back under the cover
Aug 03, 2014 | Refrigerators
My GE fridge is not cold. Over the last maybe 5 days I noticed the freezer was good but the fridge side was getting warmer, now today the fridge side is warm and freezer side is just cold. Everything on...
Without your model number this is quite generic but should help you troubleshoot.
- Feel the face of the cabinet where the doors close. It should be warm but not HOT to the touch. If you note that the cabinet is hot in the door gasket area open the back of the unit and clean out the condenser coils. Make sure the condenser fan is running. The fan should be running any time the compressor is running.
- Look in the very back of the freezer compartment for signs of frost or ice build up. If you note this condition it is a result of the automatic defrost cycle / componenets not working. The components of the defrost cycle are the defrost control, (main board on some GE units), the defrost heater and the defrost thermostat or thermistor depending upon model. One of these components or wiring has failed.
- Can you hear the compressor running?
NO: The possible causes are:
The PTC / KilXon Thermal overload mounted on the side of the compressor.
The Run capacitor
The compressor
Main control board
Defrost cycle not complete (caused by a bad thermostat or thermistor) What will happen is the unit would go into defrost and never restart. Additionally the defrost heater can remain on.
Temperature control malfunction
The fan in the freezer compartment is supposed to be on any time the compressor is running.
If the compressor is running and the evaporator fan is not running you need to find out why. It can be stopped from ice build up locking the fan blades in place, a bad motor or a wiring problem to the fan.
Lastly... if all the coils are clear, the fans and compressor are running.. the unit can be low on coolant. Low coolant problems are always a result of a tubing. fitting or compressor leak. Most compressor leaks are found right at the PTC / Overload connection area. A leak is easily identified by an oil residue surround the area of a leak. I use a kleenex or paper towel to GRASP but not wipe suspected areas and look for oil on the tissues. If you find oil... you found your leak.
Thanks for choosing FixYa,
Kelly
Aug 05, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My side by side fridge has stopped chilling down, the power is Ok, and moter seems to be working, but no cold inside. A few months ago the freezer side stopped, but as i did not use it , i just left well...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Heated panel
turn your frig off as soon as possible! this is an easy fix but if it goes to long it can cause permanent damage to the compressor and then you have a huge repair bill, or a big piece of trash :(
What has happened is this:
There is a fan called the condenser fan that blows air across the compressor to keep it cool. This fan has stopped working for some reason and now the compressor is VERY hot. When this happens it stops running and you get zero cold produced.
The reason the mullion is hot is because there is tubing connected to the compressor that is run through this area for condensation prevention purposes. When the condenser fan stops working, this tubing gets much hotter than normal, and that is what you are feeling.
So, replace the condenser fan motor before the compressor gets to hot that it damages itself! If I can be of further help please let me know, good luck friend!
May 31, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Mother board
May 18, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Ge zoneline az55ho7d when i tunr on it comes on fine, but after 10 minutes the fan in back side stop running and front fan keep running so throw only air no cold air. so what is wrong . is it motor for the...
Could be lack of service. The unit depends on a clean evaporator and condenser coil. The "other" motor you hear is the compressor starting or stopping probably due to either a high pressure or low pressure switch, or thermal cut-out.
Oct 25, 2009 | GE Zoneline AZ55H07D Air Conditioner
Freezer fan runs for hours
When compressor cycles off, your freezer fan should shut off as well !
Freezer fan should not be spinning while compressor off.
You might need a control board replacement, that controls fan.
If you are talking about compressor run time, that is a bit excessive, usual causes are dirty condensers but you say they are clean - are your condensers at the bottom of the unit ? If so make sure the condenser fan next to the compressor is running too, blowing air ont he condenser.
Sep 26, 2009 | GE Refrigerators
GE side by side TFX22RLC
If the condenser fan is not running while the compressor is running could damage the compressors overload. Yes it's a serious problem if not repaired soon. (Unplug until repaired.) This can cause a weakened internal overload inside the compressor. Thanks, Sea Breeze
Sep 21, 2009 | Refrigerators
The condenser fan is not running and our ref. and freezer are not staying cold
If the condenser fan is not running then the compressor will overheat and go out on overload. Replace the fan motor and that should correct the problem
Jun 22, 2009 | GE GSH22JFR Side by Side Refrigerator
Ge side by side not cooling enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting,
Sep 07, 2007 | GE Profile PSS26NGS Side by Side...
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
