Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Too dark Hi, I have had this TV for a few years, picture always too dark, I don't know if I am just setting parameters wrong. Any suggestions? Jim jkjedi@woh.rr.com
  • 758 Answers
Have you tried to adjust the contrast setting and the brightness?
Posted on Apr 27, 2008
    Genius:
  • 3,587 Answers
Well...the contrast comes to mind first, and then the color temperature..it's all accessible from the menu, of course.
I'd start with contrast, and then look at the color temperature ratings..
Picture brightens then darkens
Trying with a DVD will rule the tuners in the set in or out and also suggest a setting in the set or a box if used is causing this issue.
Nov 03, 2012 | Samsung LN32C350 32 in. TV
Tv got dark and darker and now no picture what can be wrong? bulb bad?
If the model number indicated here is correct that set uses 3 picture tubes.
No bulb used on that model.
If model number is correct let me know and I have a few suggestions.
May 03, 2012 | Hitachi 61SDX01B 61" Rear Projection...
Sony LCD TV has Dark Picture
the problem is not the lamp.
This model has a set of two backlight lamps, and it is practically impossible that both lamps go faulty at the same time.
When the backlight lap in an LCD TV goes off in this way, the faulty part is always the backlight inverter, that is the high voltage board powering the lamp.
In your case you have to get the TV inverter booard replaced.
May 30, 2009 | Audiovox D1210 Portable DVD Player with...
Rolling lines on screen
Sounds like the power supply has a bad capacitor. This problem can inject excessive 60 hz from the AC line into the vertical stabilizing picture system. The hum also my come from the same reason, bad or leaking filter capacitors. Cheaper just to buy a new TV or borrow another TV and connected to your system to see if the problem still occurs.
Mar 16, 2009 | RCA F36668 36" TV
Dark picture
are you using the s-video input
Jan 10, 2009 | RCA P52926 52" Rear Projection Television
Tv problem
Does the set still have backlight? That is, if the set is turned on and the room is dark, can you tell if the LCD screen is still getting power and lighting up (just with no video)?
Dec 09, 2008 | LG 32LX1D 32 in. LCD Television
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Dark picture
you know it sounds like the same problem i had....
look this is something you can try.... "turn the tv off and unplugg it!!!"...you'll need to take out the lower front part of the tv......(where the speakers are to be exact) on each lower end you will find 2 screws..Be careful it will open to the side and there are many wires, i suggest you mark them to know where to put them back...then right in the middle there will be a black cover with about 5 screws..take them out....and look at the very bottom you'll see a thing with 6 pegs....the top ones are for the screen "DO NOT TOUCH THEM"...the ones on the bottom are for the colors...re adjust them...the left one it's for blue, the middle one it's for green and the last one it's for red...
I had the same problem after i moved....and after i re adjust that the tv looks super...
i hope that helps..:P
Sep 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Picture goes black
With a shop doing the repair they will almost always say the deflection PCB will need to be replaced which would be about 350.00 plus labor. I would suggest trying to solder the vertical output IC first as that is usually the cause on the mitsubishi rear projection or solder around the flyback one of the two.
Jun 29, 2008 | Televison & Video
Pioneer SD P5071-K has a dark picture, though, a good one.
You didn't mention if this problem suddenly happened or has been getting dimmer over time. If it's the latter, it could be a heavy buildup of dust/soot/smoke (depending if there are smokers in the house or a wood stove, etc) or the picture tubes going bad. If the set is over 9 years old, I'd replace it with a HDTV set and not look back. If the problem occurred suddendly, then a resistor or some other component may have gone out and it again would not likely be a cheap or easy repair.
Dec 16, 2006 | Pioneer SD-P5795W 57" Rear Projection...
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
109 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
