Question about Philips Magnavox 51MP392H Rear Projection Television
Is there any way to reset the colours on my Magnavox Rear Projection Television. I saw the restore factory button but it doesn't help.
  • Philips Master
  • 8,617 Answers
If the on screen convergence adjustment doesnt correct the alignment issue, you will need to replace the Convergence ICs and resistors. You can get the Phillips DPTV305 - DPTV345 convergence repair kit from www.tvrepairworld.com which has the two ICs and 12 resistors . It also has the CD with instructions.
Posted on Aug 08, 2010
I have sound but no picture
Use your mitsubishi remote and press the menu button which will open up the menu screen and you will see the picture in the upper right. Now you press 1370 then the enter button and you picture will be restored. This is the factory reset for all mitsubishi projection tv's
Dec 03, 2011 | Mitsubishi VS-6043 60" Rear Projection...
Picture has red and blue shadow images
thats a fairly easy fix. You need the DPTV305-DPTV345 convergence repair kit available at the following link.
http://servicemanuals.vstore.ca/
The kit contains the parts and the CD with instructions
Sep 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
My 60" Magnavox projection tv has verticle double vision giving a red line across the top of eveything. All titles and captions are red over white.
hi
this type of problem occurs because of 3 issues..
1.colour wheel
2.jungle 45e3 ic on D- board
3.cathode ray tube...
check them...
thank u..///please rate it
Jul 04, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have a 1999 Magnavox rear projection tv. The colour when it powers up is normal but after about a minute the picture turns turns yellow. I am wondering if I could fix this problem myself. HELP ME!
Sounds like you might have cold solder connections on the R<G<B video driver transistor on each of the crt sockets. If you have never done soldering of this kind then I would suggest you call a svc co. It's not a major repair if that's what it is.
Feb 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Philips Rear Project TV with HD Inputs
It will cost about 600.00 to have a repair shop do it. However you can get the repair kit at the following link which has the coolant and a step by step instructional CD with pictures. Just click on the repair kit catagory, they have the CD available by itself or you can get the entire coolant change kit.
Here is the link.
Jul 23, 2008 | Philips Magnavox 51MP392H Rear Projection...
Instructional program for Magnavox won't turn off, and can't use the remote
I just did a search today because my kids have the same tv. I found out if you push the volume + and channel + at the same time for about 5 seconds, the tv shuts off and resets. It is in factory mode. Give it a try, if that doesn't work try volume - and channel - at the same time.
Jul 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox rear projectin television
Check the fuse first, if you are luck, probably you only need to change the fuse otherwise you probably need a new TV.
Turn off home electrity power or unplug all the expensive units when it is lighting to protect them.
Jul 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
Shadows
try to adjust the colour and balance
Jun 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
Unknown AutoLock on my Philips rear projection tv
If you look on the rear of the set and locate the chassis number can probably assist you. But I will need the chassis number for RCA & Phillips/magnavox.
Feb 02, 2008 | Philips Magnavox 9P6034C 60" Rear...
Adjusting colors on a magnavox 46" projection TV
Replace the CRT fluid. It grows algea in the blue and green only. 9.99 from MCM electronics.
Oct 19, 2007 | Philips 46PP9302 46" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
164 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
