Question about MXR Phase 90 Pedal
Just recently had a friend give me a broken mxr phase 90. said that he couldnt get it to power on with a 9v batter and had never tried a power supply. so i just figured that it just needed a new 9v battery cable to be soldered in. well i plug it into my boards power supply (visual sound 1spot) and as soon as i did power to my other pedals was completely cut off. as if the phase 90 was sucking all the juice out of my 1spot. so i quicky unplugged it. as soon as i did all my pedals had power again and nothing seemed to be fried. so does anyone have any idea what could be causing the problem? im pretty good at soldering and i have a basic knowledge of electronics (replace my own volume pots, switches, pickups) so if its just a solder job i should be able to do it. any help is much appreciated.
  • MXR Master
  • 5,603 Answers
This is likely a problem very near the power input connector. It could be a blown filter cap (electrolytic) or a shorted protection diode. You can troubleshoot this with only an ohmmeter.
A broken power input connector could also be causing a short.
Often the input audio connector is used to switch the power on so trace the power circuitry looking for the problem.
Suggestion test seperate from other pedals. Be careful to not burn out your power supply during testing... we put a lamp in series with teh 120 volts to the power supply to limit current to a safe value while troubleshooting.
Posted on Aug 09, 2010
MXR phase 90 swtiches on but I have no phasing
I would check the difference in sound between using an AC adapter and a battery. These things lose the effect when the batteries get low.
Mar 28, 2014 | MXR Phase 90 Pedal
I just bought an MXR Phase 90 and i do not have the right 9v cable to plug in to the wall. So i just bought a duracell 9v battery and pluged it in. When the pedal is bypassed i can hear the gutair through...
The battery is being shorted by something. It is impossible for me to guess what without looking at it. If the pedal is brand new, take it back for warranty repair/replacement. If you bought it from somebody, you bought THEIR problem... they likely knew about it. If this is the case, look for a pinched wire from the battery lead... make sure it is not backward. If you can't see anything and cannot get a refund, open the pedal. Look for a problem where the 9 volt adapter plugss in. Broken jack, etc. Look for evidence that somebody has taampered with the insides. Of course look for foreign debris.
May 06, 2011 | MXR Phase 90 Pedal
I have the MXR EVH Phase 90. When plugged in, and unit is off my sound is fine. When unit is activated, the light comes on but there is no sound. The same thing is going on with my Maxon AD999 Delay pedal....
The fact that it happens with 2 different units may point to something in common. You just first eleminate the cables as a possibility by swapping. Also, most pedal problems can be traced to a battery issue, so make sure it is a good one. Make sure you are using mono, not stereo cables.
The footswitch could be faulty, try holding it in different ways to see if it makes contact.
Feb 27, 2011 | MXR Phase 90 Pedal
Is there some sort of trim pot or something in the block letter phase 90 where I can turn the volume boost down when it's on. I don't hate the sound of it but it gives me too much gain when I click it. I...
Have you tried experimenting with the order of your signal chain? Have a look at this link:http://www.zimbio.com/Guitar+Boomer/articles/36/How+Choose+Correct+Signal+Chain+Order+Effects
Jul 02, 2010 | MXR Phase 90 Pedal
How do I fix a mxr phase 90 (overvoltaged!with 12V universal)
My first guess would be that the zener diode is probably shorted. Also check the 2N4125 transistor for a short. Start there and update this with your results.
Dan
Apr 30, 2010 | MXR Phase 90 Pedal
Bypass is fine, LED lights when active, but signal is very low in volume when effect is active. Almost inaudible.
Make sure power voltage is adequate. If using a battery, the LED will light LONG after the batteery is beyond usability.
Jan 17, 2010 | MXR Phase 90 Pedal
MXR Phase 90 doesn't phase only clean signal. The oscillator is working and I have changed the BJT's.
sounds like a switch contact problem, try some surgical alcohol. (for the MXR not for you!!!)
Dec 31, 2009 | MXR Phase 90 Pedal
Turns on, led works, just suddenly stopped applying its awesome phase 90 effect though.
If you are using battery power, just because the LED lights doesn't mean the battery is adequate. Check the battery voltage.
If you are on adapter power, make sure any bypass switch is in right state. Also occassionally someone gets the in's and out's cables backward... that can do it!
Nov 09, 2009 | MXR Custom Shop Phase 90 Led
Mxr phase 90 block logo and the 9v power jack not working
These break and SOMETIMES the circuit board gets cracked.
Open up and inspect for damage. If board is cracked, bridge broken traces by soldering wires around the break.
If the solder is broken, resolder it.
If the connector is damaged or weak spring, replace the connector.
Sep 12, 2009 | MXR Phase 90 Pedal
MXR Phase 90 Pedal Logo
231 people viewed this question
Top MXR Music Experts
Vito Vacirca Jr.
Are you a MXR Music Expert? Answer questions, earn points and help others
